A solid all-round descender (65.5° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Mountain Cross 5 2023
Carbon trail eMTB with Shimano EP801 (85Nm) and 720Wh integrated battery; 24.3kg
The Husqvarna Mountain Cross 5 2025 is a carbon full-power eMTB built around the Shimano EP801 motor, with mid-travel 150 mm-front-and-rear geometry pitched between trail and all-mountain. Headline numbers: 85 Nm of torque, 720 Wh removable Shimano battery, a 65.5 degree head angle, 24.0 kg claimed and a £4,399 base price that is genuinely surprising for a carbon frame at this level. Owners praise the modern geometry and the bike's all-round usability, with the build value being the standout note.
Drive system and range. The Shimano EP801 is one of the most-respected full-power motors in production today: 85 Nm of torque, 600 W manufacturer-claimed peak, 2.7 kg motor weight, with the well-developed E-Tube app ecosystem for power-mode tuning. The 720 Wh Shimano battery is removable and delivers solid all-day capability on a 150 mm trail-class platform. The EP801 has earned its reliability stripes over multiple model years now, with strong dealer support across the Shimano network.
Geometry and handling. The Mountain Cross 5 runs four sizes (S to XL) with reach progressing from 425 mm (S) through 460 mm (M), 480 mm (L) and 500 mm (XL). The head angle is fixed at 65.5 degrees across all sizes, with a 445 mm chainstay and wheelbase that grows from 1,184 mm to 1,279 mm. Bad Mechanic rates the geometry as "modern with a slack headtube (65 degree), a steep-ish seat tube (76 degree) and a long reach (480 mm)" on his large, confirming the bike sits in the sensible 2025 trail/all-mountain bracket rather than the conservative end. The 445 mm chainstay is a reasonable middle ground between agility and stability.
Build and value. Only one trim is on file at £4,399 — exceptional value for a carbon full-power eMTB with the EP801 motor and a 720 Wh battery. Husqvarna's bike division is wholly owned by Pierer Mobility (also KTM, GasGas) and benefits from the parent company's manufacturing scale and parts-sourcing leverage, which explains the aggressive pricing.
Community-verified strengths. First, geometry: Bad Mechanic highlights the slack HTA, steep STA and long reach as the headline ride-quality wins. Second, "really good" overall ride character after a month of ownership on his large. Third, the carbon-frame-at-this-price proposition that no other major brand currently matches.
Caveats and known gripes. First, the smaller Husqvarna bike dealer footprint compared to mainstream brands, which can affect warranty and service access depending on region. Second, with no other curated forum quotes on file specifically about the Mountain Cross 5, prospective buyers should demo before committing and check the Husqvarna service-centre network in their area.
Verdict. The Husqvarna Mountain Cross 5 2025 makes a lot of sense for buyers who want a carbon full-power 150 mm trail eMTB with the proven Shimano EP801 motor, modern geometry, and a price that genuinely undercuts the segment. Less suitable for riders chasing aggressive 170 mm enduro travel, the latest Bosch CX Gen 5 motor, or who require a tight major-brand dealer network. Production status: current.
Balanced front-to-rear in L (FC:RC 1.80) — weight sits evenly between the wheels.
Shimano EP801 and a steep 76.9° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Trail bikes (from 238 bikes in the database)
| S | M | L | XL | |
| Reach | 425 mm | 450 mm | 475 mm | 500 mm |
| Stack | 619 mm | 633 mm | 646 mm | 660 mm |
| Chainstay | 445 mm | 445 mm | 445 mm | 445 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 77.1° | 77° | 76.9° | 76.8° |
| Wheelbase | 1184 mm | 1216 mm | 1247 mm | 1279 mm |
| Front Centre | 739 mm | 771 mm | 802 mm | 834 mm |
| FC:RC | 1.66 | 1.73 | 1.80 | 1.87 |
Trims · 2
Base £4,399 | MC5 | |
| Motor | Shimano EP801 · 85 Nm · all trims | |
| Battery | Shimano 720Wh · 720 Wh · all trims | |
| Travel F/R | 150/150 mm · all trims | |
| Frame | Carbon · all trims | |
| Fork | FOX Float 36 Performance, GRIP, E-Optimized, 150 mm | Fox 36 Performance E-Optimised 150mm |
| Shock | FOX Float DPS Performance, 230x62.5 mm | Fox Float DPS Performance |
| Headset | Acros ICR, blocklock, ZS56/ZS56 · all trims | |
| Handlebar | Husqvarna Riser 35 mm, 780 mm, 8° sweep, 20 mm rise · all trims | |
| Grips | Husqvarna MTB, Lock-on · all trims | |
| Saddle | Husqvarna MTB · all trims | |
| Seatpost | Husqvarna Pro dropper, 31.6 mm · all trims | |
| Brakes | SRAM G2 R, 4-piston hydraulic disc | SRAM G2 hydraulic, 200mm rotors |
| Rear derailleur | SRAM GX Eagle, 12-speed · all trims | |
| Crank | Shimano FC-EM900 · all trims | |
| Shifters | SRAM GX Eagle, Single Click · all trims | |
| Cassette | SRAM PG-1230, 11-50T · all trims | |
| Chain | SRAM GX Eagle · all trims | |
| Drivetrain | SRAM GX Eagle, 12-speed; Shimano FC-EM900; SRAM GX Eagle, Single Click; SRAM PG-1230, 11-50T; SRAM GX Eagle | SRAM GX Eagle 12-speed, 11-50T |
| Wheels | NEWMEN Evolution SL E.G, tubeless ready, 15x110 / 12x148 mm · all trims | |
| Tyres | — | Schwalbe Nobby Nic |
| Weight | 24 kg | 24.3 kg |
| Price | £4,399 | — |
Rides similarly
Spot a mistake?
