Bike Finder · Giant
Giant Fathom E+
Giant
Fathom E+ 2024
DiscontinuedTrail eMTBLegacy · 0.9/10iFreshness 0.9/10
Motor
Giant SyncDrive Sport · 75Nm · 250W
Battery
Giant EnergyPak Smart 625 · 625Wh
Travel F/R
130mm / —
Wheels
29F / 29R
Frame
Aluminium
Price
From £2,999
View the Giant Fathom E+ on Giant’s site
Giant Fathom E+ 2024
From £2,999
EMTB Forums verdict
The Giant Fathom E+ is the brand's aluminium hardtail trail e-bike, built around an ALUXX SL frame, 29-inch wheels and a 130mm fork on the flagship trim. It sits below Giant's full-suspension Trance E+ and Stance E+, aimed at riders who want assisted climbing and trail capability without the cost or complexity of rear suspension.
Two trims made up the 2024 line. The Fathom E+ 2 (RRP £3,299) is the better-equipped of the pair: it pairs the 75Nm SyncDrive Sport2 motor with a 625Wh EnergyPak battery, an SR Suntour XCR 34 coil fork, a Contact Switch dropper post and a Shimano Cues LinkGlide 1x9 drivetrain. The Fathom E+ 3 (RRP £2,999) steps down to the 70Nm SyncDrive Sport motor, a 500Wh battery, a 120mm SR Suntour XCM32 fork, a fixed seatpost and a microSHIFT Advent 1x9 transmission, so the extra spend on the E+ 2 buys more battery, a dropper and a longer-travel fork.
Geometry is consistent across both trims with a 66-degree head angle, 75-degree seat angle and long 470mm chainstays, giving a stable, climbing-focused rather than aggressive trail character. Sizing runs S to XXL on the E+ 2 and S to XL on the E+ 3, with reach from 416mm to 486mm.
This is a discontinued 2024 model. Giant carried the Fathom E+ nameplate forward into later model years with the SyncDrive Sport platform, so current stock is run-out pricing on the outgoing generation.
💬 Forum discussion
Giant Fathom e+2 2020 + Speedbox help please
14 replies · 6.2k views · last reply 63 months ago
Join the discussion →
Bike geometry diagram
SMLXLXXL
Reach416 mm434 mm451 mm469 mm486 mm
Stack647 mm656 mm665 mm675 mm684 mm
Seattube380 mm420 mm460 mm495 mm530 mm
Chainstay470 mm470 mm470 mm470 mm470 mm
Headtube Angle66°66°66°66°66°
Seattube Angle (eff)75°75°75°75°75°
Wheelbase1197 mm1219 mm1241 mm1262 mm1284 mm
Headtube110 mm120 mm130 mm140 mm150 mm
Standover730 mm757 mm750 mm773 mm776 mm
Front Centre727 mm*749 mm*771 mm*792 mm*814 mm*
Trims · 2
Fathom E+ 3
£2,999
Fathom E+ 2
£3,299
MotorGiant SyncDrive Sport · 75 Nm · all trims
BatteryGiant EnergyPak Smart 625 · 625 Wh · all trims
Travel F/R130/? mm · all trims
FrameALUXX aluminiumALUXX SL aluminium
ForkSR Suntour XCM32 NLO DS 15AH2 29, 120mm travel, tapered steerer, lockoutSR Suntour XCR 34 Boost 2-CR Coil 29, 130mm travel, Tapered 1.125"-1.5" steerer, 15AH2-110 thru-axle
HeadsetOverdrive 1.5 - 1.125" head tubeOverdrive 1.5" - 1.8" head tube
StemGiant Contact 31.8 alloyGiant Contact
HandlebarGiant Connect TR Riser 31.8 alloy 750mm [S], 780mm [M-XXL]Giant Connect TR Riser 31.8mm
GripsGiant Tactal single lock-onGiant Tactal Pro, single lock-on
SaddleGiant SportGiant Ergo Contact Trail
SeatpostGiant 30.9mm, 2-bolt Micro Adjustable, Forged AluminiumGiant Contact Switch Adj, adjustable dropper, 30.9mm
BrakesTektro HD-M285, hydraulic disc · all trims
Rear derailleurmicroSHIFT ADVENT, 9-speedShimano Cues LinkGlide
CrankFSA MegaTooth direct-mount 1X steel 36T alloy crank armFSA MegaTooth direct-mount 1X steel 36T FSA Comet E-Bike crank arm
ShiftersmicroSHIFT ADVENT e-optimizedShimano Cues LinkGlide 1x9
CassettemicroSHIFT ADVENT, 11-42T, 9-speed, e-optimisedShimano Cues, LinkGlide, CS-LG300-9, 11-46T, 9-speed
ChainKMC e.9 Sport, e-bike optimisedKMC eGlide NP/BK, e-bike optimised
DrivetrainmicroSHIFT ADVENT, 9-speed; FSA MegaTooth direct-mount 1X steel 36T alloy crank arm; microSHIFT ADVENT e-optimized; microSHIFT ADVENT, 11-42T, 9-speed, e-optimised; KMC e.9 Sport, e-bike optimisedShimano Cues LinkGlide; FSA MegaTooth direct-mount 1X steel 36T FSA Comet E-Bike crank arm; Shimano Cues LinkGlide 1x9; Shimano Cues, LinkGlide, CS-LG300-9, 11-46T, 9-speed; KMC eGlide NP/BK, e-bike optimised
WheelsGiant XCT 29 Tubeless Ready 25mm e-bike optimised · all trims
TyresMaxxis Rekon 29x2.4" Wire Bead 60TPI · all trims
Price£2,999£3,299
Rides similarly
Spot a mistake?
