Bike Finder · Kona
Kona Remote 160 CR
Kona
Remote 160 CR 2026
CurrentLightweight · EnduroCurrent · 8.2/10iFreshness 8.2/10
Motor
Bosch Performance Line SX · 60Nm · 600W
Battery
Bosch PowerTube 400 · 400Wh
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Full carbon
Weight
20.8 kg
Price
£5,910
View the Kona Remote 160 CR on Kona’s site
Kona Remote 160 CR 2026
From £5,910
EMTB Forums verdict
The Remote 160 CR is Kona's carbon lightweight enduro e-bike, pairing a 160 mm front and rear chassis with the 2 kg Bosch Performance Line SX motor (60 Nm, 600 W peak). A 400Wh internal PowerTube plus the included 250Wh PowerMore range extender gives a 400-650Wh window, and Kona claims a complete weight of just over 20.8 kg, putting it firmly in the light-assist category rather than the full-power class.
It is sold as a single complete build, so the value question is about the spec rather than choosing a trim. You get a RockShox Lyrik Ultimate fork and Super Deluxe Ultimate shock, SRAM Maven Base four-piston brakes on 200 mm HS2 rotors front and rear, and a Shimano Deore Di2 wired LinkGlide drivetrain with Full Manual, Manual+ and Full Automatic eShift modes. The 11-speed CUES 11-50t cassette and WTB ST Tough i30 rims are pragmatic choices that keep cost down rather than chasing a headline groupset.
Geometry is consistent across the four sizes with a 64 degree head angle, 445 mm chainstays and a steepening 77 to 76.8 degree effective seat angle as reach grows from 430 mm to 515 mm. The Match or Mix flip chip switches between full 29 and an MX (29F / 27.5R) rear, and Kona quotes the layout as 0.5 degrees slacker with 5 mm longer stays than the previous Remote 160 DL, biasing it towards composure on steeper terrain.
💬 Forum discussion
Kona Remote 160
42 replies · 18k views · last reply 70 months ago
Join the discussion →
“Kona’s got a bike worth looking at. Definitely real Trail Bike geometry in keeping with their Process series. Not very many eMTB truly this progressive in the geometry. Rides great. Fits 27+ or 29 widetrail. Rides great! Shimano drive.…”
— sparrow · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach430 mm455 mm480 mm515 mm
Stack627 mm627 mm637 mm648 mm
Seattube380 mm380 mm420 mm450 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)77°77°76.9°76.8°
Wheelbase1217 mm1242 mm1272 mm1312 mm
Headtube112 mm112 mm123 mm135 mm
BB Height350 mm350 mm350 mm350 mm
Standover754 mm761 mm762 mm765 mm
Front Centre772 mm*797 mm*827 mm*867 mm*
FC:RC1.731.791.861.95
Trims · 1
Base
£5,910
MotorBosch Performance Line SX · 60 Nm
BatteryBosch PowerTube 400 · 400 Wh
Travel F/R160/160 mm
FrameCarbon
ForkRockShox Lyrik Ultimate, 160 mm, 29", Linear XL air spring, Charger 3.2 damper
ShockRockShox Super Deluxe Ultimate, 160 mm, RC2T damper, Linear XL air spring
StemKona BC, 35 mm
HandlebarKona Remote, 35 mm
GripsKona Key Grip
SaddleWTB Volt Cromoly SL Fusion
SeatpostTransX dropper, 31.6 mm
BrakesSRAM Maven Base, 4-piston, MMX clamp
Rear derailleurShimano Deore Di2 wired E-Shift, 11-speed (LinkGlide)
CrankProWheel EB19 Carbon, 155 mm
ShiftersShimano Deore wireless, 11-speed
CassetteShimano CUES 11-50t, 11-speed
ChainShimano LinkGlide, 11-speed
DrivetrainShimano Deore Di2 wired E-Shift, 11-speed (LinkGlide); ProWheel EB19 Carbon, 155 mm; Shimano Deore wireless, 11-speed; Shimano CUES 11-50t, 11-speed; Shimano LinkGlide, 11-speed
WheelsWTB ST Tough i30 TCS 2.0
TyresFront: Schwalbe Magic Mary Trail Pro Radial Ultra Soft 29x2.5"; Rear: Schwalbe Albert Trail Pro Radial Addix Soft 2.5" (S: 27.5", M-XL: 29")
Weight20.8 kg
Price£5,910
Rides similarly
Spot a mistake?
