Bike Finder · Focus
Focus Thron²
Focus
Thron² 2022
DiscontinuedFull Power · Cross-CountryLegacy · 1/10iFreshness 1/10
Straightforward alloy trail bike for relaxed rides and daily use
Travel F/R
130/130mm
Wheels
29F / 29R
Frame
Aluminium
Weight
25.4 kg
Price
£4,199
View the Focus Thron² on Focus’s site
Focus Thron² 2022
From £4,199
EMTB Forums verdict
The 2022 Focus Thron² was the German brand's aluminium trail eMTB, built around 130 mm of travel front and rear with Focus's F.O.L.D. linkage and 29in wheels. Every trim ran the Bosch Performance Line CX Gen 4 motor with 85 Nm of torque, with the down tube battery removable for charging. It is now discontinued.
The range split clearly by budget. The 6.7 and the equipped 6.7 EQP and 6.8 EQP trims paired a 625 Wh PowerTube with the simple Bosch Purion display and SR Suntour suspension, mixing Shimano Deore 11-speed (6.7 trims) or SLX 12-speed (6.8 EQP) gearing. The flagship 6.9 stepped up to the 750 Wh Smart System battery with the Kiox 300 display, a FOX 34 Float Rhythm fork and FOX Float DPS shock, Shimano XT 12-speed shifting and DT Swiss H1900 wheels.
Geometry was moderate and tour-friendly rather than aggressive: a 66.8 degree head angle and 415 to 470 mm reach across S to XL on the 6.7 and EQP builds, with the 6.9 a touch slacker at 66 degrees and longer in reach. Claimed weights sat around 25.4 to 26.6 kg. The EQP versions added a rack, mudguards, lights and a stand for commuting and bikepacking duty.
Note prices: the 6.7 and 6.7 EQP both carried a UK RRP of £4,199, the EQP being the equipped touring build with a 120 mm fork, lighter tyres, a rack, mudguards, lights and a stand rather than a higher price. The 6.8 EQP and 6.9 GBP figures were not captured, so their native EUR prices (4,499 EUR and 6,299 EUR) are recorded instead.
Geometry read
Size
Descending
54
A solid all-round descender (66.8° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
48
Size balance
79
Rear-long with a planted front in L (FC:RC 1.69) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
73
Bosch Performance Line CX Gen 4 and a steep 74.5° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
Weight25.4 kg1.7 kg heavier than average
Battery625 Wh61 Wh below average
Motor torque85 Nmabout average torque
Value for money20/100from £4,199 · most Bosch Performance Line CX Gen 4 bikes ~£3,499
Bike geometry diagram
SMLXL
Reach415 mm430 mm450 mm470 mm
Stack609 mm623 mm639 mm653 mm
Seattube400 mm440 mm470 mm485 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle66.8°66.8°66.8°66.8°
Seattube Angle (eff)74.5°74.5°74.5°74.5°
Wheelbase1175 mm1196 mm1223 mm1249 mm
Headtube115 mm130 mm147 mm163 mm
Front Centre720 mm*741 mm*768 mm*794 mm*
FC:RC1.581.631.691.75
Trims · 4
6.7
£4,199
6.7 EQP
£4,199
6.8 EQP
€4,499
6.9
€6,299
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 625 · 625 Wh · all trims
Travel F/R130/130 mm · all trims
FrameAluminium · all trims
ForkSR Suntour Zeron 35 Air LOR, 110x15 mmSR Suntour XCR 34 Air, LOR, 110x15 mm (120 mm travel)SR Suntour XCR 34 Air, LOR, 110x15 mm, 120 mm travelFOX 34 Float Rhythm 29, E-Bike, Grip Remote, 110x15 mm, 46 mm rake
ShockSR Suntour EDGE LOR, 190/45 mm, hardware: 25,0 x 8 mmSR Suntour EDGE LOR, 190/45 mm, hardware: 25,0 x 8 mmSR Suntour Edge LOR, 190/45 mm, hardware: 25,0 x 8 mm, custom tuneFOX Float DPS, 210/50 mm, hardware: 25.0 x 8.0 mm, no Bushing
HeadsetVP Components, ZS56/286-ZS56/40VP Components, ZS56/286-ZS56/40VP Components, ZS56/286-ZS56/40ACROS ZS56/ZS56 (ICR), FOCUS C.I.S. Integrated
StemAluminium, 31,8 mm, 6°FOCUS aluminium, 31,8 mm, 60 mm, 17°BBB Jumper BHS-137, 31.8 mmFOCUS C.I.S. integrated, 50 mm, 0°, 35 mm, aluminium
HandlebarAluminium, riserbar, 760 mm, 35,0 mmAluminium, 720 mm, flatbar, backsweep: 9°, 31.8 mmRiser, Aluminium, 720 mmAluminium, 800 mm, rise: 35 mm, backsweep: 9°
GripsFOCUS Sport Ergo
SaddleProxim W350Selle Royal VivoFOCUS Sport SLProxim X400
SeatpostPost Moderne dropper post PM-MT171, 31.6 mmFOCUS Post Moderne dropper post PM-214, 31.6 mmAluminium, 31,6 mmPost Moderne dropper post PM-214, 34.9 mm
BrakesShimano MT420, 4-piston, hydraulic disc brake (lever: Shimano MT420)Shimano MT420, 4-piston, hydraulic disc brake (lever: Shimano MT420)Shimano MT420, 4-piston, hydraulic disc brake (lever: Shimano MT420)Shimano MT520, hydraulic disc brake (lever: Shimano MT520)
Rear derailleurShimano Deore RD-M5100, 11-speedShimano Deore RD-M5100, 11-speedShimano SLX M7100, 12-speedShimano Deore XT M8100, 12-speed
CrankSamox EC40 ISIS (front: 36)FSA CK-320, aluminium (front: 34)FSA CK-320, aluminium (front: 34)Samox EC40 ISIS (front: 34)
ShiftersShimano Deore M5100, 11-speedShimano Deore M5100, 11-speedShimano SLX M7100, 12-speedShimano Deore XT SL-M8100, 12-speed
CassetteShimano Deore CS-M5100, 11-speed (11-51)Shimano Deore CS-M5100, 11-speed (11-51)Shimano SLX M7100, 12-speed (10-51)Shimano SLX M7100, 12-speed (11-51)
ChainShimano CN-HG601, 11-speedShimano CN-HG601, 11-speedShimano SLX CN-M7100Shimano SLX CN-M7100, 12-speed
DrivetrainShimano Deore RD-M5100, 11-speed; Samox EC40 ISIS (front: 36); Shimano Deore M5100, 11-speed; Shimano Deore CS-M5100, 11-speed (11-51); Shimano CN-HG601, 11-speedShimano Deore RD-M5100, 11-speed; FSA CK-320, aluminium (front: 34); Shimano Deore M5100, 11-speed; Shimano Deore CS-M5100, 11-speed (11-51); Shimano CN-HG601, 11-speedShimano SLX M7100, 12-speed; FSA CK-320, aluminium (front: 34); Shimano SLX M7100, 12-speed; Shimano SLX M7100, 12-speed (10-51); Shimano SLX CN-M7100Shimano Deore XT M8100, 12-speed; Samox EC40 ISIS (front: 34); Shimano Deore XT SL-M8100, 12-speed; Shimano SLX M7100, 12-speed (11-51); Shimano SLX CN-M7100, 12-speed
WheelsRODI TRYP30, 30-622 (front hub Novatec D041SB 15x100 mm, rear hub Novatec D462SB 12x148 mm)RODI TRYP25, 25-622 (front hub Shimano Alivio MT400 15x110 mm, rear hub Shimano Alivio MT400 12x148 mm)Rodi Black Rock 23 custom for Focus (front hub Novatec D041 15x110 mm, rear hub Novatec D162 Disc 12x148 mm)DT SWISS H1900, 30-622, 15x110 mm / 12x148 mm
TyresMaxxis Minion DHF, 2.5 3C EXO, 63-622Schwalbe Smart Sam 2.25, 57-622Schwalbe Hurricane Performance, 57-622Schwalbe Hans Dampf, 2.6 SuperGround Soft, 65-622 (rear: Schwalbe Nobby Nic 2.6 SuperTrail SpeedGrip)
Weight25.8 kg25.4 kg25.8 kg26.6 kg
Price£4,199£4,199€4,499€6,299
Rides similarly
Spot a mistake?
