Bike Finder · Focus
Focus JAM² SL
Focus
JAM² SL 2026
CurrentLightweight eMTBMature · 6/10iFreshness 6/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy 430 · 430Wh
Travel F/R
160/150mm
Wheels
29F / 29R
Frame
Full carbon
Weight
17.9 kg
Price
From £6,499
View the Focus JAM² SL on Focus’s site
Focus JAM² SL 2026
From £6,499
EMTB Forums verdict
The Focus JAM² SL is the lightweight, mid-power sibling to the full-power JAM², built around a full-carbon frame, 160 mm of fork travel and 150 mm at the rear on 29in wheels. The Fazua Ride 60 motor (60 Nm, 450 W) and 430 Wh battery keep claimed weights low, from 17.9 kg on the range-topping 9.0 to 20.2 kg on the 8.7, putting it squarely in the trail-focused light eMTB category rather than chasing outright assistance.
The four-bike range is unusually consistent on the things that matter, with every trim sharing the same frame, motor, battery, 160/150 mm travel and adjustable geometry. The differences are all in the kit. The £10,199 9.0 spends its money on a MAX carbon frame, FOX 36 Factory fork, carbon Mavic wheels and wireless SRAM X01 AXS. The £9,299 9.9 keeps the MAX carbon frame but switches to Shimano XT and FOX Performance Elite suspension, which makes it arguably the value pick of the lighter models. The £7,299 8.8 and £6,499 8.7 step down to the standard carbon frame and mixed drivetrains (XT/Deore and SRAM NX/SX respectively), with the 8.7 the most affordable way into the platform.
Geometry is firmly modern-trail. The frame is delivered in its slack 64.5 degree head-angle and long 447 mm chainstay setting, with reach running 430 mm on the S to 515 mm on the XL and a consistent 76.5 degree effective seat angle. Riders can steepen the head angle to 65.5 degrees via the angle headset and shorten the chainstays to 440 mm with the FLIP CHIPs, giving four geometry combinations to tune handling between stability and agility.
Bike geometry diagram
SMLXL
Reach430 mm460 mm485 mm515 mm
Stack614 mm614 mm632 mm650 mm
Seattube390 mm420 mm440 mm460 mm
Chainstay447 mm447 mm447 mm447 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1205 mm1230 mm1264 mm1297 mm
Headtube100 mm100 mm120 mm140 mm
Standover790 mm790 mm790 mm792 mm
Front Centre758 mm*783 mm*817 mm*850 mm*
Trims · 4
8.7
£6,499
8.8
£7,299
9.9
£9,299
9.0
£10,199
MotorFazua Ride 60 · 60 Nm · all trims
BatteryFazua Energy 430 · 430 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbonCarbonMAX CarbonMAX Carbon
ForkDVO Diamond E3, 110x15 mm, 44 mm rake, 160 mm travelFOX 36 Float Rhythm 29 E-Bike, Grip, 110 x 15 mm, 44 mm rake, 160 mm travelFOX 36 Float Performance Elite 29, Grip 2, 110 x 15 mm, 44 mm rake, 160 mm travelFOX 36 Float Factory 29, Grip 2, 110 x 15 mm, 44 mm rake, 160 mm travel
ShockRockShox Deluxe Select+, 210/55 mm, hardware: 25.0 x 8.0 mm, no BushingFOX Float DPS, 2-position lever, 210/55 mm, hardware: 25.0 x 8.0 mm, no BushingFOX Float X Performance, 210/55 mm, hardware: 25.0 x 8.0, no BushingFOX Float DPS Factory, 3-position Evol LV, 210/55 mm, hardware: 25.0 x 8.0 mm, no Bushing
HeadsetACROS ZS56/ZS56 (ICR), FOCUS C.I.S. Integrated, 1.5/1.5" angle headset · all trims
StemFOCUS C.I.S. 2.0 MTB, 35 mm, aluminiumFOCUS C.I.S. 2.0 MTB, 35 mm, aluminiumFOCUS C.I.S. 2.0 MTB, 35 mm, aluminiumFOCUS C.I.S. integrated, 50 mm, 0°, 35 mm, aluminium
HandlebarAluminium, 800 mm, rise: 30 mm, backsweep: 9°Aluminium, 800 mm, rise: 30 mm, backsweep: 9°RaceFace Atlas 35, aluminium, 820 mm, rise: 35 mm, backsweep: 8°RaceFace Next R, carbon, 800 mm, rise: 25 mm, backsweep: 8°, 35.0 mm
GripsFOCUS Locker SLHerrmans DD 41BRaceFace Getta GripRaceFace Getta Grip
Saddlefi'zi:k Taigafi'zi:k Taigafi'zi:k TaigaPrologo Proxim W850
SeatpostPost Moderne dropper post PM-MT171, 31.6 mm · all trims
BrakesSRAM DB8, 4-piston hydraulic disc (front) | SRAM DB8, 4-piston hydraulic disc (rear)Magura MT5 (front) | Magura MT5 (rear)Shimano XT M8120, 4 piston (front) | Shimano XT M8120, 4 piston (rear)SRAM G2 Ultimate (front) | SRAM G2 Ultimate (rear)
Rear derailleurSRAM NX Eagle, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speedSRAM X01 Eagle AXS, 12-speed
CrankSamox EC40 ISIS, front: 32TRotor eKAPIC RF Link 29, front: 32TRotor eKAPIC RF Link 29, front: 32TRotor eKAPIC RF Link 29, front: 32T
ShiftersSRAM SX Eagle, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speedSRAM AXS Rocker, 12-speed
CassetteSRAM NX Eagle, 12-speed, 11-50Shimano Deore CS-M6100, 12-speed, 10-51Shimano Deore XT M8100, 12-speed, 10-51e*thirteen Helix Plus, 10-52
ChainSRAM SX Eagle, 12-speedShimano Deore CN-M6100, 12-speedShimano SLX M7100, 12-speedSRAM X01 Eagle, 12-speed
DrivetrainSRAM NX Eagle, 12-speed; Samox EC40 ISIS, front: 32T; SRAM SX Eagle, 12-speed; SRAM NX Eagle, 12-speed, 11-50; SRAM SX Eagle, 12-speedShimano Deore XT M8100, 12-speed; Rotor eKAPIC RF Link 29, front: 32T; Shimano Deore XT M8100, 12-speed; Shimano Deore CS-M6100, 12-speed, 10-51; Shimano Deore CN-M6100, 12-speedShimano Deore XT M8100, 12-speed; Rotor eKAPIC RF Link 29, front: 32T; Shimano Deore XT M8100, 12-speed; Shimano Deore XT M8100, 12-speed, 10-51; Shimano SLX M7100, 12-speedSRAM X01 Eagle AXS, 12-speed; Rotor eKAPIC RF Link 29, front: 32T; SRAM AXS Rocker, 12-speed; e*thirteen Helix Plus, 10-52; SRAM X01 Eagle, 12-speed
WheelsRaceFace AR30 Offset (front and rear); Novatec D041 hub 15x110 mm front, Novatec D462 hub 12x148 mm rear, Niro black spokesRaceFace AR30 Offset (front and rear); Novatec D041 hub 15x110 mm front, Novatec D462 hub 12x148 mm rear, Niro black spokesDT Swiss HX1700 LS, 30-622, 110x15 mm / 12x148 mmMavic Crossmax X LR 29, carbon, 622-30, 15x110 mm / 12x148 mm
TyresMaxxis Minion DHF, EXO, 29 x 2.5" (front) | Maxxis Minion DHF, EXO, 29 x 2.5" (rear)Maxxis Assegai, 3C MaxxTerra Exo TR, 29 x 2.5" (front) | Maxxis Dissector, WT 3C MaxxTerra Exo TR, 29 x 2.5" (rear)Schwalbe Magic Mary, Super Ground Soft, 29 x 2.4" (front) | Schwalbe Nobby Nic 2.4 SuperTrail SpeedGrip, 29 x 2.4" (rear)Maxxis Dissector, Exo, 29 x 2.4" (front) | Maxxis Dissector, Exo, 29 x 2.4" (rear)
Weight20.2 kg19.7 kg19.2 kg17.9 kg
Price£6,499£7,299£9,299£10,199
Rides similarly
Spot a mistake?
