Bike Finder · KTM
KTM Macina Kapoho
KTM
Macina Kapoho 2026
CurrentEnduro eMTBCurrent · 8.6/10iFreshness 8.6/10
Travel F/R
160/160mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium / Full carbon / Carbon front, aluminium rear
Weight
24.9 kg
View the KTM Macina Kapoho on KTM’s site
KTM Macina Kapoho 2026
EMTB Forums verdict
The Macina Kapoho is KTM's 160mm all-rounder e-fully, and for 2026 it spans an unusually wide range, from the 10,999 euro carbon Exonic Di2 down to the 4,599 euro Comp LTD. All models run KTM's DiMMiX mullet setup, a 29in front wheel paired with a 27.5in Plus rear, on a 65deg head angle and 76.5deg effective seat angle.
The 2026 line splits across two frame platforms. The headline models (Exonic, the Di2 builds, Pro LTD, Comp LTD and the 8900-series alloy bikes) use a new Dimmix CB frame with a carbon or alloy main triangle, the latest Bosch Performance Line CX motor rated up to 120Nm and an 800Wh PowerTube. The carryover Prestige, Master, Elite and 7900-series bikes keep the earlier SLL-LTE Perf. Carbon or alloy frame with the 85Nm Bosch CX Gen 4 Smart System motor and a 750Wh pack. The CB frame is also marginally longer and slacker, with 448mm chainstays versus 442mm on the SLL-LTE frame.
On value, the alloy 8973 L at 4,999 euro is notable: it carries the full 120Nm motor and 800Wh battery with a Shimano Deore XT mech, where the dearer carbon Prestige and Master sit on the older 85Nm/750Wh system. The Exonic is the flagship, with a Bosch CX-R motor, FOX Factory suspension, carbon DT Swiss wheels and a wireless FOX Transfer NEO post.
Geometry is consistent and contemporary rather than extreme, suiting riders who want one bike for long climbs and technical descents. Claimed weights run from 24.9kg for the Exonic to around 27.8kg for the heaviest alloy builds.
Bike geometry diagram
MLXL
Reach453 mm471 mm493 mm
Stack611 mm620 mm634 mm
Seattube430 mm450 mm480 mm
Chainstay448 mm448 mm448 mm
Headtube Angle65°65°65°
Seattube Angle (eff)76.5°76.5°76.5°
Wheelbase1228 mm1250 mm1278 mm
Headtube100 mm110 mm125 mm
Standover830 mm830 mm841 mm
Front Centre780 mm*802 mm*830 mm*
Trims · 17
7971
7972
7973
8971 Di2
8972 L Di2
8973 L
Comp LTD
Elite
Elite Di2
Exonic Di2
Master
Master (TRP)
Master ABS L Di2
Master L Di2
Prestige
Pro L Di2
Pro LTD
MotorBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX-R Gen 5 · 120 NmBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 4 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 Nm
BatteryBosch PowerTube 800 · 800 Wh · all trims
Travel F/R160/160 mm · all trims
FrameAluminium 6061 (SLL-LTE)Aluminium 6061 (SLL-LTE)Aluminium 6061 (SLL-LTE)Aluminium 6061 (Dimmix CB)Aluminium 6061 (Dimmix CB)Aluminium 6061 (Dimmix CB)Carbon (Dimmix CB 160 UDH)Carbon (Perf. Carbon SLL-LTE)Carbon (Dimmix CB 160 UDH)Carbon (Dimmix CB 160 UDH)Carbon (Perf. Carbon SLL-LTE)Carbon (Perf. Carbon SLL-LTE) / alloyCarbon (Dimmix CB 160 UDH)Carbon (Dimmix CB 160 UDH)Carbon (Perf. Carbon SLL-LTE)Carbon (Dimmix CB 160 UDH)Carbon (Dimmix CB 160 UDH)
ForkFOX 36 Float 29" Rhythm e-bike 160mm 15x110FOX 36 Float 29" Rhythm e-bike 160mm 15x110RockShox 35 Silver TK 29" 160mm 15x110 taperFOX 36 Float 29" Rhythm E 160mm 15x110FOX 36 Float 29" Rhythm E 160mm 15x110RockShox 35 Silver TK 29" 160mm 15x110RockShox 35 Silver TK 29" 160mm 15x110RockShox 35 Silver TK 29" 160mm 15x110 taperFOX 36 Float 29" Rhythm E 160mm 15x110FOX 36 Float 29" Factory E 160mm 15x110FOX 36 Float 29" Performance e-bike 160mm 15x110FOX 36 Float 29" Perf E 160mm 15x110FOX 36 Float 29" Perf E 160mm 15x110FOX 36 Float 29" Factory e-bike 160mm FIT4 15x110FOX 36 Float 29" Perf E 160mm 15x110FOX 36 Float 29" Rhythm E 160mm 15x110
ShockFOX Float X Performance 2-Pos 250x70FOX Float X Performance 2-Pos 250x70Suntour Tri-Air 3CR 3-Pos 250x70FOX Float X Performance 2-Pos 250x70FOX Float X Performance 2-Pos 250x70Suntour Tri-Air 3CR 250x70Suntour Tri-Air 3CR 250x70FOX Float X Performance 2-Pos 250x70FOX Float X Performance 2-Pos 250x70FOX DHX Factory 250x75FOX Float X Performance 2-Pos 250x70FOX Float X Performance 2-Pos 250x70FOX Float X Performance 2-Pos 250x70FOX Float X Factory 2-Pos 250x70FOX Float X Performance 2-Pos 250x70FOX Float X Performance 2-Pos 250x70
HeadsetAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limitAcros AICR internal 1.1/8"-1.5" angle limit
StemKTM TEAM II Trail35KTM TEAM Trail35KTM TEAM Trail35KTM TEAM II Trail35KTM TEAM Trail35KTM TEAM Trail35KTM TEAM II Trail35KTM TEAM Trail35
HandlebarKTM Team Trail35 rizer25 800mmKTM TEAM Trail35 rizer25 800mmKTM PRIME Trail35 Carbon rizer20 800mmKTM Team Trail35 rizer25 800mmKTM TEAM Trail35 rizer25 800mmKTM TEAM Trail35 rizer25 800mmKTM Prime Trail35 Carbon rizer20 800mmKTM TEAM Trail35 rizer25 800mm
GripsErgon GA20Ergon GE10Ergon GE10Ergon GA20Ergon GE10Ergon GE10Ergon GA20Ergon GA20
SaddleSelle San Marco Ground Short Open Fit NarrowSelle San Marco Ground Short Open Fit NarrowFizik Terra Aidon X5 SAlloySelle San Marco Ground Short Open Fit NarrowSelle San Marco Ground Short Open Fit NarrowSelle San Marco Ground Short Open Fit NarrowSelle San Marco GND Open Fit Supercomfort Manganese RailsSelle San Marco Ground Short Open Fit Narrow
SeatpostKTM COMP II dropper internalKTM COMP II dropper internal 34.9 T:125FOX Transfer NEO Factory 34.9 wireless dropperKTM COMP II dropper internalKTM COMP II dropper internal 34.9 T:125KTM COMP II dropper internal 34.9 T:125FOX Transfer Factory internal dropperKTM COMP II dropper internal 34.9 T:125
BrakesSRAM DB8 4-PistonTektro HD-M750 / E730 4-PistonShimano M4100 / MT420 4-PistonShimano M4100 / MT420 4-Piston(not listed in spec table; Bosch ABS BDU3863)Shimano Deore XT M8100 / M8120 4-Piston(not listed; Bosch ABS BDU3843)Shimano XTR M9100 / M9120 4-Piston
Rear derailleurSRAM GX Eagle AXS 12-speedShimano Deore XT M8100-12 SGS shadow+SRAM SX Eagle 12-speedShimano Deore Di2 M6260-11 LG SGS shadow+Shimano CUES Di2 U8050-11 SGS shadowShimano Deore XT M8100-12 SGS shadow+Shimano Deore XT M8100-12 SGS shadow+Shimano Deore XT M8100-12 SGS shadow+Shimano CUES Di2 U8050-11 SGS shadowShimano XTR Di2 M9260-11 LG shadow+Shimano Deore XT M8100-12 SGS shadow+TRP A12 1x12Shimano Deore Di2 M6260-11 LG SGS shadow+Shimano Deore Di2 M6260-11 LG SGS shadow+Shimano XTR M9100-12 SGS shadow+Shimano Deore Di2 M6260-11 LG SGS shadow+Shimano Deore XT M8100-12 SGS shadow+
CrankKTM E-TRAIL ISIS 160mm Q16 (FSA Megatooth 36T)KTM E-TRAIL2 ISIS 160mm Q12RACE FACE ERA-E160KTM E-TRAIL ISIS 160mm Q16 (FSA Megatooth 36T)KTM E-TRAIL2 ISIS 160mm Q12KTM E-TRAIL2 ISIS 160mm Q12KTM E-TRAIL ISIS 160mm Q16 (FSA Megatooth 36T)KTM E-TRAIL ISIS 160mm Q16
ShiftersSRAM GX Eagle AXS ControllerSRAM SX Eagle singleClickShimano CUES Di2 EN605 SwitchShimano Deore M6100-12Shimano CUES Di2 EN605 SwitchShimano XTR Di2 M9250Shimano Deore XT M8100-121x12 TRP A12 drivetrain (TRP A12 brakes)Shimano Deore Di2 M6250Shimano Deore Di2 M6250Shimano XTR M9100-12Shimano Deore Di2 M6250
CassetteSRAM NX Eagle PG-1230 / 11-50Shimano Deore M6100-12 / 10-51SRAM SX Eagle PG-1210 / 11-50Shimano LG400-11 / 11-50Shimano LG400-11 / 11-50Shimano Deore M6100-12 / 10-51Shimano Deore M6100-12 / 10-51Shimano Deore M6100-12 / 10-51Shimano LG400-11 / 11-50Shimano LG700-11 / 11-50Shimano Deore M6100-12 / 10-51Shimano LG400-11 / 11-50Shimano LG400-11 / 11-50Shimano Deore XT M8100-12 / 10-51Shimano LG400-11 / 11-50Shimano Deore M6100-12 / 10-51
ChainShimano M6100-12KMC e500 LG e-bikeKMC e11 Sport EPT e-bikeShimano M6100-12KMC e11 Sport EPT e-bikeKMC e11 Sport EPT e-bikeShimano M8100-12KMC e500 LG e-bike
DrivetrainSRAM GX Eagle AXS 12-speed; SRAM GX Eagle AXS Controller; SRAM NX Eagle PG-1230 / 11-50Shimano Deore XT M8100-12 SGS shadow+; Shimano Deore M6100-12 / 10-51SRAM SX Eagle 12-speed; SRAM SX Eagle singleClick; SRAM SX Eagle PG-1210 / 11-50Shimano Deore Di2 M6260-11 LG SGS shadow+; Shimano LG400-11 / 11-50Shimano CUES Di2 U8050-11 SGS shadow; Shimano CUES Di2 EN605 Switch; Shimano LG400-11 / 11-50Shimano Deore XT M8100-12 SGS shadow+; Shimano Deore M6100-12 / 10-51Shimano Deore XT M8100-12 SGS shadow+; Shimano Deore M6100-12 / 10-51Shimano Deore XT M8100-12 SGS shadow+; KTM E-TRAIL ISIS 160mm Q16 (FSA Megatooth 36T); Shimano Deore M6100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12Shimano CUES Di2 U8050-11 SGS shadow; KTM E-TRAIL2 ISIS 160mm Q12; Shimano CUES Di2 EN605 Switch; Shimano LG400-11 / 11-50; KMC e500 LG e-bikeShimano XTR Di2 M9260-11 LG shadow+; RACE FACE ERA-E160; Shimano XTR Di2 M9250; Shimano LG700-11 / 11-50; KMC e11 Sport EPT e-bikeShimano Deore XT M8100-12 SGS shadow+; KTM E-TRAIL ISIS 160mm Q16 (FSA Megatooth 36T); Shimano Deore XT M8100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12TRP A12 1x12; 1x12 TRP A12 drivetrain (TRP A12 brakes)Shimano Deore Di2 M6260-11 LG SGS shadow+; KTM E-TRAIL2 ISIS 160mm Q12; Shimano Deore Di2 M6250; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bikeShimano Deore Di2 M6260-11 LG SGS shadow+; KTM E-TRAIL2 ISIS 160mm Q12; Shimano Deore Di2 M6250; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bikeShimano XTR M9100-12 SGS shadow+; KTM E-TRAIL ISIS 160mm Q16 (FSA Megatooth 36T); Shimano XTR M9100-12; Shimano Deore XT M8100-12 / 10-51; Shimano M8100-12Shimano Deore Di2 M6260-11 LG SGS shadow+; KTM E-TRAIL ISIS 160mm Q16; Shimano Deore Di2 M6250; Shimano LG400-11 / 11-50; KMC e500 LG e-bikeShimano Deore XT M8100-12 SGS shadow+; Shimano Deore M6100-12 / 10-51
WheelsShimano MT410B 32H / Ambrosio E30 & E35 TrailDT HXC 1200 Spline Carbon CL 110/15TA 622x30 front / 148/12TA 584x30 rear (TLR)DT Swiss 370 CL / Ambrosio E30 Trail 28H front, Ambrosio E35 Trail 28H rearMavic E-Deemax S 29 110/15TA front / Mavic E-Deemax S 27 148/12TA rear
TyresMaxxis Minion DHF 63-622 / Minion DHR II 70-584Maxxis Minion DHF 63-622 / Minion DHR II 70-584Schwalbe Nobby Nic Perf. Folding 65-622 / 70-584Maxxis Minion DHF 63-622 / Minion DHR II 70-584Schwalbe Nobby Nic Perf. Folding 65-622 / 70-584Continental Kryptotal F 60-622 / Kryptotal R 65-584Schwalbe Nobby Nic Perf. Folding 65-622 / 70-584Maxxis Minion DHF 63-622 / Minion DHR II 70-584Maxxis Minion DHF 63-622 / Minion DHR II 65-584Schwalbe Magic Mary Evo SuperTrail 65-622 F / Schwalbe Hans Dampf Evo SuperGravity 65-584 RMaxxis Minion DHF 3C-MaxxTerra/EXO/TR 63-622 / Minion DHR II 3C/EXO/TR 70-584Maxxis Minion DHF 3C-MaxxTerra/NEXO+/TR 63-622 F / Minion DHR II 3C/NEXO+/TR 65-584 RMaxxis Minion DHF 63-622 / Minion DHR II 65-584Schwalbe Eddy Current Front Evo SuperTrail 65-622 / Eddy Current Rear Evo SuperGravity 70-584Maxxis Minion DHF 63-622 / Minion DHR II 70-584Maxxis Minion DHF 63-622 / Minion DHR II 70-584
Weight27.5 kg27.8 kg27.6 kg27.4 kg27.2 kg27.8 kg25.4 kg25.9 kg26.2 kg24.9 kg25.3 kg26.5 kg26.9 kg25.2 kg25.8 kg25.2 kg
Rides similarly
Spot a mistake?
