Steeper 71° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Macina Race 2023
Simple full-power XC hardtail for fast, smooth terrain
The KTM Macina Race was the brand's budget entry into electric mountain biking for 2023, a no-nonsense aluminium hardtail built around the legacy (non-Smart System) Bosch Performance Line CX Gen 4 motor, a 500Wh PowerTube battery and a simple Purion display. It sat below the alloy Macina Team hardtail and the full-suspension Macina Chacana/Scarp, trading interactivity and battery size for a keener price just around the 3,000 euro mark.
The build is deliberately frugal: a coil-sprung SR Suntour XCM fork with 100mm of travel, a 9-speed Shimano Alivio drivetrain, two-piston MT200 brakes and Schwalbe Smart Sam tyres. The geometry is firmly cross-country and tour focused rather than aggressive, with a relaxed 70.5 to 71 degree head angle, a 73 degree seat angle, long 465mm chainstays and a modest reach (396 to 431mm across M to XL). Mudguard and rack mounts mean it doubles as an everyday commuter.
Two builds were offered: the 592 on 29in wheels and the 572 on 27.5in, each with a 'Glorious' colourway option. It is well suited to riders wanting a stable, durable first eMTB for forest tracks and towpaths rather than technical trails. It is now discontinued; KTM later moved the range to Bosch Smart System hardware and introduced the lightweight Bosch SX-powered Macina Race SX as the spiritual successor, though that is a distinctly different, sportier machine.
Rear-long with a planted front in L (FC:RC 1.39) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Bosch Performance Line CX Gen 4 and a steep 73° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
| M | L | XL | |
| Reach | 396 mm | 414 mm | 431 mm |
| Stack | 618 mm | 625 mm | 636 mm |
| Seattube | 430 mm | 480 mm | 530 mm |
| Chainstay | 465 mm | 465 mm | 465 mm |
| Headtube Angle | 70.5° | 71° | 71° |
| Seattube Angle (eff) | 73° | 73° | 73° |
| Wheelbase | 1096 mm | 1111 mm | 1131 mm |
| Headtube | 120 mm | 125 mm | 137 mm |
| Standover | 745 mm | 761 mm | 792 mm |
| Front Centre | 631 mm* | 646 mm* | 666 mm* |
| FC:RC | 1.36 | 1.39 | 1.43 |
Trims · 2
572 €3,199 | 592 £0 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm · all trims | |
| Battery | Bosch PowerTube 500 · 500 Wh · all trims | |
| Travel F/R | 100/? mm · all trims | |
| Frame | Aluminium (Alloy 6061) · all trims | |
| Fork | SR Suntour XCM 32 coil 27.5" NLO 100mm 15x100 tapered | SR Suntour XCM 32 coil 29" NLO 100mm 15x100 tapered |
| Headset | KTM Team drop/in 1.1/8-1.5 · all trims | |
| Stem | KTM COMP II 7deg · all trims | |
| Handlebar | KTM COMP II rizer15 700mm | KTM COMP II flat 2X 720mm |
| Grips | KTM Comp Lock · all trims | |
| Saddle | KTM Line Sport · all trims | |
| Seatpost | KTM COMP II 30.9/350 | KTM COMP II 30.9/400 |
| Brakes | Shimano MT200 / MT200 2-piston hydraulic disc, Shimano RT30 CL 180/180 rotors · all trims | |
| Rear derailleur | Shimano Alivio M3100-9 SGS shadow · all trims | |
| Crank | KTM E-COMP ISIS 170mm Q16, FSA Megatooth 38T · all trims | |
| Shifters | Shimano Alivio M3100-9 · all trims | |
| Cassette | Shimano HG201-9 / 11-36 · all trims | |
| Chain | Shimano E6070-9 e-bike · all trims | |
| Drivetrain | Shimano Alivio M3100-9 SGS shadow; KTM E-COMP ISIS 170mm Q16, FSA Megatooth 38T; Shimano Alivio M3100-9; Shimano HG201-9 / 11-36; Shimano E6070-9 e-bike · all trims | |
| Wheels | KTM Line - Shimano MT400/MT400B hubs, Ryde Rival30 32H 584x30C rims | KTM Line - Shimano MT400/MT400B hubs, Ryde Rival30 32H 622x30C rims |
| Tyres | Schwalbe Smart Sam K-Guard 57-584 | Schwalbe Smart Sam K-Guard 57-622 |
| Price | €3,199 | £0 |
Rides similarly
Spot a mistake?
