Bike Finder · Devinci
Devinci E-Spartan
Devinci
E-Spartan 2027
CurrentFull Power · Enduro
Aluminium 170mm mullet enduro on Bosch's CX Gen 5, a value-focused three-build range
Travel F/R
170/165mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
View the Devinci E-Spartan on Devinci’s site
Devinci E-Spartan 2027
Geometry read
Size
Descending
93
Slack 63.5° head angle, 165mm travel and a long the wheelbase wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
63
Size balance
60
Not enough geometry on record to judge size balance.
Technical climbing
69
Climbs well — a the seat angle seat keeps the front planted. 750W of peak power and 120Nm of torque — among the most powerful e-bike motors made.
How it stacks up vs other Full Power · Enduro bikes (from 160 bikes in the database)
Battery800 Wh75 Wh above average
Motor torque120 Nm17 Nm above average
Frame
Aluminium 6061-T6 Optimum G04 frame, Split-Pivot suspension, 165mm rear travel, mullet 29"/27.5", 438mm chainstay, Bosch PowerTube 800Wh integrated battery, PowerMore 250 range-extender compatible, SRAM UDH hanger
Bike geometry diagram
SMLXL
Reach436 mm456 mm478 mm500 mm
Chainstay438 mm438 mm438 mm438 mm
Headtube Angle63.5°63.5°63.5°63.5°
Trims · 3
Deore 12s
Eagle 90 12s
GX AXS 12s
MotorBosch Performance Line CX Gen 5 · 120 Nm · all trims
BatteryBosch PowerTube 800Wh · 800 Wh · all trims
Travel F/R170/165 mm · all trims
FrameAluminium 6061-T6 · all trims
ForkRockShox Zeb, Delta RC, 170mm, 44 offsetRockShox Zeb Select+, Charger 3.1 RC2, 170mm, 44 offsetRockShox Zeb Ultimate DB, 170mm, 29"
ShockRockShox Super Deluxe Select, 205x65mmRockShox Vivid Select+, 205x65mmRockShox Vivid Ultimate, 205x65mm
BrakesSRAM DB8, SRAM Centerline 200mm rotorsSRAM Maven Bronze, 4-piston, 200mm rotorsSRAM Maven Silver, 4-piston
Rear derailleurShimano Deore M6200, 12-speedSRAM Eagle 90 T-Type, 12-speed (mechanical)SRAM GX Eagle AXS T-Type, 12-speed (AXS POD shifter)
CrankRaceFace Aeffect R, 160mm, 34TSRAM Eagle 90 Bosch, 155mm, 34TSRAM GX Bosch, 155mm, 34T
CassetteShimano Deore, 10-51T MicrosplineSRAM XS-1270 T-Type, 10-52TSRAM XS-1275 T-Type, 10-52T
DrivetrainShimano Deore M6200 1x12, 10-51T MicrosplineSRAM Eagle 90 T-Type 1x12 mechanical, 10-52TSRAM GX Eagle AXS T-Type 1x12 electronic, 10-52T
Rides similarly
Spot a mistake?
