Bike Finder · Devinci
Devinci E-Troy Lite
Devinci
E-Troy Lite 2025
CurrentTrail eMTBMature · 5/10iFreshness 5/10
Motor
Bosch Performance Line SX · 55Nm · 600W
Battery
Bosch CompactTube 400 · 400Wh
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
19.5 kg
View the Devinci E-Troy Lite on Devinci’s site
Devinci E-Troy Lite 2025
EMTB Forums verdict
The E-Troy Lite is Devinci's lightweight take on its Troy trail platform, built around the compact Bosch Performance Line SX motor (55 Nm, 600 W peak) and a 400 Wh CompactTube battery. It pairs 160 mm of fork travel with 150 mm out back via the Split Pivot suspension, runs a mixed-wheel setup as standard and is welded from 6061-T6 aluminium in Devinci's own Canadian factory. The geometry is firmly modern-trail: a 63.6 degree head angle across every size, steep effective seat angles around 77.5 to 77.9 degrees, a consistent 438 mm chainstay and a 461 mm reach on the medium.
Three builds make up the 2025 range, all sharing the same frame, motor and battery. The GX 12S (6,399 USD) is the value entry, with a Fox 36 fork, Fox Float X Performance Elite shock, SRAM Code Bronze brakes and a mechanical SRAM GX Eagle drivetrain. The S1000 AXS 12S (6,599 USD) swaps to RockShox Lyrik Select+ and Super Deluxe Ultimate suspension and adds wireless SRAM S1000 Eagle AXS T-Type shifting for only a small premium, which makes it the standout on paper. The GX AXS 12S (7,399 USD) tops the range with a Lyrik Ultimate fork, four-piston Magura MT5 HCW brakes on 203 mm rotors, RaceFace ARC30 wheels and SRAM GX Eagle AXS T-Type, and is also the lightest at a claimed 19.5 kg.
The small SX motor and 400 Wh pack mean this is a light-assist bike rather than a full-power eMTB, so range is modest at a claimed 40 km average, though the optional Bosch PowerMore 250 range extender adds 250 Wh for longer days. Buyers chasing maximum torque or all-day battery will look elsewhere, but for riders who want a Canadian-made alloy trail bike that handles close to its non-assisted sibling, the E-Troy Lite covers the brief.
💬 Forum discussion
Devinci Troy e-lite
64 replies · 12.4k views · last reply 2 months ago
Join the discussion →
“I bought my E-Troy Lite about a month ago and already have over 200 km on it. I got the GX transmission build, and my first upgrade before trying the Magura was to swap them out with Hayes dominion A4, because I did not trust the stock…”
— fredmotokx · ♥ 5 · most-liked post
Bike geometry diagram
SMLXL
Reach441 mm461 mm481 mm501 mm
Stack608 mm617 mm626 mm635 mm
Seattube400 mm420 mm460 mm495 mm
Chainstay438 mm438 mm438 mm438 mm
Headtube Angle63.6°63.6°63.6°63.6°
Seattube Angle (eff)77.9°77.8°77.6°77.5°
Wheelbase1216 mm1240 mm1264 mm1289 mm
Headtube95 mm105 mm115 mm125 mm
BB Height346 mm346 mm346 mm346 mm
Standover740 mm740 mm740 mm740 mm
Front Centre778 mm*802 mm*826 mm*851 mm*
Trims · 3
GX 12S
GX AXS 12S
S1000 AXS 12S
MotorBosch Performance Line SX · 55 Nm · all trims
BatteryBosch CompactTube 400 · 400 Wh · all trims
Travel F/R160/150 mm · all trims
FrameAluminium · all trims
ForkFox 36 PSE | Grip2 | 29 | 160 | 110x15 | 44 OSRockShox Lyrik Ultimate | DB | 29 | 160 | 110x15 | 44 OSRockShox Lyrik Select+ | Charger 3.1 | RC2 | DB | 160 | 44 Offset
ShockFox Float X Performance Elite | 185 x 55 TrunnionRockShox Super Deluxe Ultimate | 185 x 55 TrunnionRockShox Super Deluxe Ultimate | 185 x 55 Trunnion
HeadsetFSA Orbit | 1.5 | Zero Stack · all trims
StemV2 Pro | B:35mm | L:40mm | 0degRaceFace Turbine R35 | B:35mm | L:40mm | 0degV2 Pro | B:35mm | L:40mm | 0deg
HandlebarRaceFace Turbine R35 | B:35mm | R:35mm | W:800mmRaceFace Next R35 | B:35mm | R:20mm | W:800mmRaceFace Turbine R35 | B:35mm | R:35mm | W:800mm
GripsDevinci | w/lock-onDevinci Performance | w/lock-onDevinci | w/lock-on
SaddleSDG BELAIR Max eMTBSDG BELAIR 3.0SDG BELAIR Max eMTB
SeatpostSDG Tellis 31.6mm dropper (S 150 / M 170 / L 200 / XL 200 mm), SDG Tellis Matchmaker 1x leverSDG Tellis 31.6mm dropper (S 150 / M 170 / L 200 / XL 200 mm), SDG Tellis leverSDG Tellis 31.6mm dropper (S 125 / M 150 / L 170 / XL 200 mm), SDG Tellis Matchmaker 1x lever
BrakesSRAM Code Bronze (4-piston)Magura MT5 HCW (4-piston)SRAM Code Bronze (4-piston)
Rear derailleurSRAM GX Eagle | 12sSRAM GX Eagle AXS | T-Type | 12sSRAM S1000 Eagle AXS | T-Type | 12s
CrankSRAM GX Bosch | 165mm, Sram X-Sync Eagle 34T eMTB chainringSRAM X0 Bosch | 165mm, Sram Eagle T-Type 34T eMTB chainringSRAM GX Bosch | 165mm, Sram XX Eagle 34T Bosch eMTB chainring
ShiftersSRAM GX Eagle 12s Single ClickSRAM AXS POD | 12sSRAM AXS POD | 12s
CassetteSRAM PG1230 | 12s | 11-50T | HGSRAM XS1275 T-TYPE | 12s | 10-52TSRAM XS1270 T-TYPE | 12s | 10-52T
ChainSRAM NX Eagle | 12sSRAM GX | T-Type | 12sSRAM
DrivetrainSRAM GX Eagle | 12s; SRAM GX Bosch | 165mm, Sram X-Sync Eagle 34T eMTB chainring; SRAM GX Eagle 12s Single Click; SRAM PG1230 | 12s | 11-50T | HG; SRAM NX Eagle | 12sSRAM GX Eagle AXS | T-Type | 12s; SRAM X0 Bosch | 165mm, Sram Eagle T-Type 34T eMTB chainring; SRAM AXS POD | 12s; SRAM XS1275 T-TYPE | 12s | 10-52T; SRAM GX | T-Type | 12sSRAM S1000 Eagle AXS | T-Type | 12s; SRAM GX Bosch | 165mm, Sram XX Eagle 34T Bosch eMTB chainring; SRAM AXS POD | 12s; SRAM XS1270 T-TYPE | 12s | 10-52T; SRAM
WheelsRaceFace Aeffect R30 (29 front / 27.5 rear) | 30mm innerRaceFace ARC30 (29 front / 27.5 rear) | 30mm inner | TR, RaceFace Vault hubs (6-bolt), Sapim Stainless 14G spokesRaceFace AR30 (29 front / 27.5 rear) | 30mm inner | TR, DT Swiss 370 Classic hubs, Sapim Stainless 14G spokes
TyresMaxxis Assegai 29x2.5WT 3C Exo TR MaxxTerra (front) / Maxxis Minion DHRII 27.5x2.4WT 3C Exo+ TR MaxxTerra (rear)Maxxis Minion DHF 29x2.5WT 3C Exo TR MaxxTerra (front) / Maxxis Dissector 27.5x2.4WT 3C Exo+ TR MaxxTerra (rear)Maxxis Assegai 29x2.5WT 3C Exo+ TR MaxxTerra (front) / Maxxis Minion DHR II 27.5x2.5 3CT EXO+ TR (rear)
Weight20.2 kg19.5 kg
Rides similarly
Spot a mistake?
