Bike Finder · Giant
Giant Trance X E+
Giant
Trance X E+ 2023
DiscontinuedFull Power · TrailLegacy · 0.4/10iFreshness 0.4/10
Motor
Giant SyncDrive Pro2 · 85Nm · 250W
Battery
Giant EnergyPak 800 · 800Wh
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
From £5,499
View the Giant Trance X E+ on Giant’s site
Giant Trance X E+ 2023
From £5,499
EMTB Forums verdict
The Giant Trance X E+ (2023) was the alloy, full-power version of Giant's trail E-MTB family, sitting below the carbon Trance X Advanced E+ models. It uses an ALUXX SL-grade aluminium frame with 140mm of Maestro rear travel, a 150mm fork and a full 29in wheel setup, driven by the SyncDrive Pro2 motor (85Nm, co-developed with Yamaha) and a sizeable integrated 800Wh EnergyPak. The frame adds a UDH rear axle and is compatible with the EnergyPak Plus 250 range extender.
The UK range ran two trims off the same frame, motor and battery. The Trance X E+ 1 at £5,999 was the flagship, with a Fox 36 Float Performance fork, Fox Float X air shock, Shimano Deore XT four-piston brakes on a 220/203mm rotor set, Deore XT 12-speed shifting and a Tranz-X Rad+ travel-adjustable dropper. The Trance X E+ 2 at £5,499 stepped down to a Fox 36 Float Rhythm fork, Float Performance shock, Shimano SLX shifting with Deore four-piston brakes on 203mm rotors and a Giant Contact Switch dropper, making it the value pick.
Geometry is adjustable via a flip chip giving a slacker, lower setting (around 65.7 to 65.8 degrees head angle, 30mm BB drop) and a steeper, higher setting (66.5 degrees, 20mm BB drop). Reach on a size L runs 482mm in Low and 489mm in High, with consistent 473mm chainstays across all sizes and a 1268 to 1301mm wheelbase, giving a stable but not extreme trail position. Both trims share Maxxis Minion DHF / Dissector 2.6in tyres and a Giant Contact 35 cockpit.
This generation is now discontinued and appears at clearance pricing. It remains of interest as a relatively affordable, big-battery (800Wh) full-power 29er trail E-MTB for riders who want SyncDrive Pro2 power and long range in an alloy frame, without paying for the lighter carbon Advanced versions.
Geometry read
Size
Setting
Descending
59
A solid all-round descender (65.8° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
31
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
78
Rear-long with a planted front in L (FC:RC 1.68) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
77
Giant SyncDrive Pro2 and a steep 76° seat angle keep the weight planted over the front — a proper winch. 250W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
Battery800 Wh95 Wh above average
Motor torque85 Nm13 Nm below average
Value for money30/100from £5,499 · comparable bikes ~£4,860
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
2023 Giant Trance X E+ / E+ Elite
340 replies · 100k views · last reply 5 weeks ago
Join the discussion →
“Finally got my bike delivered this weekend after waiting a few weeks. All I can say is damn it was worth the wait. First time owning an ebike and I'm 100% happy with my decision to get the trance. Made a few changes already and have a…”
— thebradjohns · ♥ 10 · most-liked post
OWNERS’ REPORT
Giant Trance X E+ — what owners actually know
4,937 posts · 792 owners · data through May 2026
10Firmware / derestriction lockouts · typical onset: On any app/firmware update or after fitting a tuning device
8Random shut-off / cut-out (2022-24 Trance X, SyncDrive Pro2) · typical onset: A few hundred miles to 18 months
6Frame cracking at the motor mount / rocker (2022-24 Trance X) · typical onset: 3-12 months
1000 miles through a British winter, completely soaked and muddy, no trouble whatsoever on a 2020 Trance E+ 3, posted to balance a water-ingress thread
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXL
Reach447 mm462 mm489 mm517 mm
Stack601 mm605 mm614 mm624 mm
Seattube400 mm425 mm450 mm475 mm
Chainstay473 mm473 mm473 mm473 mm
Headtube Angle66.5°66.5°66.5°66.5°
Seattube Angle (eff)76.7°76.7°76.7°76.7°
Wheelbase1206 mm1237 mm1269 mm1301 mm
Headtube95 mm100 mm110 mm120 mm
Standover789 mm784 mm770 mm782 mm
Front Centre733 mm*764 mm*796 mm*828 mm*
FC:RC1.551.621.681.75
Trims · 2
£5,499
£5,999
MotorGiant SyncDrive Pro2 · 85 Nm · all trims
BatteryGiant EnergyPak 800 · 800 Wh · all trims
Travel F/R150/140 mm · all trims
FrameALUXX SL-grade Aluminium, Advanced Forged Composite linkage, 140mm Maestro Suspension System, 'Boost' 148x12 UDH rear axle, Giant EnergyPak Plus Range Extender Compatible · all trims
ForkFox 36 Float Rhythm E-Tuned, 29er, 150mm travel, 44mm offset, Grip Damper, Sweep adjust, Boost 110x15QRFox 36 Float Performance E-Tuned, 29er, 150mm travel, 44mm offset, Grip 3-position Micro Adjust damper, Kabolt-X 110
ShockFox Float Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned, recommended sag: 30%Fox Float X Performance, EVOL Large Volume sleeve, 3-Pos Lever, 185x52.5mm Trunnion mount, custom tuned, recommended sag: 30%
StemGiant Contact SL 35 · all trims
HandlebarGiant Contact 35 Trail, 35x780mm · all trims
GripsGiant Tactal Pro-E, tapered design, 135mm Ø28~30mm (S/M) 142mm Ø29~32mm (L/XL) · all trims
SaddleGiant Romero · all trims
SeatpostGiant Contact Switch, dropper, 30,9mm (S:125mm, M:150mm, L/XL:170mm)Tranz-X Rad+ 30,9mm, 30mm travel adjustable (S:120-150mm, M:140-170mm, L/XL:170-200mm)
BrakesShimano Deore, BR-M6120, 4-piston, hydraulic disc, 203mmShimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 220mm [F], 203mm [R]
Rear derailleurShimano SLX, 12-speed, Shadow+Shimano Deore XT, 12-speed, Shadow+
CrankPraxis Wave tm 36T Cold Forged 4130 premium steel chain ring 104BCD Praxis e-crank arm set (S:160, M/L:165, XL:170) Q-factor=168mm, Chainline: 55mm, Max Chainring: 38T · all trims
ShiftersShimano SLX 1x12Shimano Deore XT 1x12
CassetteShimano CS-M6100-12, 10-51T, 12-speedShimano CS-M7100-12, 10-51T, 12-speed
ChainKMC e.12 Turbo, EcoProteq, e-bike optimised · all trims
DrivetrainShimano SLX, 12-speed, Shadow+; Praxis Wave tm 36T Cold Forged 4130 premium steel chain ring 104BCD Praxis e-crank arm set (S:160, M/L:165, XL:170) Q-factor=168mm, Chainline: 55mm, Max Chainring: 38T; Shimano SLX 1x12; Shimano CS-M6100-12, 10-51T, 12-speed; KMC e.12 Turbo, EcoProteq, e-bike optimisedShimano Deore XT, 12-speed, Shadow+; Praxis Wave tm 36T Cold Forged 4130 premium steel chain ring 104BCD Praxis e-crank arm set (S:160, M/L:165, XL:170) Q-factor=168mm, Chainline: 55mm, Max Chainring: 38T; Shimano Deore XT 1x12; Shimano CS-M7100-12, 10-51T, 12-speed; KMC e.12 Turbo, EcoProteq, e-bike optimised
WheelsGiant AM30, Tubeless ready, 30mm inner width, 29" · all trims
TyresMaxxis Minion DHF 29x2.6" foldable, Tubeless, EXO+, 3C MaxxTerra [F]; Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 3C MaxxTerra [R] · all trims
Price£5,499£5,999
Rides similarly
Spot a mistake?
