A solid all-round descender (66.5° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
EP 2022
The 2022 Devinci EP is the Canadian brand's E-Trail platform, a full-suspension trail eMTB built around a handcrafted 6066-T6 Optimum G04 aluminium frame with 130mm of rear travel via Devinci's eMTB-optimised Split Pivot linkage and 140mm up front. It rolls on 29in wheels at both ends and uses Devinci's FRG flip-chip to switch between a low setting (66.5 degree head angle, 345mm BB height) and a high setting (67.0 degree head angle, 351mm BB), letting riders choose a slacker, more planted feel or a steeper, livelier one. This bike is discontinued.
For 2022 the EP came in a single build, the Deore 12S, at US$5,999. It pairs a Shimano STEPS E7000 drive unit (250W, 60Nm) with a 504Wh Shimano STEPS E8035 battery, both shielded by moulded frame, motor and battery protection. The build is practical and durable rather than flashy: a RockShox 35 Silver TK fork and Deluxe Select R shock, Magura MT30 four-piston brakes on 203mm rotors, a Shimano Deore M6100 12-speed drivetrain with a Sunrace 11-51T cassette, and Maxxis Minion DHF/DHRII 2.6in tyres in MaxxTerra Exo+. Claimed weight is 24.33kg for a size medium.
Geometry spans four sizes (S to XL) with reach from 435mm to 495mm in the low setting, paired with steepish 76.4 to 76.5 degree seat angles for climbing and a consistent 470mm chainstay. As a Made in Canada alloy trail eMTB at a mid-range price, the EP positions itself as an accessible, durable all-rounder rather than a high-output enduro machine. Devinci is not sold in the UK, so there is no genuine GBP RRP. No owner or long-term reliability data is available here, so this verdict is based on published specification only.
Rear-long with a planted front in L (FC:RC 1.66) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Climbs well — a 76.4° seat keeps the front planted. 250W of peak power and 60Nm of torque.
How it stacks up vs other Lightweight · Cross-Country bikes (from 63 bikes in the database)
| S | M | L | XL | |
| Reach | 440 mm | 460 mm | 480 mm | 501 mm |
| Stack | 613 mm | 613 mm | 622 mm | 631 mm |
| Seattube | 410 mm | 420 mm | 455 mm | 495 mm |
| Chainstay | 469 mm | 469 mm | 469 mm | 469 mm |
| Headtube Angle | 67° | 67° | 67° | 67° |
| Seattube Angle (eff) | 77° | 77° | 76.9° | 76.9° |
| Wheelbase | 1205 mm | 1225 mm | 1249 mm | 1273 mm |
| Headtube | 105 mm | 105 mm | 115 mm | 125 mm |
| BB Height | 351 mm | 351 mm | 351 mm | 351 mm |
| Standover | 745 mm | 752 mm | 776 mm | 803 mm |
| Front Centre | 736 mm* | 756 mm* | 780 mm* | 804 mm* |
| FC:RC | 1.57 | 1.61 | 1.66 | 1.71 |
Trims · 1
Deore 12S $5,999 | |
| Motor | Shimano E7000 · 60 Nm |
| Battery | Shimano STEPS E8035 · 504 Wh |
| Travel F/R | 140/130 mm |
| Frame | Aluminum Optimum G04 (6066-T6) |
| Fork | RockShox 35 Silver TK Solo Air 140 | 0T | 44 Offset |
| Shock | Rockshox Deluxe Select R Debonair Trunnion | 185x47.5 |
| Headset | FSA Orbit | 1.5 | Zero Stack |
| Stem | V2 Pro | B:35mm | L:50mm | 0deg |
| Handlebar | V2 Pro | B:35mm | R:15mm | W:780mm |
| Grips | Devinci Performance | w/lock-on |
| Saddle | SDG BELAIR 3.0 |
| Seatpost | TranzX Dropper | 31.6mm | 1x Lever |
| Brakes | Magura MT30 | 4 Pistons (front and rear) |
| Rear derailleur | Shimano Deore M6100 | 12s |
| Crank | Crankarm: Shimano STEPS E8000 | Chainring: Shimano STEPS CRE70 | 36T |
| Shifters | Shimano Deore M6100 | 12s |
| Cassette | Sunrace 12s | 11-51T |
| Chain | Shimano Deore M6100 | 12s |
| Drivetrain | Shimano Deore M6100 | 12s; Crankarm: Shimano STEPS E8000 | Chainring: Shimano STEPS CRE70 | 36T; Shimano Deore M6100 | 12s; Sunrace 12s | 11-51T; Shimano Deore M6100 | 12s |
| Wheels | V2 Comp | 36mm inner | TR (front and rear). Front hub Formula DC-711 Sealed 6bolts TA 15x110mm; rear hub Formula EHL-148 Sealed 6bolts TA 12x148mm HG; Sapim Stainless 14G spokes w/Nylok |
| Tyres | Maxxis Minion DHF 29x2.6wt 3C MaxxTerra Exo+ TR (front); Maxxis Minion DHRII 29x2.6WT 3C MaxxTerra Exo+ TR (rear) |
| Weight | 24.33 kg |
| Price | $5,999 |
Rides similarly
Spot a mistake?
