Bike Finder · Focus
Focus JAM²
Focus
JAM² 2022
DiscontinuedFull Power · TrailLegacy · 1/10iFreshness 1/10
Balanced full-power alloy trail bike from Focus's earlier JAM line
Travel F/R
150/150mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
From £4,049
View the Focus JAM² on Focus’s site
Focus JAM² 2022
From £4,049
EMTB Forums verdict
The 2022 Focus JAM² was the German brand's full-suspension trail eMTB, sitting between the SAM² e-enduro and the THRON² in the range. It used Focus's F.O.L.D. linkage with 150 mm of travel front and rear, a 7005 hydroformed aluminium frame, and a flip chip in the dropout allowing 29", 27.5+ or mixed (Drifter) wheels.
Focus split the family across two drive systems, and the two used genuinely different frames and geometries. The Bosch 6-series (6.7, 6.8, 6.9) ran the Bosch Performance Line CX motor (Gen 4, 85 Nm) with an integrated, removable 625 Wh PowerTube battery, on a 66 degree head angle, 75 degree seat angle frame with 427 mm chainstays. Builds stepped from a RockShox Recon, Shimano SLX groupset and Shimano four-piston brakes on the 6.7, up to a FOX 36 Rhythm fork and Shimano XT 1x12 on the 6.9. The Shimano 7-series (7.0, 7.9, 7.8) used the Shimano EP8 motor with a 720 Wh battery on a slacker, longer-stay frame (65 degree head angle, 76 degree seat angle, 448 mm chainstays), topping out in the 7.0 with a RockShox ZEB, FOX Float X and wireless SRAM GX Eagle AXS. All six trims were aluminium; the carbon JAM² in this family was the separate 9.9 Drifter.
UK pricing ran from 4049 GBP for the 6.7 up to 7499 GBP for the 7.0, with the 6.9 at 5399 GBP and the Shimano 7.8 and 7.9 at 4799 GBP and 5699 GBP. This model year is discontinued. Focus has since reworked the JAM², moving the alloy Bosch bike to a 750 Wh battery and a 160 mm fork, and adding the lighter JAM² SL (Fazua) as a separate lineage.
Note on data: full per-size geometry and the per-component tables here were read from 99spokes, which mirrors Focus's published 2022 spec, because the original Focus 2022 datasheet was a JavaScript page that did not render from archive captures. Prices, motors, batteries, travel and the Bosch-versus-Shimano geometry split were cross-checked against Focus's own 2022 UK and Austrian product pages.
Geometry read
Size
Descending
53
A solid all-round descender (66° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
77
Short 427mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
82
Balanced front-to-rear in L (FC:RC 1.86) — weight sits evenly between the wheels.
Technical climbing
53
Climbs well — a 75° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Trail bikes (from 271 bikes in the database)
Battery625 Wh79 Wh below average
Motor torque85 Nm13 Nm below average
Value for money73/100from £4,049 · most Bosch Performance Line CX Gen 4 bikes ~£4,800
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
Focus jam 2 complete wiring loom
51 replies · 20.3k views · last reply 32 months ago
Join the discussion →
“My one big takeaway from the past year on they forum, and being lucky enough to try a lot of the bikes out there, is that at this moment in the development of EMTB's and I would suppose Ebikes in general, is that its the brands that…”
— R120 · ♥ 3 · most-liked post
Bike geometry diagram
SMLXL
Reach420 mm437 mm470 mm495 mm
Stack607 mm612 mm625 mm644 mm
Seattube400 mm420 mm450 mm490 mm
Chainstay427 mm427 mm427 mm427 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)75°75°75°75°
Wheelbase1163 mm1190 mm1221 mm1254 mm
Headtube110 mm115 mm130 mm150 mm
BB Height364 mm364 mm364 mm364 mm
Front Centre736 mm*763 mm*794 mm*827 mm*
FC:RC1.721.791.861.94
Trims · 6
6.7
£4,049
6.8
£4,799
7.8
£4,799
6.9
£5,399
7.9
£5,699
7.0
£7,499
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 625 · 625 Wh · all trims
Travel F/R150/150 mm · all trims
FrameAluminium · all trims
ForkRockShox Recon RL 29 Boost E-MTB (150 mm travel, 110x15 mm, 51 mm rake)FOX Rhythm 34 suspension fork (150 mm travel)RockShox 35 Gold RL 29 Boost (150 mm travel, 110x15 mm, 44 mm rake)FOX 36 Rhythm suspension fork (150 mm travel)FOX 36 Float Rhythm 29, Grip Remote (150 mm travel, 110x15 mm, 44 mm rake)RockShox ZEB 29 Boost, Charger R, DebonAir (150 mm travel, 110x15 mm, 44 mm rake)
ShockRockShox Deluxe Select, 210/55 mm, custom tuneFOX DPS Performance rear shockRockShox Deluxe Select, 210/55 mmFOX DPS Performance rear shockFOX Float X Performance, 210/55 mmFOX Float X Performance, 210/55 mm
HeadsetVP Components, ZS56/286-ZS56/40ACROS ZS56/ZS66 (ICR), FOCUS C.I.S. integrated, 1.5/1.8" angle headsetACROS ZS56/ZS66 (ICR), FOCUS C.I.S. integrated, 1.5/1.8" angle headsetACROS ZS56/ZS66 (ICR), FOCUS C.I.S. integrated
StemBBB Jumper BHS-138, 31.8 mm (FOCUS C.I.S.)FOCUS C.I.S. (fully integrated cable routing through stem)FOCUS C.I.S. integrated, 50 mm, 35 mm, aluminiumFOCUS C.I.S. (fully integrated cable routing through stem)FOCUS C.I.S. integrated, 50 mm, 35 mm, aluminiumFOCUS C.I.S. integrated, 50 mm, 35 mm, aluminium
HandlebarBBB Ascension BHB-110, aluminium riser, 780 mm, 20 mm rise, 9° backsweepAluminium, 800 mm, 30 mm rise, 9° backsweepAluminium, 800 mm, 30 mm rise, 9° backsweepRaceFace Chester 35, aluminium, 780 mm, 35 mm rise, 8° backsweep
GripsFOCUS Locker SLRaceFace Getta Grip
SaddleFOCUS Trail SLFOCUS Race SLProxim W400Proxim W450
SeatpostPost Moderne dropper post PM-MT171, 31.6 mmPost Moderne dropper post PM-214, 34.9 mmPost Moderne dropper post PM-214, 34.9 mmPost Moderne dropper post PM-214, 34.9 mm
BrakesShimano BR-MT520, 4-pistonShimano XT 4-piston brakesShimano SLX 4-piston brakesShimano XT 4-piston brakesShimano XT 4-piston brakesSRAM Code RSC
Rear derailleurShimano SLX M7100, 12-speedShimano XT (1x12)Shimano SLX M7100, 12-speedShimano XT 1x12Shimano Deore XT M8100, 12-speedSRAM GX Eagle AXS (wireless electronic shifting)
CrankFSA CK-320, aluminiumSamox EC40 ISISShimano FC-EM600, 12-speede*thirteen e*spec Plus Crank (Shimano EP8)
ShiftersShimano SLX M7100, 12-speedShimano XTShimano SLX M7100, 12-speedShimano XT 1x12Shimano Deore XT M8100, 12-speedSRAM GX Eagle AXS (wireless), 12-speed
CassetteShimano SLX M7100, 12-speedShimano Deore CS-M6100, 12-speedShimano SLX M7100, 12-speedSRAM XG-1275, 12-speed
ChainShimano SLX CN-M7100, 12-speedShimano CN-LG500Shimano SLX CN-M7100, 12-speedSRAM GX Eagle, 12-speed
DrivetrainShimano SLX M7100, 12-speed; FSA CK-320, aluminium; Shimano SLX M7100, 12-speed; Shimano SLX M7100, 12-speed; Shimano SLX CN-M7100, 12-speedShimano XT (1x12); Shimano XTShimano SLX M7100, 12-speed; Samox EC40 ISIS; Shimano SLX M7100, 12-speed; Shimano Deore CS-M6100, 12-speed; Shimano CN-LG500Shimano XT 1x12; Shimano XT 1x12Shimano Deore XT M8100, 12-speed; Shimano FC-EM600, 12-speed; Shimano Deore XT M8100, 12-speed; Shimano SLX M7100, 12-speed; Shimano SLX CN-M7100, 12-speedSRAM GX Eagle AXS (wireless electronic shifting); e*thirteen e*spec Plus Crank (Shimano EP8); SRAM GX Eagle AXS (wireless), 12-speed; SRAM XG-1275, 12-speed; SRAM GX Eagle, 12-speed
WheelsRaceFace AR30 OffsetRaceFace AR30 OffsetRaceFace AR30 OffsetDT Swiss HX1700 LS, 30-622
TyresMaxxis Rekon 2.6 Dual EXO TRMaxxis Minion DHF, EXO, 2.6Maxxis Minion DHF II, 2.6Schwalbe Magic Mary 2.6 Super Trail Soft (front and rear)
Price£4,049£4,799£4,799£5,399£5,699£7,499
Rides similarly
Spot a mistake?
