Bike Finder · KTM
KTM Macina Prowler
KTM
Macina Prowler 2022
DiscontinuedFull Power · GravityLegacy · 1/10iFreshness 1/10
Long-travel carbon enduro built for steep, aggressive gravity riding
Travel F/R
180/170mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
25.2 kg
Price
£6,599
View the KTM Macina Prowler on KTM’s site
KTM Macina Prowler 2022
From £6,599
EMTB Forums verdict
The 2022 KTM Macina Prowler is the Austrian brand's carbon flagship enduro eMTB, running 180mm at the fork and 170mm at the rear on a Dimmix Performance Carbon SLL-LTE frame with KTM's STRAIGHT-LINE-LINK linkage. Every 2022 build is a mullet (MX) machine with a 29in front and 27.5in rear wheel, powered by Bosch's Performance Line CX Gen 4 motor (85Nm). It sits above the alloy Kapoho as KTM's most aggressive, longest-travel eMTB, with a slack 64 degree head angle and 75 degree seat angle on the top three trims.
The four-strong lineup runs from the Exonic (12,198 euro) with a FOX 38 Factory fork, FOX DHX2 Factory coil shock, SRAM XX Eagle AXS wireless shifting, Shimano XTR brakes, DT Swiss HXC carbon wheels and a RockShox Reverb AXS post, down to the Pro (6,953 euro). The Prestige (9,233 euro) keeps the FOX 38 and DHX2 but drops to SRAM GX AXS and Shimano XT brakes, while the Master (7,637 euro, around 6,599 GBP at UK retail) and Pro switch to a RockShox Domain fork and SuperDeluxe shock with Shimano drivetrains. The Exonic, Prestige and Master share the smart-system 750Wh PowerTube and Kiox display on the M-2236 frame; the Pro uses a 625Wh non-smart PowerTube on a slightly steeper, longer M-0136 frame (65 degree head angle, longer reach per size).
Geometry is confident and enduro-focused, with 442mm chainstays across all sizes and reach growing cleanly from 432mm on the medium PT750 frame to 467mm on the XL. As a discontinued 2022 model the Prowler is now a used-market carbon enduro option; the M-2236 and M-0136 frames carry different numbers so both size runs are captured separately. Currency note: 99spokes and KTM's own archive pages list these builds in euros, so only the Master's GBP price is asserted from a UK retailer read this session; the other trims keep euro RRPs. No forum owner data is included, so ride and reliability impressions are not claimed.
Geometry read
Size
Setting
Descending
85
Slack 64° head angle, 170mm travel and a long 1248mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
50
Size balance
90
Balanced front-to-rear in L (FC:RC 1.82) — weight sits evenly between the wheels.
Technical climbing
60
Climbs well — a 75° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
How it stacks up vs other Full Power · Gravity bikes (from 135 bikes in the database)
Weight25.2 kg1.4 kg heavier than average
Battery750 Whabout average capacity
Motor torque85 Nm16 Nm below average
Value for money55/100from £6,599 · comparable bikes ~£6,804
Bike geometry diagram
Flip-chip position
geometry changes with the chip
MDLXL
Reach444 mm462 mm489 mm
Stack607 mm616 mm630 mm
Seattube430 mm450 mm480 mm
Chainstay442 mm442 mm442 mm
Headtube Angle65°65°65°
Seattube Angle (eff)76°76°76°
Wheelbase1220 mm1242 mm1275 mm
Headtube100 mm110 mm125 mm
BB Height356 mm356 mm356 mm
Standover801 mm804 mm808 mm
Front Centre778 mm*800 mm*833 mm*
FC:RC1.761.811.88
Trims · 4
Master
£6,599
Exonic
€12,198
Prestige
€9,233
Pro
€6,953
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R180/170 mm · all trims
FrameMacina Prowler Dimmix Perf. Carbon SLL-LTE 170mm UDH; PT750 Bosch Gen.4 / M-2236Macina Prowler Dimmix Perf. Carbon SLL-LTE 170mm UDH; PT750 Bosch Gen.4 / M-2236Macina Prowler Dimmix Perf. Carbon SLL-LTE 170mm UDH; PT750 Bosch Gen.4 / M-2236Macina Prowler Dimmix Perf. Carbon SLL-LTE 170mm; PT625 Bosch Gen.4 / M-0136
ForkRockShox Domain RC 29" 180mmFOX 38 Float 29" Factory e-bike 180mm FIT4FOX 38 Float 29" Performance e-bike 180mmRockShox Domain RC 29" 180mm
ShockRockShox SuperDeluxe Select+ 250x75FOX DHX2 Factory 2Position 250x75FOX DHX2 PerformanceElite 2Position 250x75RockShox SuperDeluxe coil Select+ 250x75
HeadsetAcros AICR internal 1.1/8>1.5" angle limitAcros AICR internal 1.1/8>1.5" angle limitAcros AICR internal 1.1/8>1.5" angle limitKTM Team MTB 1.1/8"-1.5" angle limit
StemKTM Team Trail35KTM Team Trail35KTM Team Trail35KTM Team Trail35 Kiox
HandlebarKTM Team Trail35 rizer25 800mmKTM Prime Trail35 Carbon rizer20 800mmKTM Prime Trail35 Carbon rizer20 800mmKTM Team Trail35 rizer25 800mm
GripsErgon GE10 Evo ergonomic · all trims
SaddleSelle San Marco GND SupercomfortSelle San Marco GND Open Fit Supercomfort Manganese RailsSelle San Marco GND SupercomfortSelle San Marco GND Supercomfort
SeatpostKTM Comp dropper internalRockShox Reverb AXS wirelessFOX Transfer Performance internalKTM Comp dropper internal
BrakesShimano Deore XT M8100 / M8120 4-Piston (Rotor: Shimano RT64 CL 203 / EM600 CL 180)Shimano XTR M9100 / M9120 4-Piston (Rotor: Shimano MT900 CL 203 / 180 Freeza)Shimano Deore XT M8100 / M8120 4-Piston (Rotor: Shimano MT800 CL 203 / EM810 CL 180 freeza)Shimano M4100 / MT420 4-Piston (Rotor: Shimano RT64 CL 203 / EM600 CL 180)
Rear derailleurShimano Deore XT M8100-12 SGS shadow+SRAM XX Eagle SL AXS 12speedSRAM GX Eagle AXS 12speedShimano Deore XT M8100-12 SGS shadow+
CrankKTM TRAIL ISIS 160mm Q16 (Chainring: FSA Megatooth steel 36T 12speed Direct Mount)FSA CK-702/IS Carbon 160mmKTM TRAIL ISIS 160mm Q16KTM TRAIL ISIS 160mm Q16 (Chainring: FSA Megatooth steel 36T 12speed Direct Mount)
ShiftersShimano Deore XT M8100-12SRAM Eagle AXS Rocker PaddleSRAM GX Eagle AXS ControllerShimano Deore M6100-12
CassetteShimano Deore M6100-12 / 10-51SRAM XX1 Eagle XG-1299 / 10-52 rainbowSRAM GX Eagle XG-1275 / 10-52Shimano Deore M6100-12 / 10-51
ChainShimano M6100-12SRAM XX1 Eagle 12sSRAM NX Eagle 12sShimano M6100-12
DrivetrainShimano Deore XT M8100-12 SGS shadow+; KTM TRAIL ISIS 160mm Q16 (Chainring: FSA Megatooth steel 36T 12speed Direct Mount); Shimano Deore XT M8100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12SRAM XX Eagle SL AXS 12speed; FSA CK-702/IS Carbon 160mm; SRAM Eagle AXS Rocker Paddle; SRAM XX1 Eagle XG-1299 / 10-52 rainbow; SRAM XX1 Eagle 12sSRAM GX Eagle AXS 12speed; KTM TRAIL ISIS 160mm Q16; SRAM GX Eagle AXS Controller; SRAM GX Eagle XG-1275 / 10-52; SRAM NX Eagle 12sShimano Deore XT M8100-12 SGS shadow+; KTM TRAIL ISIS 160mm Q16 (Chainring: FSA Megatooth steel 36T 12speed Direct Mount); Shimano Deore M6100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12
WheelsWHEEL F: KTM Line; WHEEL R: KTM Line (made by DT Swiss per UK retailer listing)WHEEL F: DT Swiss HXC 1501 SPLINE 29 CL 110/15TA / 622x30TSS; WHEEL R: DT Swiss HXC 1501 SPLINE 27 CL 148/12TA / 584x35TSSWHEEL F: KTM E-Team Trail 29 CL 110/15TA / 622x30TC made by DT Swiss; WHEEL R: KTM E-Team Trail 27 CL 148/12TA / 622x35TC made by DT SwissWHEEL F: KTM Line - Shimano MT410B CL 32H 110-15TA / Ambrosio E30 Trail 32H 622x30TC / DT Champion 2.0 black; WHEEL R: KTM Line - Shimano MT410B CL 32H 148-12TA / Ambrosio E35 Trail 32H 584x30TC / DT Alpine II 2.34 black
TyresFront: Maxxis Minion DHF 3C-MaxxTerra/EXO/TR 63-622; Rear: Maxxis Minion DHR II 3C-MaxxTerra/EXO/TR 70-584Front: Schwalbe Eddy Current Front Evo SuperTrail TLE 65-622; Rear: Schwalbe Eddy Current Rear Evo SuperGravity TLE 70-584Front: Schwalbe Eddy Current Front Evo SuperTrail TLE 65-622; Rear: Schwalbe Eddy Current Rear Evo SuperGravity TLE 70-584Front: Maxxis Minion DHF 3C-MaxxTerra/EXO/TR 63-622; Rear: Maxxis Minion DHR II 3C-MaxxTerra/EXO/TR 70-584
Weight25.4 kg25.2 kg26.2 kg25.4 kg
Price£6,599€12,198€9,233€6,953
Rides similarly
Spot a mistake?
