Light Cross LC6 2023
Carbon Light Cross XC/trail eMTB with Shimano motor (85Nm/250W)
The Husqvarna Light Cross LC6 2024 is a carbon trail eMTB sitting in the higher tier of Husqvarna's Light Cross lineup. Headline numbers: 130mm fork, 120mm rear, Shimano EP801 motor at 85Nm and a 600W peak with a 2.7kg motor mass, a 720Wh battery, 66.0 to 66.5 degree head angle and reach 428 to 513mm across S, M, L and XL. Husqvarna is the Pierer Mobility/KTM-group sister brand to GasGas and KTM; the Light Cross line shares engineering DNA with the KTM Macina Prowler family but with its own carbon frame moulds and a more trail-leaning geometry brief. With no curated Husqvarna-specific community quotes on file, this verdict draws on the gold spec and known platform behaviour.
Drive system and range. The Shimano EP801 is one of the most refined full-power motors on the market: 85Nm of torque, a 600W peak, a 2.7kg motor mass and Shimano's signature smooth-bite power delivery. Compared to the previous EP8 the 801 brings better thermal management and improved firmware mode tuning, and pairs with Shimano's well-mapped E-Tube app for personalisation. A 720Wh battery is generous for a 130/120mm trail platform: expect 1,500 to 1,800m of vertical and three to four hours of mixed trail riding in Trail/Boost modes. Battery removability is not in the gold spec: buyers should confirm with their Husqvarna dealer.
Geometry and handling. 66.0 degrees on the S, settling to 66.5 degrees on M, L and XL is on the conservative side of modern trail eMTB geometry: steeper than a Levo SL or Trek Fuel EXe and biased toward XC-leaning use. Reach steps cleanly: 428 (S), 463 (M), 488 (L), 513 (XL): a healthy 35mm jump between S and M for fit flexibility. Chainstays are a uniform 445mm and wheelbase tops out at 1270mm on XL. The package suits riders who prioritise efficient pedalling and trail/XC use over slack-and-low descent capability.
Build and value. The gold spec lists a single base trim; Husqvarna's Light Cross LC6 sits above the LC4 and below the top-tier LC7/8 variants in its catalogue, with a high-quality carbon frame, Shimano EP801 motor and the larger 720Wh battery as standard. Build kit on a higher-tier Light Cross typically pairs Fox 34/36 Performance or Factory suspension with Shimano XT 4-piston brakes and an XT 1x12 drivetrain: properly capable for the travel envelope. Standout: the 720Wh battery is generous for the segment. Questionable: the geometry is conservative versus 2025/2026 trail bike conventions.
Caveats and known gripes.
- Conservative geometry. 66.0 to 66.5 degree head angle is steep by 2025 trail eMTB standards; riders coming from a slacker bike will need to re-learn line choice on steeper descents.
- Limited UK dealer network. Husqvarna bicycles are well-distributed in Germany, Austria and Italy but thinner in the UK and US; warranty routing is via local Husqvarna powersport dealers in some markets.
- Battery removability not confirmed. Confirm at point of sale: integrated batteries impact storage and travel logistics.
- Light on community signal. The Light Cross has very limited owner reporting on the eMTB Forums community as of 2026; long-term motor and frame reliability data is yet to mature.
- Trail-not-enduro travel. 130/120mm is firmly in the XC-trail bracket; bigger hits and longer descents will ask more of the rider.
- Brand price premium. Husqvarna is a premium-positioned brand in central Europe; the Light Cross LC6 typically sits at the upper end of equivalently-specced rivals from Cube, Canyon and Whyte.
Verdict. The Light Cross LC6 is a Shimano-powered carbon trail eMTB with a generous 720Wh battery, conservative-but-honest trail geometry and the engineering credibility of the Pierer Mobility group behind it. It suits riders who want a Shimano EP801-powered carbon trail bike, who ride mostly XC, trail centres and moderate natural terrain, and who can access Husqvarna dealer support. Buyers chasing slacker geometry, enduro-grade travel or a more established eMTB community footprint should look at the Specialized Levo, Trek Fuel EXe or Whyte E-160 lineups instead. Production status: current.
| S | M | L | XL | |
| Reach | 428 mm | 463 mm | 488 mm | 513 mm |
| Stack | 607 mm | 623 mm | 636 mm | 650 mm |
| Chainstay | 445 mm | 445 mm | 445 mm | 445 mm |
| Headtube Angle | 66° | 66.5° | 66.5° | 66.5° |
| Seattube Angle (eff) | 78.6° | 78.3° | 78.2° | 78° |
| BB Drop | 23 mm | 23 mm | 23 mm | 23 mm |
| Wheelbase | 1174 mm | 1208 mm | 1239 mm | 1270 mm |
| Headtube | 130 mm | 135 mm | 140 mm | 145 mm |
| Front Centre | 729 mm | 763 mm | 794 mm | 825 mm |
| FC:RC | 1.64 | 1.71 | 1.78 | 1.85 |
Trims · 1
Light Cross LC6 £6,030 | |
| Motor | Shimano EP801 · 85 Nm |
| Battery | 720 Wh |
| Travel F/R | 130/120 mm |
| Frame | Carbon |
| Fork | RockShox Pike Select, DebonAir, Air, 130 mm, tapered |
| Shock | RockShox SIDLuxe Select+ |
| Headset | Acros ICR, blocklock, ZS56/ZS56 |
| Stem | Husqvarna 35, 0°, Ahead |
| Handlebar | Husqvarna Riser 35 mm, 780 mm, Sweep 9°, Rise 20 mm |
| Grips | Husqvarna MTB, Lock-on grips |
| Saddle | Husqvarna MTB |
| Seatpost | Husqvarna Pro, 31.6 mm, Dropper post |
| Drivetrain | SRAM X01 Eagle 12-speed |
| Wheels | 27.5" Aluminium; Husqvarna DA210F front / DA210R rear hubs |
| Weight | 23.2 kg |
| Price | £6,030 |
Rides similarly
Spot a mistake?
