Bike Finder · KTM
KTM Macina Chacana
KTM
Macina Chacana 2026
CurrentTrail eMTBCurrent · 8.5/10iFreshness 8.5/10
Travel F/R
130/125mm
Wheels
29F / 29R
Frame
Aluminium
Weight
24.9 kg
Price
From £4,299
View the KTM Macina Chacana on KTM’s site
KTM Macina Chacana 2026
From £4,299
EMTB Forums verdict
The Macina Chacana is KTM's touring or SUV trail e-bike, sitting below the sportier Prowler and Kapoho models. It pairs 130mm of fork travel with 125mm at the rear via KTM's Straight-Line-Link suspension, on an aluminium 29in frame. The LFC trims add lights, full mudguards and a rear carrier for everyday and load-carrying duty.
The 2026 range splits across two Bosch motor generations and, importantly, more than one frame. The 891 LFC Di2, 891 Di2 and 892 LFC run the newer Performance Line CX (BDU3840) with an 800Wh PowerTube and KTM's Power Tube Top Loader battery access, with KTM quoting up to 100Nm and 750W. The 791, 792, LFC, 791 LFC Di2 and 591 carry over the Smart System Performance Line CX Gen 4 at 85Nm, on 750Wh packs (500Wh on the 591). Geometry is not uniform: the 891 Di2 models use a 65.5 degree head angle, the Gen 4 trims sit at a steeper 67 degrees, and the 892 LFC rolls on 27.5in wheels.
Value sharpens lower in the range. The 591 at £4,299 is the cheapest way in, with a Suntour fork, Smart Sam tyres and a 10-speed Deore drivetrain on a 500Wh battery. The 792 at £5,199 steps up to a 750Wh pack, RockShox suspension and an XT 12-speed mech, while the fully equipped LFC at £5,599 adds FOX suspension, XT Linkglide shifting and the full lights, fenders and carrier package. The Di2 and 89x models bring Shimano CUES electronic shifting and the 800Wh motor, though UK pricing for those trims was not published at the time of writing.
Bike geometry diagram
MLXLXXL
Reach454 mm470 mm487 mm504 mm
Stack610 mm623 mm637 mm651 mm
Seattube430 mm450 mm480 mm520 mm
Chainstay460 mm460 mm460 mm460 mm
Headtube Angle65.5°65.5°65.5°65.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1225 mm1248 mm1271 mm1294 mm
Headtube100 mm115 mm130 mm145 mm
Standover815 mm823 mm831 mm839 mm
Front Centre765 mm*788 mm*811 mm*834 mm*
Trims · 8
591
£4,299
792
£5,199
LFC
£5,599
791
791 LFC Di2
891 Di2
891 LFC Di2
892 LFC
MotorBosch Performance Line CX Gen 4 · 100 NmBosch Performance Line CX Gen 4 · 100 NmBosch Performance Line CX Gen 4 · 100 NmBosch Performance Line CX Gen 4 · 100 NmBosch Performance Line CX Gen 4 · 100 NmBosch Performance Line CX Gen 5 · 100 NmBosch Performance Line CX Gen 5 · 100 NmBosch Performance Line CX Gen 5 · 100 Nm
BatteryBosch PowerTube 800 · 800 Wh · all trims
Travel F/R130/125 mm · all trims
FrameAluminium · all trims
ForkSuntour XCR 34 Air 29" LOR 130mm 15x110 taperRockShox 35 Silver TK 29" 130mm 15x110 taperFOX 34 Float AWL 29" e-bike 130mm 15x110FOX 34 Float AWL 29" e-bike 130mm 15x110FOX 34 Float AWL 29" E 130mm 15x110FOX 34 Float AWL 29" E 130mm 15x110FOX 34 Float 29" AWL E 130mm 15x110Suntour XCR34X Air 27.5" 2CR 130mm
ShockRockShox Deluxe Select 230x57.5RockShox Deluxe Select+ 230x57.5FOX Float DPS Performance 230x57.5FOX Float DPS Performance 230x57.5FOX Float DPS Performance 230x57.5FOX Float DPS Performance 230x57.5FOX Float Rhythm 2Pos 230x57.5FOX Float Rhythm 2Pos 230x57.5
HeadsetAcros AICR internal 1.1/8"-1.5" angle limit · all trims
StemKTM TEAM II Trail35KTM TEAM II Trail35KTM TEAM II Trail35KTM TEAM II Trail35KTM TEAM Trail35KTM TEAM Trail35KTM TEAM Trail35KTM TEAM Trail35
HandlebarKTM COMP II Trail35 rizer15 760mmKTM COMP II Trail35 rizer15 760mmKTM COMP II Trail35 rizer15 760mmKTM COMP II Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mm
GripsKTM Comp LockErgon GA20Ergon GA20Ergon GA20Ergon GA20Ergon GA20Ergon GA30Ergon GA30
SaddleKTM Line SportSelle San Marco RND Manganese RailsSelle Royal Lookin AthleticSelle San Marco RND Manganese RailsSelle Royal Lookin Athletic 3DSelle San Marco RND Manganese RailsErgon SM10 E-MountainSelle Royal Lookin Athletic Evo
SeatpostKTM COMP II 30.9/400KTM COMP II dropper internalKTM COMP II dropper internalKTM COMP II dropper internalKTM COMP dropper internal 30.9 T:120KTM COMP II dropper internal 34.9 T:125KTM COMP II dropper internal 34.9 T:125KTM COMP II dropper internal 34.9 T:125
BrakesShimano MT401 / MT420 4-PistonShimano M4100 / MT420 4-PistonShimano Deore XT T8100 / M8120 4-PistonShimano Deore XT M8100 / M8120 4-PistonShimano Deore XT M8100 / M8120 4-PistonShimano Deore M6100 / M6120 4-PistonShimano MT402 (3-Finger) / MT420 4-Piston
Rear derailleurShimano Deore M5120-11/10 SGS shadow+Shimano Deore XT M8100-12 SGS shadow+Shimano Deore XT M8130-11 LG shadow+Shimano Deore XT M8100-12 SGS shadow+Shimano CUES Di2 U8050-11 SGS shadowShimano CUES Di2 U8050-11 SGS shadowShimano CUES Di2 U8050-11 SGS shadowShimano CUES U6000-11/10 LG shadow+
CrankKTM E-COMP ISIS 170mm Q16 (FSA Megatooth 36T)KTM E-COMP ISIS 170mm Q16 (FSA Megatooth 36T)KTM E-TEAM ISIS 170mm Q16 (FSA Megatooth 36T)KTM E-TEAM ISIS 170mm Q16 (FSA Megatooth 36T)KTM E-TEAM ISIS 170mm Q16KTM E-TEAM ISIS 170mm Q16KTM E-TEAM2 ISIS 170mm Q8KTM E-COMP2 ISIS 170mm Q8
ShiftersShimano Deore M4100-10Shimano Deore M6100-12Shimano Deore XT M8130-11 LGShimano Deore XT M8100-12Shimano CUES Di2 EN605 SwitchShimano CUES Di2 EN605 SwitchShimano CUES Di2 EN605 SwitchShimano CUES U6000-11 display
CassetteShimano Deore M4100-10 / 11-46Shimano Deore M6100-12 / 10-51Shimano LG400-11 / 11-50Shimano Deore M6100-12 / 10-51Shimano LG400-11 / 11-50Shimano LG400-11 / 11-50Shimano LG400-11 / 11-50Shimano LG400-11 / 11-50
ChainKMC e10 EPT e-bikeShimano M6100-12KMC e11 Sport EPT e-bikeShimano M6100-12KMC e500 LG e-bikeKMC e500 LG e-bikeKMC e500 LG e-bikeKMC e500 LG e-bike
DrivetrainShimano Deore M5120-11/10 SGS shadow+; KTM E-COMP ISIS 170mm Q16 (FSA Megatooth 36T); Shimano Deore M4100-10; Shimano Deore M4100-10 / 11-46; KMC e10 EPT e-bikeShimano Deore XT M8100-12 SGS shadow+; KTM E-COMP ISIS 170mm Q16 (FSA Megatooth 36T); Shimano Deore M6100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12Shimano Deore XT M8130-11 LG shadow+; KTM E-TEAM ISIS 170mm Q16 (FSA Megatooth 36T); Shimano Deore XT M8130-11 LG; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bikeShimano Deore XT M8100-12 SGS shadow+; KTM E-TEAM ISIS 170mm Q16 (FSA Megatooth 36T); Shimano Deore XT M8100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12Shimano CUES Di2 U8050-11 SGS shadow; KTM E-TEAM ISIS 170mm Q16; Shimano CUES Di2 EN605 Switch; Shimano LG400-11 / 11-50; KMC e500 LG e-bikeShimano CUES Di2 U8050-11 SGS shadow; KTM E-TEAM ISIS 170mm Q16; Shimano CUES Di2 EN605 Switch; Shimano LG400-11 / 11-50; KMC e500 LG e-bikeShimano CUES Di2 U8050-11 SGS shadow; KTM E-TEAM2 ISIS 170mm Q8; Shimano CUES Di2 EN605 Switch; Shimano LG400-11 / 11-50; KMC e500 LG e-bikeShimano CUES U6000-11/10 LG shadow+; KTM E-COMP2 ISIS 170mm Q8; Shimano CUES U6000-11 display; Shimano LG400-11 / 11-50; KMC e500 LG e-bike
WheelsShimano MT410B / MT400B CL / Ryde Rival30 32H 622x30C, DT Champion / DT Alpine II spokesShimano MT410B CL / Ambrosio E30 Trail 32H 622x30TC, DT Champion / DT Alpine II spokesShimano MT410B / MT400B CL / Ambrosio E30 Trail 32H 622x30TC, DT Champion / DT Alpine II spokesDT Swiss 370 CL / Ambrosio E30 Trail 28H 622x30TC, DT Champion / DT Alpine II spokesAmbrosio E30 Trail 28H 622x30TC (F/R), DT Champion 2.0 spokesMavic E-Crossride 29 CL 110x15TA / Mavic E-Crossride 29 CL 148x12TA HG TLRAmbrosio E30 Trail 32H 584x30TC (F/R), DT Champion 2.0 / DT Alpine II 2.34 spokes
TyresSchwalbe Smart Sam K-Guard 60-622 (F/R)Schwalbe Johnny Watts Perf. DD RaceGuard Folding 65-622 (F/R)Schwalbe Johnny Watts Perf. DD RaceGuard 60-622 (F/R)Schwalbe Johnny Watts Perf. DD RaceGuard Folding 65-622 (F/R)Schwalbe Johnny Watts Perf. DD RaceGuard 60-622 Reflex (F/R)Schwalbe Johnny Watts Perf. DD RaceGuard Folding 65-622 (F/R)Schwalbe Johnny Watts Perf. DD RaceGuard 60-622 Reflex (F/R)Schwalbe Johnny Watts Perf. Folding DD 65-584 Reflex (F/R)
Weight24.9 kg27.6 kg28.7 kg26.6 kg28.9 kg26.6 kg29.2 kg28.6 kg
Price£4,299£5,199£5,599
Rides similarly
Spot a mistake?
