Bike Finder · KTM
KTM Macina Chacana
KTM
Macina Chacana 2025
CurrentTrail eMTBAgeing · 4.6/10iFreshness 4.6/10
Travel F/R
130/125mm
Wheels
29F / 29R
Frame
Aluminium
Weight
24.9 kg
View the KTM Macina Chacana on KTM’s site
KTM Macina Chacana 2025
EMTB Forums verdict
The Macina Chacana is KTM's aluminium SUV trail platform, sitting in the touring camp below the sportier Prowler and Kapoho. With 130mm of fork travel and 125mm out back through KTM's Straight-Line-Link suspension, it is built around the Bosch Performance Line CX (BDU384Y) drive unit rated at 85 Nm and 600 W, paired with a sizeable 800Wh PowerTube on the 891, 892 LFC and 891 LFC Di2 builds. The Power Tube Top Loader mount makes the battery quick to drop in and out.
On value, the 891 at 5,499 euros is the pick for riders who want the long-travel-friendly kit: a Fox 34 Float fork, Fox Float DPS Performance shock, Shimano XT 4-piston brakes and a 1x12 XT drivetrain on full 29in wheels. The LFC variants step down to a Fox Rhythm shock and Shimano Deore/CUES brakes and gearing on 27.5in wheels, but add the light, fender and carrier package for everyday and touring use; the 891 LFC Di2 brings Shimano's wireless CUES Di2 shifting. The 892 LFC swaps the Fox fork for a Suntour XCR34X unit to hit 4,899 euros, while the entry 591 uses a smaller 500Wh Smart System battery, Suntour fork, RockShox Deluxe Select shock and a fixed seatpost at 4,599 euros.
Geometry is moderate and tour-friendly rather than aggressive: a 65.5 degree head angle and 76.5 degree effective seat angle are held across all four 29in sizes, with reach growing from 454mm on the M to 504mm on the XXL and chainstays fixed at 460mm. The 800Wh builds carry a dropper post, while the 591 does not, which matters for committed descending.
Bike geometry diagram
MLXLXXL
Reach454 mm470 mm487 mm504 mm
Stack610 mm623 mm637 mm651 mm
Seattube430 mm450 mm480 mm520 mm
Chainstay460 mm460 mm460 mm460 mm
Headtube Angle65.5°65.5°65.5°65.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1225 mm1248 mm1271 mm1294 mm
Headtube100 mm115 mm130 mm145 mm
BB Height344 mm344 mm344 mm344 mm
Standover815 mm823 mm831 mm839 mm
Front Centre765 mm*788 mm*811 mm*834 mm*
Trims · 4
591
891
891 LFC Di2
892 LFC
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 800 · 800 Wh · all trims
Travel F/R130/125 mm · all trims
FrameAluminium · all trims
ForkSuntour XCR 34 Air 29" LOR 130mm 15x110 taperFOX 34 Float AWL 29" e-bike 130mm 15x110FOX 34 Float 27,5" AWL e-bike 130mm 15x110Suntour XCR34X Air 27,5" 2CR 130mm taper
ShockRockShox Deluxe Select 230x57.5FOX Float DPS Performance 230x57.5FOX Float Rhythm 2Pos 230x57,5FOX Float Rhythm 2Pos 230x57,5
HeadsetAcros AICR internal 1.1/8"-1.5" angle limit · all trims
StemKTM TEAM II Trail35KTM TEAM Trail35KTM TEAM Trail35KTM TEAM Trail35
HandlebarKTM COMP II Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mmKTM COMP Trail35 rizer15 760mm
GripsKTM Comp LockErgon GA20Ergon GA30Ergon GA30
SaddleKTM Line SportSelle San Marco RND Manganese RailsErgon SM10 E-MountainSelle Royal Lookin Athletic Evo
SeatpostKTM COMP II 30.9/400 (rigid)KTM COMP II dropper internal 34.9 T:125KTM COMP II dropper internal 34.9 T:125KTM COMP II dropper internal 34.9 T:125
BrakesShimano MT401 / MT420 4-PistonShimano Deore XT M8100 / M8120 4-PistonShimano Deore M6100 / M6120 4-PistonShimano Deore M6100 / M6120 4-Piston
Rear derailleurShimano Deore M5120-11/10 SGS shadow+Shimano Deore XT M8100-12 SGS shadow+Shimano CUES Di2 U8050-11 SGS shadowShimano CUES U6000-11/10 LG shadow+
CrankKTM E-COMP ISIS 170mm Q16 (FSA Megatooth steel 36T with chainguard)KTM E-TEAM ISIS 170mm Q16KTM E-TEAM2 ISIS 170mm Q8KTM E-TEAM2 ISIS 170mm Q8
ShiftersShimano Deore M4100-10Shimano Deore XT M8100-12Shimano Di2 EN605 wirelessShimano CUES U6000-11 display
CassetteShimano Deore M4100-10 / 11-46Shimano Deore M6100-12 / 10-51Shimano LG400-11 / 11-50Shimano LG400-11 / 11-50
ChainKMC e10 EPT e-bikeShimano M6100-12KMC e11 Sport EPT e-bikeKMC e11 Sport EPT e-bike
DrivetrainShimano Deore M5120-11/10 SGS shadow+; KTM E-COMP ISIS 170mm Q16 (FSA Megatooth steel 36T with chainguard); Shimano Deore M4100-10; Shimano Deore M4100-10 / 11-46; KMC e10 EPT e-bikeShimano Deore XT M8100-12 SGS shadow+; KTM E-TEAM ISIS 170mm Q16; Shimano Deore XT M8100-12; Shimano Deore M6100-12 / 10-51; Shimano M6100-12Shimano CUES Di2 U8050-11 SGS shadow; KTM E-TEAM2 ISIS 170mm Q8; Shimano Di2 EN605 wireless; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bikeShimano CUES U6000-11/10 LG shadow+; KTM E-TEAM2 ISIS 170mm Q8; Shimano CUES U6000-11 display; Shimano LG400-11 / 11-50; KMC e11 Sport EPT e-bike
WheelsKTM Line - Shimano MT410B/MT400B CL 32H, Ryde Rival30 32H 622x30C, DT Champion / DT Alpine II blackKTM Line - DT Swiss 370 CL 28H, Ambrosio E30 Trail 28H 622x30TC, DT Champion 2.0 blackMavic E-Crossride 27 CL TLR (584x30TSS)Mavic E-Crossride 27 CL TLR (584x30TSS)
TyresSchwalbe Smart Sam K-Guard 60-622 (front and rear)Schwalbe Johnny Watts Perf. DD RaceGuard Folding 65-622 (front and rear)Schwalbe Johnny Watts Perf. Folding DD 65-584 Reflex (front and rear)Schwalbe Johnny Watts Perf. Folding DD 65-584 Reflex (front and rear)
Weight24.9 kg29.2 kg28.7 kg
Rides similarly
Spot a mistake?
