G Cross Country 2026
The GasGas G Cross Country is an entry-level hardtail eMTB range built around Yamaha motors and an alloy 6061 frame. It is pitched squarely at riders building confidence on the trail rather than seasoned enduro hands, with cross-country geometry, a 67 degree head angle on the 29in models and modest 120mm forks.
The 3.0 is the pick of the range: a Yamaha PW-X3 motor at 85Nm, a 630Wh integrated Simplo battery, a RockShox 35 Silver TK fork and a 12-speed SRAM SX Eagle drivetrain, all for the same 2,699 pounds as the lesser 2.0. The 2.0 drops to a PW-ST motor at 70Nm with a coil SR Suntour fork and a 9-speed Tektro groupset, so it is hard to see why anyone would choose it over the 3.0 at identical money.
The 1.0 is a different bike: 27.5in wheels, a 50Nm PW-CE motor, a smaller 400Wh external Yamaha battery and an 8-speed setup, aimed at smaller or first-time riders at 1,599 pounds. Across the range these are basic alloy hardtails with own-brand cockpit kit and 2-piston brakes, so expectations should be set accordingly.
| S | M | L | XL | |
| Reach | 400 mm | 420 mm | 440 mm | 460 mm |
| Stack | 626 mm | 630 mm | 636 mm | 665 mm |
| Seattube | 400 mm | 450 mm | 500 mm | 550 mm |
| Chainstay | 465 mm | 465 mm | 465 mm | 475 mm |
| Headtube Angle | 69° | 69° | 69° | 67° |
| Seattube Angle (eff) | 74° | 74° | 74° | 74° |
| Wheelbase | 1136 mm | 1156 mm | 1176 mm | 1233 mm |
| Headtube | 120 mm | 125 mm | 130 mm | 140 mm |
| BB Height | — | 319 mm | 319 mm | 319 mm |
| Front Centre | 671 mm* | 691 mm* | 711 mm* | 758 mm* |
Trims · 3
1.0 £1,599 | 2.0 £2,699 | 3.0 £2,699 | |
| Motor | Yamaha PW-CE · 85 Nm | Yamaha PW-ST · 85 Nm | Yamaha PW-X3 · 85 Nm |
| Battery | Simplo 630 · 630 Wh · all trims | ||
| Travel F/R | 120/? mm · all trims | ||
| Frame | Alloy 6061 · all trims | ||
| Fork | SR SUNTOUR XCT30, Coil, 100 mm | SR SUNTOUR XCM32 NLO, Coil, 120 mm, tapered | RockShox 35 Silver TK, Solo Air, Air, 120 mm, tapered |
| Headset | GASGAS ZS44/ZS56 · all trims | ||
| Stem | GASGAS 31,8, 7 °, Ahead · all trims | ||
| Handlebar | GASGAS Riser 31.8 mm, 720 mm, Sweep: 6 °, Rise: 15 mm · all trims | ||
| Grips | GASGAS MTB, Lock-on grips · all trims | ||
| Saddle | GASGAS MTB · all trims | ||
| Seatpost | GASGAS, 31.6 mm, 350 mm, Patent · all trims | ||
| Brakes | Tektro HD-M275, 2-piston, Hydraulic disc brake | Tektro HD-M275, 2-piston, Hydraulic disc brake | SRAM Level T, 2-piston, Hydraulic disc brake |
| Rear derailleur | Tektro RD-T350, 8-S | Tektro RD-T350, 9-S | SRAM SX Eagle, 12-S |
| Crank | GASGAS EC40, Aluminum forged, JIS | GASGAS EC40, Aluminum forged, JIS | GASGAS EC40, Aluminum forged, ISIS |
| Shifters | Tektro SL-M330R | Tektro SL-M350R | SRAM SX Eagle, Single Click |
| Cassette | Tektro CS-M330, 11-42 T | Tektro CS-M350, 11-46 T | SRAM PG-1210, 11-50 T |
| Chain | KMC Z8 | KMC e9S | SRAM SX Eagle |
| Drivetrain | Tektro RD-T350, 8-S; GASGAS EC40, Aluminum forged, JIS; Tektro SL-M330R; Tektro CS-M330, 11-42 T; KMC Z8 | Tektro RD-T350, 9-S; GASGAS EC40, Aluminum forged, JIS; Tektro SL-M350R; Tektro CS-M350, 11-46 T; KMC e9S | SRAM SX Eagle, 12-S; GASGAS EC40, Aluminum forged, ISIS; SRAM SX Eagle, Single Click; SRAM PG-1210, 11-50 T; SRAM SX Eagle |
| Wheels | Mach 1 TRAXX, With eyelets, Tubeless ready | Mach 1 TRAXX, With eyelets | Mach 1 TRAXX, With eyelets |
| Tyres | Mitas Ocelot, 27.5 x 2.35 | Continental Cross King, 58-622, 29 x 2.3 | Continental Cross King, 58-622, 29 x 2.3 |
| Weight | 21.9 kg | 23.9 kg | 23.2 kg |
| Price | £1,599 | £2,699 | £2,699 |
Rides similarly
Spot a mistake?
