Macina Lycan 2026
The 2026 Macina Lycan is KTM's nimble aluminium trail platform, built around 140 mm of Straight-Line-Link travel and a Bosch Performance Line CX motor. The range is in transition: most trims (771, 772, 773 and the 571 Glorious) run the Gen 4 Smart System motor at 85 Nm on a full 27.5 in frame, while the newer 892 and 891 DI2 step up to the Gen 5 motor rated at 120 Nm and 750 W with a Size-Split layout that puts the S frame on 27.5 in wheels and M, L and XL on 29 in.
That split matters for fit and feel. The Gen 4 27.5 in chassis is the steeper, shorter bike: a 66.5 to 67 degree head angle and 397 to 468 mm of reach across S to XL, with a low 15 mm BB drop for an agile, manoeuvrable character. The Gen 5 892 and 891 DI2 frame is slacker at 65 to 65.5 degrees with longer reach (437 to 487 mm) and a deeper 30 mm BB drop on the 29 in sizes, giving a more planted all-mountain stance.
On value, the EUR 4,799 892 looks like the pick of the range: it brings the 120 Nm Gen 5 motor, an 800 Wh battery and a Shimano XT 12-speed mechanical drivetrain for less than the EUR 5,799 Gen 4 771. The Di2 models trade outright motor torque for electronic shifting, with the 891 DI2 topping the line at EUR 5,899 with the Gen 5 motor, 800 Wh pack and Mavic E-Crossride wheels. The 773 L and 571 Glorious anchor the lower end with Suntour forks, RockShox Select shocks and smaller batteries.
| S | M | L | XL | |
| Reach | 397 mm | 418 mm | 442 mm | 468 mm |
| Stack | 600 mm | 602 mm | 612 mm | 621 mm |
| Seattube | 400 mm | 430 mm | 450 mm | 480 mm |
| Chainstay | 450 mm | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 66.5° | 67° | 67° | 67° |
| Seattube Angle (eff) | 74.4° | 74.5° | 74.7° | 74.9° |
| Wheelbase | 1151 mm | 1165 mm | 1192 mm | 1218 mm |
| Headtube | 120 mm | 120 mm | 130 mm | 140 mm |
| Standover | 786 mm | 785 mm | 790 mm | 791 mm |
| Front Centre | 701 mm* | 715 mm* | 742 mm* | 768 mm* |
Trims · 8
571 Glorious | 771 | 771 DI2 | 772 | 772 DI2 | 773 L | 891 DI2 | 892 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 5 · 85 Nm | Bosch Performance Line CX Gen 5 · 85 Nm |
| Battery | Bosch PowerTube 750 · 750 Wh · all trims | |||||||
| Travel F/R | 140/140 mm · all trims | |||||||
| Frame | Aluminium · all trims | |||||||
| Fork | Suntour XCR 34 Air 27.5" LOR 140mm 15x110 taper | FOX 34 Float AWL 27.5" e-bike 140mm 15x110 | FOX 34 Float AWL 27.5" E 140mm 15x110 | Suntour XCR 34 Air 27.5" LOR 140mm 15x110 taper | Suntour XCR34 Air 2CR 27.5" 140mm 15AH2 | Suntour XCR34 Air 27.5" LOR 140mm 15x110 | FOX 34 Float 27.5" Rhythm E 140mm 15x110 | FOX Float 34E AWL Sport 27.5" 140mm 15x110 |
| Shock | RockShox Deluxe Select 230x62.5 | FOX Float DPS Performance 230x62.5 | FOX Float DPS Performance 230x62.5 | RockShox Deluxe Select+ 230x62.5 | RockShox Deluxe Select+ 230x62.5 | RockShox Deluxe Select 230x62.5 | FOX Float Rhythm 2Pos 230x65 | FOX Float Rhythm 2Pos 230x65 |
| Headset | Acros AICR internal 1.1/8"-1.5" angle limit · all trims | |||||||
| Stem | KTM TEAM II Trail35 | KTM TEAM II Trail35 | KTM TEAM Trail35 | KTM TEAM II Trail35 | KTM TEAM Trail35 | KTM TEAM Trail35 | KTM TEAM Trail35 | KTM TEAM II Trail35 |
| Handlebar | KTM COMP II Trail35 rizer15 760mm | KTM COMP II Trail35 rizer15 760mm | KTM COMP Trail35 rizer15 760mm | KTM COMP II Trail35 rizer15 760mm | KTM COMP Trail35 rizer15 760mm | KTM COMP Trail35 rizer15 760mm | KTM COMP Trail35 rizer15 760mm | KTM COMP Trail35 rizer15 760mm |
| Grips | KTM Comp Lock | Ergon GA20 | Ergon GA20 | KTM COMP Lock | KTM COMP Lock | KTM COMP Lock | Ergon GE10 | KTM COMP Lock |
| Saddle | KTM Line Sport | Selle San Marco Ground Short Open Fit Narrow | Selle San Marco Ground Short Open Fit Narrow | KTM Line Sport | KTM Line Sport | KTM Line Sport | Selle San Marco Ground Short Open Fit Narrow | Selle San Marco RND Manganese Rails |
| Seatpost | KTM COMP II 30.9/400 (rigid) | KTM COMP II dropper internal | KTM COMP dropper internal 30.9 T:120 | KTM COMP II dropper internal | KTM COMP dropper internal 30.9 T:120 | KTM COMP dropper internal 30.9 T:120 | KTM COMP II dropper internal 34.9 T:125 | KTM COMP II dropper internal 34.9 T:125 |
| Brakes | Shimano MT401 / MT420 4-Piston | Shimano Deore M6100 / M6120 4-Piston | — | Tektro HD-M750 / E730 4-Piston | — | — | — | — |
| Rear derailleur | Shimano Deore M5120-11/10 SGS shadow+ | — | Shimano Deore Di2 M6260-11 LG SGS shadow+ | Shimano Deore M5100-11 SGS shadow+ | Shimano CUES Di2 U8050-11 SGS shadow | Shimano Deore M5100-11 SGS shadow+ | Shimano Deore Di2 M6260-11 LG SGS shadow+ | Shimano Deore XT M8100-12 SGS shadow+ |
| Crank | KTM E-TRAIL ISIS 170mm Q16, FSA steel 36T Direct Mount chainring | KTM E-TRAIL ISIS 170mm Q16, FSA Megatooth steel 36T 12-speed Direct Mount chainring | KTM E-TRAIL ISIS 170mm Q16 | KTM E-TRAIL ISIS 170mm Q16, FSA steel 36T Direct Mount chainring | KTM E-TRAIL ISIS 170mm Q16 | KTM E-TRAIL ISIS 170mm Q16 | KTM E-TRAIL ISIS 170mm Q12 | KTM E-TRAIL ISIS 170mm Q12 |
| Shifters | Shimano Deore M4100-10 | Shimano Deore M6100-12 | Shimano Deore Di2 M6250 | Shimano Deore M5100-11 | Shimano CUES Di2 EN605 Switch | Shimano Deore M5100-11 | Shimano Deore Di2 M6250 | Shimano Deore M6100-12 |
| Cassette | Shimano Deore M4100-10 / 11-46 | Shimano Deore M6100-12 / 10-51 | Shimano LG400-11 / 11-50 | Shimano Deore M5100-11 / 11-51 | Shimano LG400-11 / 11-50 | Shimano Deore M5100-11 / 11-51 | Shimano LG400-11 / 11-50 | Shimano Deore M6100-12 / 10-51 |
| Chain | KMC e10 EPT e-bike | Shimano M6100-12 | KMC e11 Sport EPT e-bike | KMC e11 Sport EPT e-bike | KMC e11 Sport EPT e-bike | KMC e11 Sport EPT e-bike | KMC e11 Sport EPT e-bike | Shimano M6100-12 |
| Drivetrain | Shimano Deore M5120-11/10 SGS shadow+; KTM E-TRAIL ISIS 170mm Q16, FSA steel 36T Direct Mount chainring; Shimano Deore M4100-10; Shimano Deore M4100-10 / 11-46; KMC e10 EPT e-bike | KTM E-TRAIL ISIS 170mm Q16, FSA Megatooth steel 36T 12-speed Direct Mount chainring; Shimano Deore M6100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12 | Shimano Deore Di2 M6260-11 LG SGS shadow+; KTM E-TRAIL ISIS 170mm Q16; Shimano Deore Di2 M6250; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bike | Shimano Deore M5100-11 SGS shadow+; KTM E-TRAIL ISIS 170mm Q16, FSA steel 36T Direct Mount chainring; Shimano Deore M5100-11; Shimano Deore M5100-11 / 11-51; KMC e11 Sport EPT e-bike | Shimano CUES Di2 U8050-11 SGS shadow; KTM E-TRAIL ISIS 170mm Q16; Shimano CUES Di2 EN605 Switch; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bike | Shimano Deore M5100-11 SGS shadow+; KTM E-TRAIL ISIS 170mm Q16; Shimano Deore M5100-11; Shimano Deore M5100-11 / 11-51; KMC e11 Sport EPT e-bike | Shimano Deore Di2 M6260-11 LG SGS shadow+; KTM E-TRAIL ISIS 170mm Q12; Shimano Deore Di2 M6250; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bike | Shimano Deore XT M8100-12 SGS shadow+; KTM E-TRAIL ISIS 170mm Q12; Shimano Deore M6100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12 |
| Wheels | — | — | — | — | — | — | Mavic E-Crossride 27 CL 110x15TA | 584x30TSS TLR (front) / Mavic E-Crossride 27 CL 148/12TA | 584x30TSS HG TLR (rear) | — |
| Tyres | Schwalbe Nobby Nic Perf. Folding 65-584 (front and rear) | Schwalbe Nobby Nic Perf. Folding 65-584 (front and rear) | Schwalbe Nobby Nic Perf. Folding 65-584 (front and rear) | Schwalbe Nobby Nic Perf. Folding 65-584 (front and rear) | Schwalbe Nobby Nic Perf. Folding 65-584 (front and rear) | Schwalbe Nobby Nic Perf. Folding 65-584 (front and rear) | Schwalbe Wicked Will Perf. 65-584 (front and rear) | Schwalbe Wicked Will Perf. 65-584 (front and rear) |
| Weight | 24.7 kg | 26.6 kg | 26.5 kg | 26.6 kg | 26.9 kg | 26.9 kg | 25.9 kg | 25.9 kg |
Rides similarly
Spot a mistake?
