A solid all-round descender (65.8° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Trance X Advanced E+ 2022
The Trance X Advanced E+ was Giant's first carbon full-power trail E-MTB, arriving for 2022 as the flagship above the alloy Trance X E+. It pairs an Advanced-grade composite frame with 140mm of Maestro rear travel and a 150mm fork on a full 29in wheel setup, and runs the full-power SyncDrive Pro motor (85Nm, co-developed with Yamaha) fed by a downtube-integrated 625Wh EnergyPak Smart battery, with a 250Wh EnergyPak Plus range extender as an option.
Two carbon trims were sold in the UK. The Advanced E+ 1 at £6,999 was the headline build, with Fox 36 Live Valve electronic fork and Float X Live Valve shock, a Shimano Deore XT 12-speed drivetrain, Shimano four-piston brakes on 203mm rotors and Giant AM alloy wheels. The Advanced E+ 2 at £5,999 kept the same carbon frame, motor and battery but stepped down to a conventional Fox 36 Float Performance fork and DPS Performance shock, a Shimano SLX 12-speed drivetrain and Shimano Deore brakes. Both rolled on Maxxis Assegai front and Dissector rear 2.6in tyres. A pricier Advanced E+ 0 with full Fox Live Valve and XT also existed for 2022 but is tracked separately.
Geometry is adjustable via a flip chip, giving a slacker, lower Low setting (around 65.7 to 65.8 degrees head angle, 30mm BB drop) and a steeper, higher High setting (66.5 degrees, 20mm BB drop). Reach on a size L runs 482mm Low to 489mm High, and chainstays are a consistent 473mm across all sizes, reflecting the full-power motor and battery packaging. This generation is now discontinued and turns up at clearance pricing.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Rear-long with a planted front in L (FC:RC 1.68) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Giant SyncDrive Pro and a steep 76° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Strong up and composed down — a do-it-all, not a specialist.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Trail bikes (from 248 bikes in the database)
| S | M | L | XL | |
| Reach | 447 mm | 462 mm | 489 mm | 517 mm |
| Stack | 601 mm | 605 mm | 614 mm | 624 mm |
| Seattube | 400 mm | 425 mm | 450 mm | 475 mm |
| Chainstay | 473 mm | 473 mm | 473 mm | 473 mm |
| Headtube Angle | 66.5° | 66.5° | 66.5° | 66.5° |
| Seattube Angle (eff) | 78° | 76.7° | 76.7° | 76.7° |
| Wheelbase | 1221 mm | 1237 mm | 1269 mm | 1301 mm |
| Headtube | 95 mm | 100 mm | 110 mm | 120 mm |
| Standover | 746 mm | 734 mm | 726 mm | 723 mm |
| Front Centre | 748 mm* | 764 mm* | 796 mm* | 828 mm* |
| FC:RC | 1.58 | 1.62 | 1.68 | 1.75 |
Trims · 2
2 £5,999 | 1 £6,999 | |
| Motor | Giant SyncDrive Pro · 85 Nm · all trims | |
| Battery | Giant EnergyPak Smart 625 · 625 Wh · all trims | |
| Travel F/R | 150/140 mm · all trims | |
| Frame | Advanced-grade composite frame, Advanced-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension system · all trims | |
| Fork | Fox 36 Float Performance, 150mm travel, 44mm offset, Grip 3-position Micro Adjust damper, Boost 110x15QR, e-optimized | Fox 36 Live Valve, 150mm travel, 44mm offset, Boost 110x15QR, electronic adaptive suspension, e-bike integrated |
| Shock | Fox DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned | Fox Float X Live Valve, 185x52.5mm Trunnion mount, electronic suspension, e-bike integrated |
| Stem | Giant Contact SL 35 · all trims | |
| Handlebar | Giant Contact 35 Trail, 35x780mm · all trims | |
| Grips | Giant Tactal Pro-E, single lock-on · all trims | |
| Saddle | Giant Romero · all trims | |
| Seatpost | Giant Contact Switch, dropper, 30.9mm (S:125, M:150, L/XL:170) · all trims | |
| Brakes | Shimano Deore, BR-M420, 4-piston, hydraulic disc, 203mm | Shimano, BR-MT520, 4-piston, hydraulic disc, 203mm |
| Rear derailleur | Shimano Deore SLX, 12-speed, Shadow+ | Shimano Deore XT, 12-speed, Shadow+ |
| Crank | Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (Q-factor 168, XS/S:160, M/L:165, XL:170) · all trims | |
| Shifters | Shimano Deore SLX 1x12 | Shimano Deore XT 1x12 |
| Cassette | Shimano HG-M6100, 10-51T, 12-speed · all trims | |
| Chain | KMC e.12 Sport, NP/NP, e-bike optimized | KMC e.12 Turbo, EcoProteq, e-bike optimized |
| Drivetrain | Shimano Deore SLX, 12-speed, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (Q-factor 168, XS/S:160, M/L:165, XL:170); Shimano Deore SLX 1x12; Shimano HG-M6100, 10-51T, 12-speed; KMC e.12 Sport, NP/NP, e-bike optimized | Shimano Deore XT, 12-speed, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (Q-factor 168, XS/S:160, M/L:165, XL:170); Shimano Deore XT 1x12; Shimano HG-M6100, 10-51T, 12-speed; KMC e.12 Turbo, EcoProteq, e-bike optimized |
| Wheels | Giant AM 29", Tubeless ready, 30mm inner width · all trims | |
| Tyres | Maxxis Assegai 29x2.6" foldable, Tubeless, EXO, 3C MaxxTerra [F]; Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 120tpi 3C [R] · all trims | |
| Price | £5,999 | £6,999 |
Rides similarly
Spot a mistake?
