E-Troy Lite 2026
The Devinci E-Troy Lite is the Canadian brand's lightweight trail eMTB, built around the Bosch Performance Line SX motor (60 Nm, 600 W peak) and a 400 Wh CompactTube battery for a claimed 20.1 kg in size medium. The frame is welded from 6061-T6 Optimum G04 aluminium and the e-MTB optimised Split Pivot suspension gives 150 mm rear travel paired with a 160 mm RockShox Lyrik fork.
For 2026 Devinci lists a single GX AXS 12S build on the live site. It is a high-end specification: SRAM GX Eagle AXS Transmission, powerful SRAM Maven Silver brakes on 200 mm rotors, RockShox Ultimate suspension front and rear, RaceFace ARC30 wheels and a Maxxis Assegai / Minion DHR II tyre pairing. The PowerMore 250 range extender is supported for longer days.
Geometry is consistently slack and modern across all four sizes, with a 63.6 degree head angle, steep seat angles from 77.9 to 77.5 degrees, a fixed 438 mm chainstay and reach growing from 441 mm (S) to 501 mm (XL). Mixed wheels keep the handling snappy while the 29 inch front adds rollover. There is no flip chip or geometry adjustment. With no current UK distributor, pricing is shown in North American currencies rather than a GBP RRP.
| S | M | L | XL | |
| Reach | 441 mm | 461 mm | 481 mm | 501 mm |
| Stack | 608 mm | 617 mm | 626 mm | 635 mm |
| Seattube | 400 mm | 420 mm | 460 mm | 495 mm |
| Chainstay | 438 mm | 438 mm | 438 mm | 438 mm |
| Headtube Angle | 63.6° | 63.6° | 63.6° | 63.6° |
| Seattube Angle (eff) | 77.9° | 77.8° | 77.6° | 77.5° |
| Wheelbase | 1216 mm | 1240 mm | 1264 mm | 1289 mm |
| Headtube | 95 mm | 105 mm | 115 mm | 125 mm |
| BB Height | 346 mm | 346 mm | 346 mm | 346 mm |
| Standover | 740 mm | 740 mm | 740 mm | 740 mm |
| Front Centre | 778 mm* | 802 mm* | 826 mm* | 851 mm* |
Trims · 1
GX AXS 12S | |
| Motor | Bosch Performance Line SX · 60 Nm |
| Battery | Bosch CompactTube 400 · 400 Wh |
| Travel F/R | 160/150 mm |
| Frame | Aluminium |
| Fork | RockShox Lyrik Ultimate DB | 29 | 160 | 110x15 | 44OS | Black |
| Shock | RockShox Super Deluxe Ultimate | 185x55 Trunnion |
| Headset | FSA Orbit | 1.5 | Zero Stack (Top ZS44 / Bottom ZS56) |
| Stem | RaceFace Turbine | B:35mm | L:40mm | 0deg |
| Handlebar | RaceFace ERA 35 | B:35mm | R:40mm | W:800mm |
| Grips | Devinci w/lock-on |
| Saddle | SDG BELAIR Max eMTB |
| Seatpost | SDG Tellis 31.6mm (dropper; S 150mm / M 170mm / L 200mm / XL 240mm), SDG Tellis Matchmaker 1x lever |
| Brakes | SRAM Maven Silver (front and rear) |
| Rear derailleur | SRAM GX Eagle AXS | T-Type | 12s |
| Crank | SRAM GX 155mm crankarm | SRAM XX Eagle 34T Bosch eMTB chainring |
| Shifters | SRAM AXS POD | 12s |
| Cassette | SRAM XS1275 | T-Type | 12s | 10-52T |
| Chain | SRAM GX | T-Type | 12s |
| Drivetrain | SRAM GX Eagle AXS | T-Type | 12s; SRAM GX 155mm crankarm | SRAM XX Eagle 34T Bosch eMTB chainring; SRAM AXS POD | 12s; SRAM XS1275 | T-Type | 12s | 10-52T; SRAM GX | T-Type | 12s |
| Wheels | RaceFace ARC30 29 front / RaceFace ARC30 27.5 rear | 30mm inner | TR (RaceFace Vault hubs, Sapim Stainless 14G spokes) |
| Tyres | Front: Maxxis Assegai 29x2.5WT 3C EXO+ TR MaxxGrip / Rear: Maxxis Minion DHR II 27.5x2.5 3C EXO+ TR MaxxTerra |
| Weight | 20.1 kg |
Rides similarly
Spot a mistake?
