Bike Finder · Focus
Focus JAM2 SL
Focus
JAM2 SL 2025
CurrentLightweight eMTBAgeing · 4.4/10iFreshness 4.4/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy 430 · 430Wh
Travel F/R
160/150mm
Wheels
29F / 29R
Frame
Full carbon
Weight
17.9 kg
Price
From £6,499
View the Focus JAM2 SL on Focus’s site
Focus JAM2 SL 2025
From £6,499
EMTB Forums verdict
The Focus JAM2 SL is the brand's lightweight take on the trail e-MTB, built around a full-carbon frame, 160 mm of fork travel and 150 mm at the rear. The Fazua Ride 60 drive unit delivers 60 Nm and a 450 W peak from a 430 Wh battery, placing it firmly in the mid-power, natural-feeling category rather than chasing full-fat torque figures.
Geometry is modern but adjustable. The default 64.5 degree head angle and 76.5 degree seat angle suit longer trail descents, while an angle headset lets you steepen the front to 65.5 degrees and rear FLIP CHIPs swap chainstays between 440 and 447 mm, giving four set-up combinations. Reach runs 430 mm on the S up to 515 mm on the XL, with stack climbing from 614 to 650 mm, so sizing spans compact to long.
The four-trim range stretches from the SRAM NX Eagle equipped 8.7 at £6,499 to the AXS-shifted, carbon-wheeled flagship 9.0 at £10,199. The £7,299 8.8 and £9,299 9.9 both use the same Fazua platform and full-carbon frame, so the choice between them is mostly about suspension grade and groupset rather than ride character. The 9.0's claimed 17.9 kg weight underlines the light e-MTB billing.
Bike geometry diagram
SMLXL
Reach430 mm460 mm485 mm515 mm
Stack614 mm614 mm632 mm650 mm
Seattube390 mm420 mm440 mm460 mm
Chainstay447 mm447 mm447 mm447 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1205 mm1230 mm1264 mm1297 mm
Headtube100 mm100 mm120 mm140 mm
Standover790 mm790 mm790 mm792 mm
Front Centre758 mm*783 mm*817 mm*850 mm*
Trims · 4
8.7
£6,499
8.8
£7,299
9.9
£9,299
9.0
£10,199
MotorFazua Ride 60 · 60 Nm · all trims
BatteryFazua Energy 430 · 430 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbonCarbonCarbon (MAX Carbon)Carbon (MAX Carbon)
ForkDVO Diamond (160 mm)FOX Rhythm 29 E-Bike (160 mm)FOX 36 Performance Elite (160 mm)FOX 36 Float Factory 29, Grip 2, 110 x 15 mm, 44 mm rake (160 mm)
ShockRockShox Deluxe Select+ (150 mm)FOX DPS (150 mm)FOX X Performance (150 mm)FOX Float DPS Factory, 3-position Evol LV, 210/55 mm, hardware 25.0 x 8.0 mm, no Bushing
HeadsetACROS ZS56/ZS56 (ICR), FOCUS C.I.S. Integrated, 1.5/1.5" angle headset
StemFOCUS C.I.S. integrated, 50 mm, 0deg, 35 mm, aluminium
HandlebarRaceFace Next R, carbon, 800 mm, rise 25 mm, backsweep 8deg, 35.0 mm
GripsRaceFace Getta Grip
SaddlePrologo Proxim W850
SeatpostPost Moderne dropper post PM-MT171, 31.6 mm
BrakesSRAM G2 Ultimate (front) | SRAM G2 Ultimate (rear)
Rear derailleurSRAM NX Eagle 12-speedShimano XT 12-speedShimano XT 12-speedSRAM XO1 Eagle AXS, 12-speed
CrankRotor eKAPIC RF Link 29; front: 32, rear: 10-52
ShiftersSRAM AXS Rocker, 12-speed
Cassettee*thirteen Helix Plus
ChainSRAM X01 Eagle, 12-speed
DrivetrainSRAM NX Eagle 12-speedShimano XT 12-speedShimano XT 12-speedSRAM XO1 Eagle AXS, 12-speed; Rotor eKAPIC RF Link 29; front: 32, rear: 10-52; SRAM AXS Rocker, 12-speed; e*thirteen Helix Plus; SRAM X01 Eagle, 12-speed
WheelsDT Swiss HX1700 LS wheelsMavic Crossmax X LR 29, carbon, 622-30, 15x110 mm / 12x148 mm
TyresMaxxis Dissector, Exo, 29 x 2.4" (front) | Maxxis Dissector, Exo, 29 x 2.4" (rear)
Weight17.9 kg
Price£6,499£7,299£9,299£10,199
Rides similarly
Spot a mistake?
