Bike Finder · Giant
Giant Talon E+
Giant
Talon E+ 2025
CurrentTrail eMTBAgeing · 3.9/10iFreshness 3.9/10
Motor
Giant SyncDrive Sport · 75Nm · 250W
Battery
Giant EnergyPak Smart 430 · 430Wh
Travel F/R
100mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
21.7 kg
Price
£2,299
View the Giant Talon E+ on Giant’s site
Giant Talon E+ 2025
From £2,299
EMTB Forums verdict
The Talon E+ is Giant's entry-level aluminium hardtail eMTB, an all-new generation built around an ALUXX frame with a removable EnergyPak Smart 430Wh battery slid into a slim down tube. At £2,299 it sits at the affordable end of the eMTB market, aimed as much at fitness, commuting and gravel-track duty as it is at light trail riding.
It is sold as a single build, so there is no trim ladder to weigh up. The spec is honest rather than flashy: an SR Suntour XCM coil fork with 100mm of travel, a 9-speed Shimano Cues drivetrain, Shimano MT200 hydraulic brakes on 180mm rotors front and rear, and Maxxis Rekon 29in tyres. It is a clean, serviceable kit list at the price, with a UDH dropout leaving the door open for a drivetrain upgrade later.
Power comes from Giant's SyncDrive Sport 2 motor rated at 75Nm with a claimed 400 per cent maximum support, paired with the RideControl Dash 2 colour display and app tuning. At a claimed 21.7kg for a medium it is light for a full-power eMTB, helped by the modest 430Wh pack, which can be supplemented with an EnergyPak Plus range extender.
Geometry is upright and stable rather than aggressive: a 68-degree head angle across all four sizes, a fixed 470mm chainstay, and reach growing from 404mm in S to 452mm in XL. The 100mm fork and conservative angles point this firmly at smooth trails, towpaths and dirt roads rather than steep technical terrain.
💬 Forum discussion
Giant talon e+ wont power off display froze ? Help
9 replies · 3.7k views · last reply 37 months ago
Join the discussion →
Bike geometry diagram
SMLXL
Reach404 mm420 mm436 mm452 mm
Stack613 mm627 mm641 mm655 mm
Seattube385 mm435 mm485 mm535 mm
Chainstay470 mm470 mm470 mm470 mm
Headtube Angle68°68°68°68°
Seattube Angle (eff)78°74°74°74°
Wheelbase1144 mm1165 mm1187 mm1209 mm
Headtube100 mm115 mm130 mm145 mm
Standover723 mm753 mm788 mm808 mm
Front Centre674 mm*695 mm*717 mm*739 mm*
Trims · 1
Base
£2,299
MotorGiant SyncDrive Sport · 75 Nm
BatteryGiant EnergyPak Smart 430 · 430 Wh
Travel F/R100/? mm
FrameAluminium
ForkSR Suntour XCM ATB DS coil 29" 100mm travel 15x110 AH axle
HeadsetOverdrive 1½ - 1⅛"
StemGiant Contact
HandlebarGiant Connect TR Riser 31.8x690~750mm
GripsGiant Sole-O Grip
SaddleGiant Ergo Trail ESG
SeatpostGiant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium
BrakesShimano MT200, hydraulic disc, 180mm [F/R]; Shimano MT-200 levers
Rear derailleurShimano Cues 9-speed
CrankForged aluminium direct-mount chainring steel 36T, forged aluminium crank arms
ShiftersShimano Cues
CassetteShimano Cues, 11-41T, 9-speed
ChainKMC eGlide NP/BK, e-bike optimized
DrivetrainShimano Cues 9-speed; Forged aluminium direct-mount chainring steel 36T, forged aluminium crank arms; Shimano Cues; Shimano Cues, 11-41T, 9-speed; KMC eGlide NP/BK, e-bike optimized
WheelsGiant GX03V aluminium
TyresMaxxis Rekon 29x2.4" (Electric Blue, Meteor Storm) / Maxxis Rekon Tanwall 29x2.4" (Asphalt Green)
Weight21.7 kg
Price£2,299
Rides similarly
Spot a mistake?
