Bike Finder · GasGas
GasGas G Enduro
GasGas
G Enduro 2024
CurrentEnduro eMTBAgeing · 3/10iFreshness 3/10
Travel F/R
170/160mm
Wheels
29F / 29R
Frame
Aluminium
Weight
25.5 kg
Price
From £3,999
View the GasGas G Enduro on GasGas’s site
GasGas G Enduro 2024
From £3,999
EMTB Forums verdict
The GasGas G Enduro is the brand's aluminium 29er enduro e-bike, built around a Yamaha PW-X motor and a 720Wh Simplo battery (630Wh on the entry build) with 170mm up front and 160mm at the rear.
Three builds are offered. The 1.0 is the budget option, and notably uses a different, slightly steeper frame setup with a coil RockShox 35 fork, 160mm front travel, a smaller 630Wh battery and the 80Nm Yamaha PW-X2 motor, paired with a Shimano Deore 1x10 drivetrain and Formula Cura 4 brakes. The 2.0 steps up to a 170mm RockShox Domain air fork, 720Wh battery and 85Nm PW-X3, keeping the Deore 1x10 kit but moving to Tektro four-piston brakes. The 3.0 is the flagship, with a FOX Float 38 Factory fork and Float X Factory shock, SRAM GX Eagle 1x12, SRAM Code R brakes and NEWMEN wheels on Schwalbe Hans Dampf tyres.
The 2.0 and 3.0 share a properly slack 64-degree head angle and a low 353mm bottom bracket, giving them a stable, descent-focused character, while the 1.0's separate geometry is taller and a touch steeper at 66 to 68 degrees. Reach figures are conservative by current standards, running 445mm to 485mm across S to L on the 2.0/3.0 frame.
💬 Forum discussion
2.1k replies · 221.2k views · last reply today
Join the discussion →
“1300mm wheelbase does look long for the given reach number in size large (485mm) and head angle. According to the geo chart the front centre *should* be 860mm in large, with the 440mm chainstay. It could be a fair bit slacker than in…”
— Rob Rides EMTB · ♥ 20 · most-liked post
Bike geometry diagram
SMLXL
Reach445 mm460 mm480 mm500 mm
Stack620 mm621 mm639 mm639 mm
Seattube410 mm430 mm470 mm510 mm
Chainstay460 mm475 mm475 mm475 mm
Headtube Angle64°68°66°66°
Seattube Angle (eff)72°72.5°72.5°72.5°
Wheelbase1241 mm1260 mm1288 mm1308 mm
Headtube100 mm120 mm140 mm140 mm
BB Height353 mm369 mm369 mm369 mm
Front Centre781 mm*785 mm*813 mm*833 mm*
Trims · 3
1.0
£3,999
3.0
£5,299
2.0
MotorYamaha PW-X2 · 85 NmYamaha PW-X3 · 85 NmYamaha PW-X3 · 85 Nm
BatterySimplo 720Wh · 720 Wh · all trims
Travel F/R170/160 mm · all trims
FrameAluminium · all trims
ForkRockShox 35 Silver R, Coil, 160 mm, taperedFOX Float 38 Factory, Grip 2, E-Optimized, Air, 170 mm, taperedRockShox Domain R, DebonAir, Air, 170 mm, tapered
ShockRockShox Deluxe Select, Air, 230x65 mm (160 mm travel)FOX Float X Factory, Air, 230x65 mm (160 mm travel)RockShox Deluxe Select, Air, 230x65 mm (160 mm travel)
HeadsetGASGAS ZS44/ZS56FSA Orbit ZS56/ZS56FSA Orbit ZS56/ZS56
StemGASGAS, 31.8 mm, 0 deg, AheadGASGAS, 35 mm, 0 deg, AheadGASGAS, 35 mm, 0 deg, Ahead
HandlebarGASGAS Riser, 31.8 mm, 780 mm, 9 deg sweep, 15 mm riseGASGAS Riser, 35 mm, 780 mm, 9 deg sweep, 20 mm riseGASGAS Riser, 35 mm, 780 mm, 9 deg sweep, 20 mm rise
GripsGASGAS MTB, lock-on grips · all trims
SaddleGASGAS MTB · all trims
SeatpostGASGAS dropper post, 31.6 mmGASGAS dropper post, 34.9 mmGASGAS dropper post, 34.9 mm
BrakesFormula Cura 4, 4-piston hydraulic disc (front and rear)SRAM Code R, 4-piston hydraulic disc (front and rear)Tektro HD-M745, 4-piston hydraulic disc (front and rear)
Rear derailleurShimano Deore LG, RD-M5130, Shadow Plus, 10-speedSRAM GX Eagle, 12-speedShimano Deore LG, RD-M5130, Shadow Plus, 10-speed
CrankGASGAS, Narrow Wide, 38 TSRAM X-Sync Eagle, 38 TGASGAS, Narrow Wide, 38 T
ShiftersShimano Deore, SL-M5130, Rapidfire PlusSRAM GX Eagle, single clickShimano Deore, SL-M5130, Rapidfire Plus
CassetteShimano CS-LG400, 11-43 TSRAM PG-1230, 11-50 TShimano CS-LG400, 11-43 T
ChainShimano CN-LG500SRAM GX EagleShimano CN-LG500
DrivetrainShimano Deore LG, RD-M5130, Shadow Plus, 10-speed; GASGAS, Narrow Wide, 38 T; Shimano Deore, SL-M5130, Rapidfire Plus; Shimano CS-LG400, 11-43 T; Shimano CN-LG500SRAM GX Eagle, 12-speed; SRAM X-Sync Eagle, 38 T; SRAM GX Eagle, single click; SRAM PG-1230, 11-50 T; SRAM GX EagleShimano Deore LG, RD-M5130, Shadow Plus, 10-speed; GASGAS, Narrow Wide, 38 T; Shimano Deore, SL-M5130, Rapidfire Plus; Shimano CS-LG400, 11-43 T; Shimano CN-LG500
WheelsMach 1 TRUCKY 30, with eyelets, tubeless ready; GASGAS DA210F/DA210R hubs, 15x110 / 12x148 mm thru axleNEWMEN Evolution A.30, tubeless ready, center lock, 15x110 / 12x148 mm thru axleMach 1 TRUCKY 30, with eyelets, tubeless ready; GASGAS DA210F/DA210R hubs, 15x110 / 12x148 mm thru axle
TyresContinental Trail King, 60-622, 29 x 2.4Schwalbe Hans Dampf, Evolution, 60-622, 29 x 2.35, tubeless readyContinental Trail King, 60-622, 29 x 2.4
Weight26.3 kg25.5 kg
Price£3,999£5,299
Rides similarly
Spot a mistake?
