Bike Finder · Ibis
no image yet
Ibis
Oso S 2026
CurrentTrail eMTBCurrent · 8.5/10iFreshness 8.5/10
Travel F/R
140/130mm
Wheels
29F / 29R
Frame
Full carbon
Weight
Price
View the Ibis Oso S on Ibis’s site
Ibis Oso S 2026
EMTB Forums verdict
The Oso S is the mid-travel member of Ibis's 2026 Oso eMTB family, pairing 130mm of dw-link rear travel with a 140mm RockShox Pike fork on a full carbon frame. It sits below the longer-travel Oso HD and above the Oso TR, and despite the lightweight-sounding name it runs the full-power Bosch Performance Line CX Gen 5 with up to 120Nm and a 600Wh internal battery, not a lower-power SX system.
Ibis leans heavily on modularity here. Bolt-on dropouts and brake mounts let riders adjust chainstay length and swap between 29" and 27.5" rear wheels, and the shock, clevis and fork can be changed to reconfigure travel. The 600Wh pack keeps system weight down while the optional PowerMore 250Wh range extender lifts total capacity to 850Wh for longer days.
The single $7999 build is well sorted for the money, with SRAM Eagle 90 Transmission shifting, four-piston SRAM Maven brakes on 220mm rotors and Maxxis Assegai/DHR2 rubber. A five-size range including the new Extra-Medium, plus size-specific cranks, stems and chainstays, shows Ibis trying to dial fit across the bell curve.
💬 Forum discussion
Ibis Oso
44 replies · 11.3k views · last reply 38 months ago
Join the discussion →
“Photoshop is certainly possible, but the only bikes I know with a high swingarm like that (Siryon and Wolf Ridge) have a very different shape.”
— Gyre · ♥ 5 · most-liked post
Bike geometry diagram
SMXMLXL
Reach445 mm467 mm489 mm513 mm536 mm
Stack614 mm625 mm634 mm644 mm656 mm
Seattube381 mm381 mm405 mm432 mm450 mm
Chainstay456 mm456 mm457 mm457 mm457 mm
Headtube Angle63.9°64.7°64.4°64.4°64.4°
Seattube Angle (eff)77.7°77.7°77.9°78.4°78.9°
Wheelbase1227 mm1246 mm1276 mm1307 mm1338 mm
Headtube99 mm109 mm121 mm136 mm152 mm
BB Height329 mm332 mm332 mm335 mm338 mm
Standover684 mm697 mm722 mm733 mm750 mm
Front Centre771 mm*790 mm*819 mm*850 mm*881 mm*
Trims · 1
Base
MotorBosch Performance Line CX Gen 5 · 120 Nm
BatteryBosch PowerTube 600 · 600 Wh
Travel F/R140/130 mm
FrameCarbon Fiber
ForkRockShox Pike, Base, 140mm, 29”
ShockRockShox Deluxe Select+, 210x52.5mm
HeadsetCane Creek 50, ZS56/ZS56
StemBlackbird 35 Stem; SM-MD: 35mm, XM-XL: 50mm
HandlebarBlackbird 35 Aluminum Riser Bar 800mm
GripsLizard Skins Strata Single Clamp
SaddleWTB Silverado Fusion CrMo 142
SeatpostKS Vantage Dropper, 34.9mm; SM–MD: 140–170mm, XM–XL: 180–210mm
BrakesSRAM Maven Base
Rear derailleurSRAM Eagle 90 Transmission
CrankSRAM; SM-MD: SRAM 90, 155mm, 34T Steel Ring; XM-XL: SRAM EX1, 165mm, 34T Steel Ring
ShiftersSRAM Eagle 90 Transmission
CassetteSRAM XS 1275 Transmission, T-Type, 10-52T
ChainSRAM GX Eagle Transmission, T-Type
DrivetrainSRAM Eagle 90 Transmission; SRAM; SM-MD: SRAM 90, 155mm, 34T Steel Ring; XM-XL: SRAM EX1, 165mm, 34T Steel Ring; SRAM Eagle 90 Transmission; SRAM XS 1275 Transmission, T-Type, 10-52T; SRAM GX Eagle Transmission, T-Type
WheelsBlackbird Send Alloy, 32H, Blackbird Hubs (F: Send I, 29 / R: Send II, 29)
TyresFront: Maxxis Assegai 29x2.5 EXO; Rear: Maxxis DHR2 29x2.5 EXO+
Rides similarly
Spot a mistake?
