Bike Finder · Cube
Cube Stereo Hybrid One44
Cube
Stereo Hybrid One44 2025
CurrentTrail eMTBAgeing · 4.6/10iFreshness 4.6/10
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Weight
23.9 kg
Price
From £3,499
View the Cube Stereo Hybrid One44 on Cube’s site
Cube Stereo Hybrid One44 2025
From £3,499
EMTB Forums verdict
The Stereo Hybrid One44 is Cube's mainstream trail eMTB for 2025, built around 140mm of FSP 4-Link rear travel, a 150mm fork, the Bosch Performance Line CX motor and a fully integrated 800Wh PowerTube battery. It uses Cube's Size Split approach, so the small frame rolls on 27.5in wheels while medium to extra-large get 29in, and an angle-adjustable headset gives roughly a 0.6 degree swing between slack (64.8 degrees) and moderate (65.4 degrees) head angles. Chainstays grow from 450mm on the small to 457mm on the larger sizes, pointing the bike towards stable, comfortable trail and touring use rather than playful enduro riding.
The range splits into a carbon HPC line and an alloy HPA line. At the top, the SLT (7499 GBP) gets Fox Factory suspension, SRAM XX Transmission and Magura Gustav Pro brakes, while the AT (6499 GBP) pairs Fox Factory parts with SRAM X0 AXS Transmission. The TM (5499 GBP) and SLX (4499 GBP) bring the carbon frame within easier reach, and the Race (3999 GBP) is the carbon entry point on a Fox 36 AWL fork and Magura MT Thirty brakes. The alloy EXC (3999 GBP) matches the carbon Race on price while running a Fox fork and Shimano XT, which makes it one of the more interesting value picks. Below it sit the EX (3899 GBP) on RockShox suspension and the Pro (3499 GBP) on SR Suntour with a Shimano Cues 1x11 drivetrain and a 140mm fork.
All trims share the same Bosch drive package, so the choice is really about frame material, suspension grade and drivetrain rather than power or range. Buyers chasing carbon on a budget should weigh the Race against the cheaper alloy EXC, which offers a comparable component level. Note that the 2025 model uses the Bosch CX BDU38 unit published at 85Nm for MY25; Cube's current pages display it as up to 120Nm following the later Bosch firmware update on the same hardware.
💬 Forum discussion
2025 Cube Stereo Hybrid One44 HPC Race 800 or One44 HPC SLX 800 dilema.
21 replies · 27.4k views · last reply 17 months ago
Join the discussion →
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm510 mm
Stack606 mm622 mm634 mm660 mm
Seattube370 mm405 mm420 mm480 mm
Chainstay450 mm457 mm457 mm457 mm
Headtube Angle65.4°65.4°65.4°65.4°
Seattube Angle (eff)76°76°76°76°
Wheelbase1196 mm1226 mm1256 mm1303 mm
Headtube128 mm106 mm120 mm148 mm
Front Centre746 mm*769 mm*799 mm*846 mm*
Trims · 8
Pro
£3,499
EX
£3,899
EXC
£3,999
Race
£3,999
SLX
£4,499
TM
£5,499
AT
£6,499
SLT
£7,499
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 800 · 800 Wh · all trims
Travel F/R150/140 mm · all trims
FrameAluminiumAluminiumAluminiumCarbonCarbonCarbonCarbonCarbon
ForkSR Suntour XCR34 2CR Air, Tapered, 15x110mm, 140mmRockShox Psylo Silver, Air, 150mmFox 36 Float AWL, 150mmFox 36 Float AWL, RAIL Damper, Tapered, 15x110mm, E-Bike Optimized, 150mmFox Float 36 Rhythm Grip, Tapered, 15x110mm, E-Bike Optimized, 150mmFox 36 Float GRIP, 3-Position w/Micro Adjust, Tapered, 15x110mm, E-Bike Optimized, 150mmFox 36 Float Factory GRIPX, 2-Position w/High/Low Speed Compression Adjust, Tapered, 15x110mm, E-Bike Optimized, 150mm, Kashima CoatedFox 36 Float Factory GRIPX2, Tapered, 15x110mm, E-Bike Optimized, 150mm, Kashima Coated
ShockSR Suntour EdgeX R 205x60mm (27.5: 185x55mm), Rebound Adjust, Trunnion MountRockShox Deluxe Select, 230x60mm (27.5: 210x55mm)Fox Float Rhythm RC, 230x60mm (27.5: 210x55mm)Fox Float Rhythm R, 230x60mm (27.5: 210x55mm), Rebound AdjustFox Float Performance, 230x60mm (27.5: 210x55mm)Fox Float X Performance, 230x60mm (27.5: 210x55mm), Adjustable LSR w/ 2-Pos. LeverFox Float X Factory, 230x60mm (27.5: 210x55mm), Adjustable LSC w/ 2-Pos. Lever, Kashima CoatedFox Float X Factory, 230x60mm (27.5: 210x55mm), Kashima Coated
HeadsetACROS AZF-1034, ICRACROS, ICRACROS AZF-1034, ICRACROS AZF-675, ICR, Fiber Inserts for Angle AdjustmentACROS AZF-675, ICR, Fiber Inserts for Angle AdjustmentACROS AZF-675, ICR, Fiber Inserts for Angle Adjustment, X-Connect InterfaceACROS AZF-675, ICR, Fiber Inserts for Angle Adjustment, X-Connect InterfaceACROS AZF-675, ICR, Fiber Inserts for Angle Adjustment, X-Connect Interface
StemCUBE Performance Stem E-MTB 35, FPI-Link · all trims
HandlebarCUBE Rise Trail Bar 35CUBE Rise Trail Bar 35CUBE Rise Trail Bar 35CUBE Rise Trail Bar 35CUBE Rise Trail Bar 35CUBE Rise Trail Bar 35Race Face ERA 35Race Face Era 35
GripsACID Hybrid PerformACID Hybrid PerformACID Hybrid PerformACID DisruptACID DisruptACID DisruptACID DisruptACID Disrupt
SaddleACID Venec LiteACID Venec LiteACID Venec LiteACID Venec EMTB Trail 140ACID Venec EMTB Trail 140ACID Venec EMTB Trail 140ACID Venec EMTB Trail 140ACID Venec EMTB Trail 140
SeatpostCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post (remote)CUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmFox Transfer Factory 31.6mm, Kashima CoatedDropper post (remote)
BrakesMagura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc Brake (203/203)Shimano, Hydr. Disc Brake (203/203)Shimano XT, Hydr. Disc Brake (203/203)Magura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc Brake (203/203)Shimano XT, 4-Piston, Hydr. Disc Brake (203/203)Magura MT7, Hydr. Disc Brake (203/203)Shimano XT BR-M8120, Hydr. Disc Brake (203/203)Magura Gustav Pro, Hydr. Disc Brake (203/203)
Rear derailleurShimano Cues RD-U6000-GS, 11-SpeedShimano XT, 12-Speed, 1x12Shimano XT, 12-Speed, 1x12Shimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT, 12-Speed, 1x12Sram GX Eagle AXS Transmission, 12-Speed, Electronic Shifting SystemSram X0 Eagle AXS Transmission, 12-Speed, Electronic Shifting SystemSram XX Eagle AXS Transmission, 12-Speed, Electronic Shifting System
CrankACID MTB Hybrid Pro, 27.5: 36T // 29: 34TACID MTB Hybrid Pro, 27.5: 36T // 29: 34TACID MTB Hybrid Pro, 27.5: 36T // 29: 34TACID MTB Hybrid Pro, 27.5: 36T // 29: 34TACID MTB Hybrid Pro, 27.5: 36T // 29: 34TACID MTB Hybrid Pro, 27.5: 36T // 29: 34TACID MTB Hybrid Pro, 27.5: 36T // 29: 34TRace Face Era Carbon, 27.5: 36T // 29: 34T
ShiftersShimano Cues SL-U6000, Rapidfire PlusShimano XTShimano XTShimano Deore SL-M6100, Rapidfire-PlusShimano XTSram AXS Pod ControllerSram AXS Pod ControllerSram AXS Pod Controller
CassetteShimano Cues CS-LG400, 11-50TShimano XT 10-51TShimano XT 10-51TShimano Deore CS-M6100, 10-51TShimano XT 10-51TSram XS-1275, 10-52TSram XS-1275, 10-52TSram XS-1275, 10-52T
ChainKMC eGlideKMC e12Sram GX Eagle TransmissionSram GX Eagle TransmissionSram XX Eagle Transmission
DrivetrainShimano Cues RD-U6000-GS, 11-Speed; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Shimano Cues SL-U6000, Rapidfire Plus; Shimano Cues CS-LG400, 11-50T; KMC eGlideShimano XT, 12-Speed, 1x12; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Shimano XT; Shimano XT 10-51TShimano XT, 12-Speed, 1x12; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Shimano XT; Shimano XT 10-51TShimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Shimano Deore SL-M6100, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; KMC e12Shimano XT, 12-Speed, 1x12; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Shimano XT; Shimano XT 10-51TSram GX Eagle AXS Transmission, 12-Speed, Electronic Shifting System; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Sram AXS Pod Controller; Sram XS-1275, 10-52T; Sram GX Eagle TransmissionSram X0 Eagle AXS Transmission, 12-Speed, Electronic Shifting System; ACID MTB Hybrid Pro, 27.5: 36T // 29: 34T; Sram AXS Pod Controller; Sram XS-1275, 10-52T; Sram GX Eagle TransmissionSram XX Eagle AXS Transmission, 12-Speed, Electronic Shifting System; Race Face Era Carbon, 27.5: 36T // 29: 34T; Sram AXS Pod Controller; Sram XS-1275, 10-52T; Sram XX Eagle Transmission
WheelsCUBE EX30, 32H, Disc, Tubeless Ready (CUBE Engineered By Newmen hubs)CUBE EX30, 32H, Disc, Tubeless ReadyCUBE EX30, 32H, Disc, Tubeless ReadyCUBE EX30, 32H, Disc, Tubeless Ready (CUBE Engineered By Newmen hubs)Newmen Performance 30, Tubeless ReadyNewmen Beskar 30 base/strong, 28/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Beskar 30 base/strong, 28/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Phase 30
TyresSchwalbe Nobby Nic, Performance, 2.6Schwalbe Nobby Nic, Performance, 2.6Schwalbe Nobby Nic, Performance, 2.6Schwalbe Hans Dampf, Addix Soft, Super Trail, Tubeless Easy, 2.6 (front); Schwalbe Hans Dampf, Addix Speedgrip, Super Trail, Tubeless Easy, 2.6 (rear)Schwalbe 2.6 (front and rear)Schwalbe Magic Mary, Addix Soft, Super Trail, Kevlar, 2.4 (front); Schwalbe Big Betty, Addix Soft, Super Gravity, Kevlar, 2.4 (rear)Schwalbe Magic Mary, Addix Soft, Super Trail, Kevlar, 2.4 (front); Schwalbe Big Betty, Addix Soft, Super Gravity, Kevlar, 2.4 (rear)Schwalbe Magic Mary 2.4 (front), Schwalbe Nobby Nic 2.4 (rear)
Weight26.4 kg24.4 kg24.1 kg23.9 kg
Price£3,499£3,899£3,999£3,999£4,499£5,499£6,499£7,499
Rides similarly
Spot a mistake?
