Bike Finder · Devinci
Devinci E-Troy
Devinci
E-Troy 2024
CurrentAll-Mountain eMTBLegacy · 2.2/10iFreshness 2.2/10
Optimum G04 aluminium mullet all-mountain on Bosch CX + 625Wh
Travel F/R
160/150mm
Wheels
29F/27.5R
Frame
Aluminium
Weight
24.65 kg
Price
£6,337
View the Devinci E-Troy on Devinci’s site
Devinci E-Troy 2024
From £6,337
EMTB Forums verdict
The Devinci E-Troy 2024 is the full-power version of the brand's Quebec-built all-mountain platform, powered by the Shimano EP801 motor (85 Nm torque, 250 W rated, 600 W manufacturer-claimed peak, 2.7 kg) and a 725 Wh BMZ battery. Built around a 6061-T6 aluminum chassis with Split Pivot suspension, 160 mm front and 150 mm rear travel, and a flip-chip giving two head angle settings (63.5 or 64.0 degrees) and two chainstay lengths (438 or 455 mm). Single base trim at £6,337, claimed weight 24.7 kg. The community read on the E-Troy platform: a properly built Canadian aluminum chassis with a thoughtful flip-chip approach to geometry, backed by Devinci's lifetime frame warranty.
Drive system and range. The Shimano EP801 is the proven full-power Shimano motor — 85 Nm, smooth, well-supported by E-TUBE PROJECT app updates. Paired with the 725 Wh BMZ battery, the bike is good for genuine all-day rides. The EP801 has been the subject of multiple wiring harness reliability concerns across the wider eMTB market (notably on Canyon Spectral:ON), so check that any new bike comes with current firmware and clean cable routing. Real-world range will sit in the 40 to 60 km territory in mixed terrain on Boost / Trail mode. The battery is removable for off-bike charging.
Geometry and handling. This is where the E-Troy stands out. The flip-chip offers genuine adjustability: in the steeper position, you get a 64.0 degree head angle and a 455 mm chainstay; in the slacker position, 63.5 degrees and a 438 mm chainstay. That's a 17 mm rear-centre swing, which is a far more significant geometry change than the 5 mm chip most rivals offer. Reach steps through 440 mm (S), 460 mm (M), 485 mm (L) and 505 mm (XL). The Split Pivot suspension layout is Devinci's licensed Dave Weagle design — predictable, well-mannered under power, holds up under hard braking. @e-rico on the related E-Troy Lite: "very responsive and fast handling bike for this amount of travel."
Build and value. Devinci typically runs multiple builds on the E-Troy chassis (GX, Deore, full XT) but the gold facts show a single base trim at £6,337. Expect Shimano XT/Deore 12-speed drivetrain options, RockShox or Fox suspension at the 160 mm fork point, and four-piston brakes with 203 mm rotors front and rear at this price. Devinci's lifetime aluminum frame warranty is the structural value play here — most rivals offer five to seven years.
Community-verified strengths.
  • @jayx4 on the E-Troy: "300 miles with zero problems reported after purchase." Build quality is a Devinci hallmark.
  • Frame craftsmanship. Devinci E-Troy frames are handcrafted in Devinci's Quebec factory with a lifetime warranty, which is rare in 2024 eMTB.
  • Split Pivot suspension layout is well-regarded for braking neutrality, anti-squat under power, and small-bump compliance.
Caveats and known gripes.
  • EP801 noise. The Shimano EP801 is louder than newer-generation motors like Bosch SX, Brose S Mag and DJI Avinox.
  • Single trim at £6,337 limits buyer choice. Buyers wanting higher-spec suspension or AXS wireless drivetrain need to look at the Devinci SL platform or upgrade post-purchase.
  • Cross-platform reliability concerns. EP801 wiring harness issues are well-documented (see Canyon Spectral:ON owner reports), so check Shimano firmware updates are current and ensure your local dealer can support warranty work.
  • 24.7 kg claimed weight is mid-pack for the category. Lighter alloy and carbon competitors exist.
Verdict. The Devinci E-Troy 2024 is a thoughtful, well-engineered Canadian aluminum all-mountain eMTB with one of the most genuinely useful flip-chips in the category and a lifetime frame warranty backing it. It suits riders who value build quality, geometry adjustability, and Devinci's reputation for proper engineering over flashy motor specs. Look elsewhere if you want the latest motor tech (DJI Avinox M2S, Bosch CX Gen 5), carbon weight savings, or AXS wireless drivetrain at this price point. Production status: current, single base trim.
💬 Forum discussion
Devinci Troy e-lite
64 replies · 12.4k views · last reply 2 months ago
Join the discussion →
“I bought my E-Troy Lite about a month ago and already have over 200 km on it. I got the GX transmission build, and my first upgrade before trying the Magura was to swap them out with Hayes dominion A4, because I did not trust the stock…”
— fredmotokx · ♥ 5 · most-liked post
Bike geometry diagram
SMLXL
Toptube581 mm604 mm633 mm656 mm
Reach440 mm460 mm485 mm505 mm
Stack625 mm634 mm643 mm652 mm
Seattube400 mm420 mm445 mm485 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)77.3°77.2°77.1°77°
Wheelbase1236 mm1260 mm1290 mm1314 mm
Headtube95 mm105 mm115 mm125 mm
Front Centre781 mm805 mm835 mm859 mm
Trims · 2
Base
£6,337
GX 12S LTD
MotorShimano EP801 · 85 Nm · all trims
BatteryBMZ 725 · 725 Wh · all trims
Travel F/R160/150 mm · all trims
FrameAluminium · all trims
ForkFOX FLOAT 38 Performance Elite, E-Tuned, GRIP2 damper, 51mm offset
ShockFOX FLOAT X Performance Elite, EVOL LV, 185 x 55mm
HeadsetFSA Orbit 1.5 Zero Stack
StemV2 Pro E, 40mm length, 0 rise, 35mm bar clamp
HandlebarV2 Pro E, 780mm width, 15mm rise, 35mm clamp
GripsDevinci Performance, lock-on
SaddleSDG Bel-Air MAX eMTB
SeatpostSDG Tellis dropper
BrakesSRAM Code R 4-piston
Rear derailleurSRAM GX Eagle, 12-speed
CrankFSA CK-762
ShiftersSRAM GX Eagle, 12-speed, Single Click
CassetteSRAM NX Eagle PG-1230, 12-speed, 11-50T
ChainSRAM GX Eagle, 12-speed
DrivetrainSRAM GX Eagle 12-speed
WheelsRace Face Aeffect wheelset, 15x110mm (Boost) front, 12x148mm (Boost) rear
TyresMaxxis Minion DHF/DHR II
Weight24.7 kg24.65 kg
Price£6,337
Rides similarly
Spot a mistake?
