Bike Finder · Kona
Kona Remote 130
Kona
Remote 130 2022
DiscontinuedLightweight · Cross-CountryLegacy · 0/10iFreshness 0/10
Easygoing alloy trail bike with gentle, older Shimano power
Motor
Shimano E7000 · 60Nm · 250W
Battery
Shimano STEPS 504Wh
Travel F/R
140/130mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
$6,399
View the Kona Remote 130 on Kona’s site
Kona Remote 130 2022
EMTB Forums verdict
The Kona Remote 130 was the brand's trail-focused electric platform, sitting below the longer-travel Remote 160 enduro sibling. It pairs 140mm up front (Fox Rhythm 34) with 130mm out back via Kona's single-pivot Beamer Independent Suspension, built on a butted 6061 aluminium frame with full 29in wheels.
Power comes from a Shimano STEPS E7000 drive unit fed by a 504Wh battery, with the SC-E7000 display, a Shimano STEPS 2A charger and a Shimano Deore 12-speed drivetrain throughout. Kona offered it as a single sensibly specced build: Shimano Deore hydraulic brakes on a 203mm front and 180mm rear rotor, Maxxis Minion DHF/DHR II EXO+ tyres, WTB KOM Trail i35 rims and a TranzX dropper.
Geometry is moderate by modern standards, with a 65 degree head angle, roughly 76.3 to 76.6 degree effective seat angle and short 435mm chainstays across all four sizes. Reach runs 425mm at size S to 510mm at XL, on a 1186mm to 1282mm wheelbase.
The Remote 130 is now discontinued. Kona listed it at 6399 US dollars and did not publish a separate UK RRP on its model page. No independent owner reliability data is captured here.
Geometry read
Size
Descending
61
A solid all-round descender (65° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
76
Short 435mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
83
Balanced front-to-rear in L (FC:RC 1.86) — weight sits evenly between the wheels.
Technical climbing
54
Climbs well — a 76.4° seat keeps the front planted. 250W of peak power and 60Nm of torque.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Lightweight · Cross-Country bikes (from 70 bikes in the database)
Battery504 Wh54 Wh above average
Motor torque60 Nmabout average torque
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm510 mm
Stack610 mm615 mm625 mm635 mm
Seattube385 mm410 mm450 mm485 mm
Chainstay435 mm435 mm435 mm435 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76.6°76.5°76.4°76.3°
Wheelbase1186 mm1213 mm1243 mm1282 mm
Headtube113 mm118 mm130 mm140 mm
BB Height345 mm345 mm345 mm345 mm
Standover720 mm720 mm720 mm725 mm
Front Centre751 mm*778 mm*808 mm*847 mm*
FC:RC1.731.791.861.95
Trims · 1
Base
$6,399
MotorShimano E7000 · 60 Nm
BatteryShimano STEPS 504Wh · 504 Wh
Travel F/R140/130 mm
FrameKona 6061 Aluminum Butted 130mm Travel
ForkFox Rhythm 34 Float 140mm Tapered 110 Spacing
ShockFox Performance Float Trunnion
HeadsetFSA No.57E
StemKona XC/BC 35
HandlebarKona XC/BC 35
GripsKona Key Grip
SaddleWTB Volt
SeatpostTranzX Dropper Internal 31.6mm
BrakesShimano Deore Hydraulic Disc (Shimano Deore brake calipers, Shimano Deore brake levers)
Rear derailleurShimano Deore
CrankShimano E8000, 36t
ShiftersShimano Deore
CassetteShimano Deore 10-51t 12spd
ChainShimano Deore
DrivetrainShimano Deore; Shimano E8000, 36t; Shimano Deore; Shimano Deore 10-51t 12spd; Shimano Deore
WheelsWTB KOM Trail i35 TCS 2.0
TyresFront: Maxxis Minion DHF EXO+ TR 3C 29x2.5" WT, Rear: Maxxis Minion DHR II EXO+ TR 3C 29x2.4" WT
Price$6,399
Rides similarly
Spot a mistake?
