E-Spartan Lite 2026
Light-assist Bosch SX aluminium enduro eMTB
The Devinci E-Spartan Lite 2026 is Devinci's first e-enduro and a Canadian-built aluminium platform aimed at the lightweight, big-travel category. Headline numbers: 170mm fork, 165mm rear, Bosch Performance Line SX with 55Nm and a 600W peak from a 2.0kg motor, an integrated 400Wh battery, 63.5 degree head angle and reach 460 to 500mm across M, L and XL. The community read so far is light: this is a new launch and the forum signal is thin, but press testing and Devinci's own data position it as a serious heavy-hitting Bosch SX rig that hides its weight under genuinely lively manners.
Drive system and range. The Bosch Performance Line SX is the lightest of Bosch's drive units, sitting alongside the TQ HPR50 and Fazua 60 in the SL category but with a 600W peak that's punchier than either on short, steep ramps. The CompactTube 400Wh battery is integrated into the downtube. Devinci's own published numbers point to roughly two hours of riding, 1,000m of vertical and 40km of mixed terrain on a single charge in mid-modes, stretching to 67km if you discipline yourself to eco. A range extender is supported but not in the gold spec listed here. The Bosch ecosystem brings Flow app integration, OTA firmware and the well-proven CX/SX over-the-air update path.
Geometry and handling. 63.5 degrees up front is properly slack, a meaningful concession to the enduro brief and only half a degree off the equivalent analogue Spartan. Reach steps are honest: 460 (M), 480 (L), 500 (XL). Chainstays are a uniform 436mm, short for a 170/165mm bike, which keeps cornering quick despite the long wheelbase that tops out at 1294mm on XL. The package is biased to fast steep descents while keeping the back end snappy. Devinci is small-rider friendly here too: the M reach of 460mm is genuinely usable for riders down to 5'7.
Build and value. One frame, a single base trim listed in the gold spec at this stage. Devinci's wider catalogue confirms a GX AXS T-Type build that pairs SRAM Maven brakes with the Bosch SX system: Maven on a sub-50lb (21.5kg-class) eMTB is rare at this segment, and a clear value play. The 6061-T6 Optimum G04 aluminium frame is made in Canada, which is one of the few remaining western-hemisphere aluminium frame production stories in 2026. Wheels are 29in front and rear in the press tested build.
Caveats and known gripes.
- Bosch SX is not Bosch CX. 55Nm and 600W will feel light to riders moving across from a full-power Levo or Rail. Designed-in trade for system weight.
- 400Wh, not 800Wh. Big alpine days will need disciplined mode use, a range extender, or a recharge stop.
- Aluminium only. No carbon option from launch.
- Three sizes. No XS or S, and no XXL: riders outside roughly 5'7 to 6'4 should fit-check carefully.
- Battery removability not confirmed in gold spec. Most Bosch SX implementations on integrated downtube frames require the motor to be dropped for battery removal, which favours charge-in-frame ownership.
- New platform, limited owner-reliability data. Forum signal as of mid-2026 is sparse. Long-term motor and frame durability will take a season of riding to confirm.
Verdict. The E-Spartan Lite is Devinci's confident first stab at the lightweight enduro category, with proper 170/165mm travel, a 63.5 degree head angle, modern reach and the Bosch SX ecosystem. It suits riders who want a Canadian-built aluminium platform with genuine enduro geometry and the lighter system weight that the SX brings versus full-power Bosch CX. Riders chasing the most powerful motor, the longest range, or a carbon frame should look at the regular Spartan analogue with the option of full-power Bosch CX elsewhere. Production status: current.
| M | L | XL | |
| Toptube | 594 mm | 618 mm | 641 mm |
| Reach | 460 mm | 480 mm | 500 mm |
| Stack | 618 mm | 627 mm | 636 mm |
| Seattube | 420 mm | 460 mm | 495 mm |
| Chainstay | 436 mm | 436 mm | 436 mm |
| Headtube Angle | 63.5° | 63.5° | 63.5° |
| Seattube Angle (eff) | 77.7° | 77.5° | 77.4° |
| Wheelbase | 1245 mm | 1269 mm | 1294 mm |
| Headtube | 105 mm | 115 mm | 125 mm |
| BB Height | 355 mm | 355 mm | 355 mm |
| Front Centre | 809 mm | 833 mm | 858 mm |
Trims · 2
Eagle 90 £4,756 | GX AXS £5,800 | |
| Motor | Bosch Performance Line SX · 60 Nm · all trims | |
| Battery | 400 Wh · all trims | |
| Travel F/R | 170/165 mm · all trims | |
| Frame | Aluminium 6061-T6 · all trims | |
| Fork | RockShox Zeb Select 29 | DB | 170mm | 15x110 | 44 Offset | RockShox Zeb Ultimate DB | 29 | 170mm | 110x15 | 44 Offset |
| Shock | RockShox Vivid Select+ | 205x65T | RockShox Vivid Ultimate | 205x65T |
| Headset | FSA Orbit, 1.5 Zero Stack · all trims | |
| Stem | V2 Pro | B:35mm | L:40mm | 0° | RaceFace Turbine | B:35mm | L:40mm | 0° |
| Handlebar | V2 Pro | B:35mm | R:30mm | W:800mm | RaceFace ERA 35 | B:35mm | R:40mm | W:800mm |
| Grips | Devinci, w/lock-on · all trims | |
| Saddle | SDG BELAIR Max eMTB · all trims | |
| Seatpost | TranzX Dropper | 31.6mm | SDG Tellis 31.6mm |
| Brakes | SRAM Maven Bronze | SRAM Maven Silver |
| Rear derailleur | SRAM Eagle 90 | 12s | SRAM GX Eagle AXS | T-Type | 12s |
| Crank | SRAM Eagle 90 Bosch | 155mm | SRAM GX Bosch | 155mm |
| Shifters | SRAM Eagle 90 | 12s | SRAM AXS POD | 12s |
| Cassette | SRAM XS1270 T-TYPE | 12s | 10-52T | SRAM XS1275 T-TYPE | 12s | 10-52T |
| Chain | SRAM Eagle 70 | SRAM GX T-Type 12s |
| Drivetrain | SRAM Eagle 90 12-speed | SRAM GX Eagle AXS T-Type 12-speed |
| Wheels | RaceFace Aeffect R30, 30mm inner (front 29 Boost110x15 / rear 27.5 B148x12 HG EMTB) | RaceFace ARC30 30mm inner TR rims on RaceFace Vault hubs (front 29 / rear 27.5) |
| Tyres | Maxxis Assegai 29x2.5 3C DD TR MaxxGrip (front) / Maxxis Minion DHR II 27.5x2.5 3C DD TR MaxxTerra (rear) · all trims | |
| Weight | 21.65 kg | 21.45 kg |
| Price | £4,756 | £5,800 |
Rides similarly
Spot a mistake?
