Steeper 69° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Macina Team 2023
Full-power alloy hardtail for efficient trail miles and fire-road climbs
The 2023 KTM Macina Team is an alloy 29in hardtail eMTB built around the Bosch Performance Line CX Gen 4 (85Nm) and a sizeable 750Wh PowerTube battery on the Smart System platform, paired with 120mm of front travel. It is a trail hardtail, not a full-suspension enduro machine. KTM's full-suspension enduro eMTB is the Macina Prowler.
For 2023 the Macina Team was sold in several configurations across 29in and 27.5in wheels, with the headline 29in 750Wh trims being the 791, 792 and 793. All share the same M-2706 frame and geometry, so the choice between them is really about kit. The 791 is the flagship with a FOX 34 fork, Shimano XT 11-speed, four-piston Deore brakes and an internal dropper post. The 792 steps down to a RockShox Recon, 10-speed Deore and Tektro brakes, while the 793 is the value entry with a Suntour coil fork, Shimano MT200 brakes and a rigid post.
Geometry is moderate and all-day friendly rather than aggressive: a 68.5 to 69 degree head angle, 73 degree seat angle, 474mm chainstays and reach figures of 400/414/430mm across M/L/XL. With the big 750Wh battery, top-loader battery access and LFC mounting points, it leans towards a do-it-all touring and trail hardtail.
Prices were quoted in euros for these European-market models, with the 793 at 3,999 EUR, the 792 at 4,399 EUR and the XT-equipped 791 at 5,199 EUR. There is no genuine UK RRP for the 2023 model year.
Rear-long with a planted front in L (FC:RC 1.44) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Bosch Performance Line CX Gen 4 and a steep the seat angle seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
| M | L | XL | |
| Reach | 400 mm | 414 mm | 430 mm |
| Stack | 618 mm | 625 mm | 636 mm |
| Seattube | 430 mm | 480 mm | 530 mm |
| Chainstay | 474 mm | 474 mm | 474 mm |
| Headtube Angle | 68.5° | 69° | 69° |
| Wheelbase | 1145 mm | 1156 mm | 1177 mm |
| Headtube | 120 mm | 125 mm | 137 mm |
| Standover | 806 mm | 807 mm | 834 mm |
| Front Centre | 671 mm* | 682 mm* | 703 mm* |
| FC:RC | 1.42 | 1.44 | 1.48 |
Trims · 3
791 €5,199 | 792 €4,399 | 793 €3,999 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm · all trims | ||
| Battery | Bosch PowerTube 750 · 750 Wh · all trims | ||
| Travel F/R | 120/? mm · all trims | ||
| Frame | Aluminium · all trims | ||
| Fork | FOX 34 Float AWL 29" e-bike 120mm 15x110 | RockShox Recon Silver RL 29" 120mm 15x110 taper | Suntour XCM 34 coil 29" NLO 120mm 15x110 taper |
| Headset | Acros AICR internal 1.1/8-1.5 angle limit · all trims | ||
| Stem | KTM Team MTB 7deg | KTM Team MTB 7deg | KTM COMP II 7deg |
| Handlebar | KTM Team flat 2X 720mm | KTM COMP II flat 2X 720mm | KTM COMP II flat 2X 720mm |
| Grips | Ergon GA20 | KTM Comp Lock | KTM Comp Lock |
| Saddle | Selle San Marco RND Manganese Rails | KTM Line Sport | KTM Line Sport |
| Seatpost | KTM COMP II dropper internal | KTM COMP II 30.9/400 | KTM COMP II 30.9/400 |
| Brakes | Shimano Deore M6100 / M6120 4-Piston (front/rear); rotors Shimano RT64 CL 180 / 180 | Tektro HD-M535 4-Piston (front/rear); rotors Tektro TR-45 2.3mm CL 180 / 180 | Shimano MT200 / MT200 2-Piston (front/rear); rotors Shimano RT30 CL 180 / 180 |
| Rear derailleur | Shimano Deore XT M8130-11 LG shadow+ | Shimano Deore M5130-10 LG shadow+ | Shimano Deore M4120-10 SGS shadow |
| Crank | KTM E-TEAM ISIS 170mm Q16, FSA Megatooth 38T | KTM E-COMP ISIS 170mm Q16, FSA Megatooth 38T | KTM E-COMP ISIS 170mm Q16, FSA Megatooth 38T |
| Shifters | Shimano Deore XT M8130-11 LG | Shimano Deore M5130-10 LG | Shimano Deore M4100-10 |
| Cassette | Shimano LG400-11 / 11-50 | Shimano LG400-10 / 11-43 | Shimano Deore M4100-10 / 11-42 |
| Chain | KMC e11 Sport EPT | Shimano LG500 | KMC e10 EPT |
| Drivetrain | Shimano Deore XT M8130-11 LG shadow+; KTM E-TEAM ISIS 170mm Q16, FSA Megatooth 38T; Shimano Deore XT M8130-11 LG; Shimano LG400-11 / 11-50; KMC e11 Sport EPT | Shimano Deore M5130-10 LG shadow+; KTM E-COMP ISIS 170mm Q16, FSA Megatooth 38T; Shimano Deore M5130-10 LG; Shimano LG400-10 / 11-43; Shimano LG500 | Shimano Deore M4120-10 SGS shadow; KTM E-COMP ISIS 170mm Q16, FSA Megatooth 38T; Shimano Deore M4100-10; Shimano Deore M4100-10 / 11-42; KMC e10 EPT |
| Wheels | KTM Line - DT Swiss 370 CL hubs (110/15 front, 148/12 rear) / Ambrosio E30 Trail 28H 622x30TC rims / DT Champion 2.0 (front) & DT Alpine II 2.34 (rear) spokes | KTM Line - Shimano MT410B (front) / MT400B (rear) hubs / Ambrosio E30 Trail 32H 622x30TC rims / DT Champion 2.0 (front) & DT Alpine II 2.34 (rear) spokes | KTM Line - Shimano MT410B (front) / MT400B (rear) hubs / Ryde Rival30 32H 622x30C rims / DT Champion 2.0 (front) & DT Alpine II 2.34 (rear) spokes |
| Tyres | Maxxis Rekon EXO/TR 62-622 (29x2.4in) front and rear | Schwalbe Nobby Nic Perf. Folding 62-622 (29x2.4in) front and rear | Schwalbe Nobby Nic Perf. Folding 62-622 (29x2.4in) front and rear |
| Weight | 24.1 kg | 24.5 kg | 25.2 kg |
| Price | €5,199 | €4,399 | €3,999 |
Rides similarly
Spot a mistake?
