Bike Finder · Focus
Focus VAM² SL
Focus
VAM² SL 2026
CurrentLightweight · Cross-CountryMature · 6/10iFreshness 6/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy 430 · 430Wh
Travel F/R
130/125mm
Wheels
29F / 29R
Frame
Full carbon
Weight
16.3 kg
Price
From £5,999
View the Focus VAM² SL on Focus’s site
Focus VAM² SL 2026
From £5,999
EMTB Forums verdict
The VAM² SL is Focus's lightweight trail e-MTB, built around a MAX carbon frame with 130mm up front and 125mm out back via the F.O.L.D. GEN3 flex-pivot rear end. Power comes from the Fazua Ride 60 system: 60Nm of torque, 450W peak, and a 430Wh battery integrated into the down tube, with an optional 210Wh range extender. It runs full 29in wheels and a two-position angle headset that switches the head angle between 66.5 and 65.5 degrees.
Four builds span a wide price spread. The flagship 9.0 at GBP 10,999 is a featherweight at a claimed 16.3kg, with FOX 34 Factory fork, SRAM X0 Transmission wireless shifting, SRAM Level Ultimate brakes and carbon Mavic Crossmax wheels. The 9.9 (GBP 8,999, 17.6kg) swaps to Shimano XT mechanical and DT Swiss alloy wheels, the 9.8 (GBP 6,999, 18.4kg) runs a FOX 34 Rhythm and Magura brakes, and the alloy-cockpit 8.7 (GBP 5,999, 19.1kg) opens the range on an SR Suntour Raidon fork and Shimano Deore.
Geometry is moderate trail rather than aggressive enduro: a 66.5 degree head angle in the default steep setting, 75.5 degree seat angle, 440mm chainstays across all sizes and reach from 420mm to 505mm over four sizes (S to XL). The pairing of a sub-17kg flagship weight with full-power-style 29in trail geometry positions this as a downcountry-leaning light assist bike rather than a heavy hitter.
Geometry read
Size
Descending
53
A solid all-round descender (66.5° head angle, 125mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
98
Short 440mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
97
Rear-long with a planted front in L (FC:RC 1.77) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
67
Climbs well — a 75.5° seat keeps the front planted. 450W of peak power and 60Nm of torque.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Lightweight · Cross-Country bikes (from 63 bikes in the database)
Weight16.3 kg2.3 kg lighter than average
Battery430 Whabout average capacity
Motor torque60 Nmabout average torque
Value for money59/100from £5,999 · most Fazua Ride 60 bikes ~£6,360
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
Bike geometry diagram
SMLXL
Reach420 mm450 mm475 mm505 mm
Stack602 mm602 mm620 mm639 mm
Seattube390 mm420 mm440 mm460 mm
Chainstay440 mm440 mm440 mm440 mm
Headtube Angle66.5°66.5°66.5°66.5°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1166 mm1185 mm1218 mm1256 mm
Headtube100 mm100 mm120 mm140 mm
Front Centre726 mm*745 mm*778 mm*816 mm*
FC:RC1.651.691.771.85
Trims · 4
8.7
£5,999
9.8
£6,999
9.9
£8,999
9.0
£10,999
MotorFazua Ride 60 · 60 Nm · all trims
BatteryFazua Energy 430 · 430 Wh · all trims
Travel F/R130/125 mm · all trims
FrameMAX carbon frame (9-series carbon) · all trims
ForkSR Suntour Raidon 34, 110x15 mm, 44 mm rake, 130 mm travelFOX 34 Float Rhythm 29, 110x15 mm, 51 mm rake, 130 mm travelFOX 34 Float Performance Elite 29, 110x15 mm, 51 mm rake, 130 mm travelFOX 34 Float Factory 29, 110x15 mm, 51 mm rake, 130 mm travel (approved up to 140 mm)
ShockRockShox Deluxe Select+, 210/50 mmFOX Float DPS, 210/50 mmFOX Float Performance, 2-position lever, 210/50 mmFOX Float Factory, 2-position lever, 210/50 mm
HeadsetACROS ZS56/ZS56 (ICR), FOCUS C.I.S. Integrated, 1.5/1.5 inch angle headsetACROS ZS56/ZS56 (ICR), FOCUS C.I.S. IntegratedACROS ZS56/ZS56 (ICR), FOCUS C.I.S. IntegratedACROS ZS56/ZS56 (ICR), FOCUS C.I.S. Integrated
StemFOCUS C.I.S. 50 mm, 0 degree, 35 mm clamp, aluminiumFOCUS C.I.S. 50 mm, 0 degree, 35 mm clamp, aluminiumFOCUS C.I.S. One Piece SL Cockpit, 50 mmFOCUS C.I.S. One Piece SL Cockpit, 50 mm (also available 40 mm)
HandlebarAluminium, 800 mm, 30 mm rise, 9 degree backsweepAluminium, 800 mm, 30 mm rise, 9 degree backsweepFOCUS C.I.S. One Piece SL Cockpit, 800 mm, 25 mm riseFOCUS C.I.S. One Piece SL Cockpit, 800 mm, 25 mm rise
GripsVP VPG-122A · all trims
Saddlefi'zi:k Taigafi'zi:k Taigafi'zi:k TaigaPrologo Proxim W850 Nack
SeatpostPost Moderne dropper post PM-MT171, 31.6 mmPost Moderne dropper post PM-MT171, 31.6 mmPost Moderne dropper post PM-MT171, 31.6 mmFOX Transfer SL Factory, 31.6 mm
BrakesMagura MT Trail, 4-piston front / 2-piston rearMagura MT Trail, 4-piston front / 2-piston rearShimano XT M8120, 4-piston (front and rear)SRAM Level Ultimate Stealth, 4-piston (front and rear)
Rear derailleurShimano Deore M6100, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speedSRAM X0 Eagle Transmission, 12-speed
CrankSamox EC38 ISIS, 32T chainringRotor eKAPIC RF Link 29, 32T chainringRotor eKAPIC RF Link 29, 32T chainringRotor eKAPIC RF Link 29, 34T chainring
ShiftersShimano Deore M6100, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speedSRAM AXS POD Ultimate
CassetteShimano Deore CS-M6100, 10-51, 12-speedShimano SLX CS-M7100, 10-51, 12-speedShimano Deore XT M8100, 10-51, 12-speedSRAM XS-1295, 10-52, 12-speed
ChainShimano Deore CN-M6100, 12-speedShimano Deore CN-M6100, 12-speedShimano SLX CN-M7100, 12-speedSRAM XO1, 12-speed
DrivetrainShimano Deore M6100, 12-speed; Samox EC38 ISIS, 32T chainring; Shimano Deore M6100, 12-speed; Shimano Deore CS-M6100, 10-51, 12-speed; Shimano Deore CN-M6100, 12-speedShimano Deore XT M8100, 12-speed; Rotor eKAPIC RF Link 29, 32T chainring; Shimano Deore XT M8100, 12-speed; Shimano SLX CS-M7100, 10-51, 12-speed; Shimano Deore CN-M6100, 12-speedShimano Deore XT M8100, 12-speed; Rotor eKAPIC RF Link 29, 32T chainring; Shimano Deore XT M8100, 12-speed; Shimano Deore XT M8100, 10-51, 12-speed; Shimano SLX CN-M7100, 12-speedSRAM X0 Eagle Transmission, 12-speed; Rotor eKAPIC RF Link 29, 34T chainring; SRAM AXS POD Ultimate; SRAM XS-1295, 10-52, 12-speed; SRAM XO1, 12-speed
WheelsRaceFace ARC27, 622-27, 32H; Shimano MT410 hubs (15x110 mm front / 12x148 mm rear)RaceFace ARC27, 622-27, 32H; Novatec D041 front hub / DT Swiss 370 Hybrid rear hub, 12x148 mmDT Swiss HX1700 LS, 30-622, 110x15 mm / 12x148 mmMavic Crossmax XL R 29, carbon, 622-30
Tyres(F) Maxxis Dissector, TR EXO, 29x2.4 / (R) Maxxis Rekon MAX, EXO, 29x2.4(F) Maxxis Dissector, 2.4 EXO, 29x2.4 / (R) Maxxis Rekon, 29x2.4(F) Schwalbe Nobby Nic 2.4 SuperGround SpeedGrip / (R) Schwalbe Wicked Will 2.4 SuperGround SpeedGrip(F) Schwalbe Nobby Nic 2.4 SuperGround SpeedGrip / (R) Schwalbe Wicked Will 2.4 SuperGround SpeedGrip
Weight19.1 kg18.4 kg17.6 kg16.3 kg
Price£5,999£6,999£8,999£10,999
Rides similarly
Spot a mistake?
