Bike Finder · Forbidden
Forbidden Druid E
Forbidden
Druid E 2026
CurrentLightweight eMTBCurrent · 8/10iFreshness 8/10
Built to get you to the top fast, then reward you on the way back down
Motor
Avinox M2S · 150Nm · 1300W
Battery
Avinox FP800 · 800Wh
Travel F/R
160/150mm
Wheels
29F/27.5R
Frame
Full carbon
Price
From £6,599
View the Forbidden Druid E on Forbidden’s site
Forbidden Druid E 2026
From £6,599
EMTB Forums verdict
The Forbidden Druid E 2026 is the Canadian brand's first electric mountain bike, built on a high-modulus carbon frame with Forbidden's signature Trifecta V3 high-pivot idler suspension. It runs the DJI Avinox M2S motor (150 Nm, 250 W rated, 1,500 W peak, 2.63 kg) with the 800 Wh Avinox FP800 battery in the Core trim variants and 600 Wh in the SL. Travel is 160 mm front and 150 mm rear, head angle 64.0°, claimed weight 23.4 kg, and the UK base price for the Druid E is £10,799. @Chairman called it "a weapon" after riding Rotorua, and Pinkbike's group test put the Druid on top "almost everywhere" per @Zero71.
Drive system and range. The Avinox M2S is the headline-grabbing motor of 2025-2026, offering 150 Nm torque and 1,500 W peak — comfortably the most powerful production unit on the market. Forbidden integrates the 800 Wh FP800 pack into the frame, which is non-removable in the Core spec. @Chairman describes the motor as "smooth power delivery with unlimited feel and good range". Expect 1,200-1,600 m of climbing on a charge depending on assist mode. The high-pivot idler does eat a small amount of efficiency compared to a conventional Horst-link layout, but the trade-off shows up in how the suspension feels on big square-edge hits.
Geometry and handling. A consistent 64.0° head angle across all four sizes is paired with size-specific chainstays that grow from 443 mm on S1 to 482 mm on S4 — a Forbidden trademark that genuinely keeps weight distribution balanced for taller riders. Reach progresses S1 430 mm, S2 447 mm, S3 467 mm, S4 487 mm. Wheelbase stretches 1,209-1,319 mm. Mullet 29/27.5 wheels with UDH dropouts. @Astro66 sums up the handling character: "Druid better on chunk and enduro. The HP wheel moves up and away from the bump it strikes. So the HP will feel smoother on big rear wheel hits." @Zero71 adds that the wheelbase "grows under heavy suspension compression where it matters", which is the high-pivot suspension's signature advantage.
Build and value. Forbidden offers five trims globally. The T1 Vitalogy at €12,700 (22.8 kg) sits at the top with Fox Podium Factory fork, Fox Float X Factory shock and SRAM Maven Ultimate brakes. T2 Purple Haze at €10,299 substitutes Fox 36 Factory Grip X2. T3 EVOO and T4 Sandstorm step down to RockShox Lyrik / Super Deluxe Select forks and SRAM Maven Silver or DB4 brakes respectively, with the T4 entry at €6,599 representing the cheapest route into Avinox M2S power on the market. All trims run SRAM Eagle Transmission.
Community-verified strengths. @Chairman rates the Avinox M2S as "smooth power delivery with unlimited feel and good range" after a full-battery ride in Rotorua. @Zero71 notes "Pinkbike did a group test that saw the Druid come out on top almost everywhere — cornering, slow tech climbs, fast stuff". @N.i.c.k. took delivery of an S3 Core in August 2025 and has built it up with Maven Ultimate brakes, Schwalbe Radial tyres and Ergon GA2 grips, with no reliability flags reported.
Caveats and known gripes. @Chairman flags repeated SRAM Maven brake bleed issues from factory: "Three S-Works owners each needed 2-3 bleeds before Mavens settled properly". @DToX reports US delivery delays of more than two months on his first-batch order, although bikes did eventually ship. @Candid notes the Druid E manual restricts the bike to jumps under 1.2 m — Cat 4 territory — so genuine freeride and DH use is officially out. The integrated 800 Wh battery limits long-day flexibility.
Verdict. The Druid E is for the rider who wants the most powerful motor on the market wrapped in Forbidden's high-pivot suspension and size-specific geometry — properly serious chunky trail and enduro performance. It is not for riders who hate non-removable batteries, need a deep service network, or want a true freeride/DH-rated platform. Production status is current, and orders are shipping across Europe and North America from late 2025.
💬 Forum discussion
2.3k replies · 306.1k views · last reply yesterday
Join the discussion →
“Been following this thread from the start so it seems only right to add my 2 cents. Picked up my S3 corE 1 on August 23rd from the Trailhead in Shrewsbury. Got the deposit down early (mid April) so my bike was on the first delivery. So…”
— N.i.c.k. · ♥ 20 · most-liked post
OWNERS’ REPORT
Forbidden Druid CorE / Dreadnought E — what owners actually know
2,675 posts · 248 owners · data through Jun 2026
22Delivery and availability saga (Apr 2025 orders, rolling slips) · typical onset: Order placement to delivery: 4.5 to 9+ months depending on region and drop.
5Avinox motor-level events on Druids (the counts live in the Avinox M1 report) · typical onset: Rattle from day 1 where present; failures isolated, first 10 rides to 3 months.
5Launch-spec component complaints: SRAM Maven bleed/bite, Fox Podium leaks · typical onset: First rides to first month.
Zero frame failures, zero swingarm cracks, zero battery failures in ~9 months of owner reports across ~25 identified owners.
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Frame
High-Modulus carbon fibre frame, Trifecta V3 high-pivot four-bar suspension with idler and carbon rocker link, mixed-wheel 29/27.5 geometry, 600Wh or 800Wh integrated Avinox battery, UDH dropouts.
Bike geometry diagram
S1S2S3S4
Reach430 mm447 mm467 mm487 mm
Stack628 mm649 mm662 mm676 mm
Chainstay443 mm456 mm469 mm482 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1209 mm1250 mm1284 mm1319 mm
Front Centre766 mm794 mm815 mm837 mm
Trims · 4
T4
£6,599
T1
£10,799
T2
T3
MotorAvinox M2S · 150 Nm · all trims
BatteryAvinox FP800 · 800 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
ForkRockShox Lyrik 160mm Delta RCFox Podium Factory 160mm Grip X2Fox 36 Factory 160mm Grip X2RockShox Lyrik Select+ 160mm Charger 3.2
ShockRockShox Super Deluxe 210x55mm LinearXLFox Float X Factory 210x55mm EvolFox Float X Factory 210x55mm EvolRockShox Super Deluxe Select+ 210x55mm LinearXL
HeadsetFSA Orbit ZS ZS44|ZS56 | Sealed Cartridge Bearings | 6000 Series Alloy Cups And Materials | Sealed Steel Crown Race · all trims
StemForbidden Stem 40mmOneUp Stem 40mmOneUp Forged 42mmForbidden Forged 40mm
HandlebarForbidden Alloy 800mmOneUp Alloy 800mmOneUp Alloy 800mmForbidden Alloy 800mm
GripsForbidden 128mm length | Single Sided Lock-On | Black · all trims
SaddleForbidden 143mmFizik Terra Aidon X5 145mmFizik Terra Aidon X5 145mmForbidden 143mm
SeatpostTranzX Reverse 31.6mmOneUp Dropper Post V3TranzX Reverse 31.6mmTranzX Reverse 31.6mm
BrakesSRAM DB4 BaseSRAM Maven - UltimateSRAM Maven - SilverSRAM Maven Base
Rear derailleurSRAM Eagle 70 HangerlessSRAM X0 T-Type HangerlessSRAM GX AXS HangerlessSRAM Eagle 90 Hangerless
CrankPraxis Type 7 150mmSRAM X0 E 150mmPraxis Alloy E-Cranks 150mmPraxis Alloy E-Cranks 150mm
ShiftersSRAM Eagle 70 Two-buttonSRAM Pod Rocker AXSSRAM Pod Rocker AXSSRAM Eagle 90 Two-button
CassetteSRAM XS-1270 12-speed HGSRAM XS-1295 12-speedSRAM XS-1275 12-speedSRAM XS-1270 12-speed HG
ChainSRAM Eagle 70 T-Type 12-speedSRAM X0 T-Type 12-speedSRAM GX T-Type 12-speedSRAM Eagle 70 T-Type 12-speed
DrivetrainSRAM Eagle 70SRAM X0 T-TypeSRAM GX AXSSRAM Eagle 90
WheelsCrank Brothers Alloy 1.0, 31.5mm internalCrankbrothers Synthesis Carbon Enduro, 31.5mm internalCrankbrothers Alloy 2.0, 31.5mm internalCrank Brothers Alloy 1.0, 31.5mm internal
TyresFront: Maxxis High Roller 3 29 x 2.4; Rear: Maxxis DHRII 27.5 x 2.5 · all trims
Price£6,599£10,799
Rides similarly
Spot a mistake?
