Bike Finder · Cube
Cube Stereo Hybrid ONE22
Cube
Stereo Hybrid ONE22 2025
CurrentTrail eMTBMature · 6.9/10iFreshness 6.9/10
Travel F/R
120/120mm
Wheels
29F / 29R
Frame
Aluminium
Weight
26.6 kg
Price
From £3,499
View the Cube Stereo Hybrid ONE22 on Cube’s site
Cube Stereo Hybrid ONE22 2025
From £3,499
EMTB Forums verdict
The Stereo Hybrid One22 is Cube's aluminium full-power trail all-rounder, built around 120mm of FSP 4-Link rear travel, a 120mm fork (130mm on the flagship SLT) and the Bosch Performance Line CX motor rated at 120Nm in its MY2025 Smart System form. Every listed build runs the 800Wh Bosch PowerTube as standard, and Cube also sells a separate Pro 600 with a lighter 600Wh pack, so range is generous across the board. Geometry is deliberately moderate: a 66.5 degree head angle, 76 degree effective seat angle and reach figures from 417mm (S) to 496mm (XL), with Cube's Size Split fitting 27.5in wheels to the S and 29in to M, L and XL.
The range ladders cleanly. The Pro at GBP 3,499 keeps costs down with a Suntour XCR34 fork, Shimano Cues 1x10 gearing and MT420 brakes. Stepping up to the Race (GBP 3,799) brings a RockShox Psylo fork and Deluxe Select shock plus an XT 12-speed rear mech. The SLX (GBP 4,099) is the value sweet spot for keen trail riders, pairing a Fox 34 Float fork and Rhythm shock with four-piston Shimano XT brakes. At the top, the SLT (GBP 4,999) adds a 130mm Fox 36, electronic XT Di2 shifting, Bosch ABS Pro front braking and a Newmen wheelset. The FE variants mirror their siblings but add mudguards, lights, a kickstand and a luggage carrier for GBP 200 more.
Component choices reflect the comfort-and-capability brief rather than outright aggression: 2.6in Schwalbe tyres, a 38T crank, integrated cable routing, a UDH dropout and CUBE dropper posts across the line. Claimed weights cluster tightly around 26.6 to 26.8kg. This is a do-it-all trail platform aimed at riders who want big-battery range and dependable kit over the lowest, slackest numbers.
💬 Forum discussion
Cube Hybrid EMTB 2025 looks lit!
393 replies · 85.1k views · last reply 2 days ago
Join the discussion →
“Well, she’s finally arrived! The colour is absolutely stunning the way it flips. I’m hoping I don’t have to change the lovely ERA cranks for shorter ones, but I’ll soon find out on its first ride Sunday. Bit concerned how it’ll throw…”
— Eyuplad · ♥ 12 · most-liked post
Bike geometry diagram
SMLXL
Reach417 mm444 mm471 mm496 mm
Stack638 mm647 mm656 mm670 mm
Seattube370 mm405 mm420 mm480 mm
Chainstay454 mm487.5 mm487.5 mm487.5 mm
Headtube Angle66.5°66.5°66.5°66.5°
Seattube Angle (eff)76°76°76°76°
Wheelbase1186 mm1240 mm1271 mm1302 mm
Headtube163 mm132 mm142 mm157 mm
Front Centre732 mm*752.5 mm*783.5 mm*814.5 mm*
Trims · 7
PRO
£3,499
PRO FE
£3,699
RACE
£3,799
RACE FE
£3,999
SLX
£4,099
SLX FE
£4,299
SLT
£4,999
MotorBosch Performance Line CX Gen 5 · 120 Nm · all trims
BatteryBosch PowerTube 800 · 800 Wh · all trims
Travel F/R120/120 mm · all trims
FrameAluminium · all trims
ForkSR Suntour XCR34X 2CR Air, Tapered, 15x110mm, 120mmSR Suntour XCR34X 2CR Air, Tapered, 15x110mm, 120mmRockShox Psylo Silver RC Air, Tapered, 15x110mm, 120mmRockShox Psylo Silver RC Air, Tapered, 15x110mm, 120mmFox 34 Float AWL RAIL 2.0, Tapered, 15x110mm, E-Bike Optimized, 120mmFox 34 Float AWL RAIL 2.0, Tapered, 15x110mm, E-Bike Optimized, 120mmFox 36 Float Rhythm GRIP, Tapered, 15x110mm, E-Bike Optimized, 130mm
ShockSR Suntour EdgeX R, 185x52.5mm, Rebound Adjust, Trunnion MountSR Suntour EdgeX R, 185x52.5mm, Rebound Adjust, Trunnion MountRockShox Deluxe Select R, 185x52.5mm, Rebound Adjust, Trunnion MountRockShox Deluxe Select R, 185x52.5mm, Rebound Adjust, Trunnion MountFox Float Rhythm RC, 185x52.5mm, Adjustable LSR w/ 2-Pos. Lever, Trunnion MountFox Float Rhythm RC, 185x52.5mm, Adjustable LSR w/ 2-Pos. Lever, Trunnion MountFox Float Performance, 185x52.5mm, Open/Firm Mode, Trunnion Mount
HeadsetACROS AZF-1034, ICR, Top ZS 56mm / Bottom ZS 56mm, X-Connect Interface · all trims
StemCUBE Performance Stem E-MTB 35, FPI-Link · all trims
HandlebarCUBE Rise Trail Bar 35 · all trims
GripsACID Hybrid Perform · all trims
SaddleACID Venec EMTB Plus 145 · all trims
SeatpostCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm · all trims
BrakesShimano BR-MT420, Hydr. Disc Brake (203/203)Shimano BR-MT420, Hydr. Disc Brake (203/203)Shimano BR-MT520, Hydr. Disc Brake (203/203)Shimano BR-MT520, Hydr. Disc Brake (203/203)Shimano XT BR-M8120, Hydr. Disc Brake (203/203)Shimano XT BR-M8120, Hydr. Disc Brake (203/203)Shimano XT BR-M8220, Hydr. Disc Brake w/ Front ABS (203/203); Bosch ABS Pro
Rear derailleurShimano Cues RD-U6000-GS, 10-SpeedShimano Cues RD-U6000-GS, 10-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT Di2 RD-M8260-SGS, 12-Speed, Electronic Shifting System
CrankACID MTB Hybrid Pro, 38T · all trims
ShiftersShimano Cues SL-U6000, Rapidfire-PlusShimano Cues SL-U6000, Rapidfire-PlusShimano Deore SL-M6100-R, Rapidfire PlusShimano Deore SL-M6100-R, Rapidfire PlusShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusShimano XT Di2 SW-M8250-IR, Direct Attach
CassetteShimano Cues CS-LG300, 11-48TShimano Cues CS-LG300, 11-48TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51TShimano XT CS-M8100, 10-51T
ChainKMC eGlideKMC eGlideKMC e12KMC e12KMC e12KMC e12Shimano CN-M6100
DrivetrainShimano Cues RD-U6000-GS, 10-Speed; ACID MTB Hybrid Pro, 38T; Shimano Cues SL-U6000, Rapidfire-Plus; Shimano Cues CS-LG300, 11-48T; KMC eGlideShimano Cues RD-U6000-GS, 10-Speed; ACID MTB Hybrid Pro, 38T; Shimano Cues SL-U6000, Rapidfire-Plus; Shimano Cues CS-LG300, 11-48T; KMC eGlideShimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID MTB Hybrid Pro, 38T; Shimano Deore SL-M6100-R, Rapidfire Plus; Shimano Deore CS-M6100, 10-51T; KMC e12Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID MTB Hybrid Pro, 38T; Shimano Deore SL-M6100-R, Rapidfire Plus; Shimano Deore CS-M6100, 10-51T; KMC e12Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID MTB Hybrid Pro, 38T; Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; KMC e12Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID MTB Hybrid Pro, 38T; Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; KMC e12Shimano XT Di2 RD-M8260-SGS, 12-Speed, Electronic Shifting System; ACID MTB Hybrid Pro, 38T; Shimano XT Di2 SW-M8250-IR, Direct Attach; Shimano XT CS-M8100, 10-51T; Shimano CN-M6100
WheelsACID PRO 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID PRO 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID SLX 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID SLX 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID SLX 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID SLX 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Performance 30 base/strong, 28/32 Spokes, 15x110mm / 12x148mm, Tubeless Ready
TyresSchwalbe Smart Sam, Active, 2.6Schwalbe Smart Sam, Active, 2.6Schwalbe Smart Sam, Active, 2.6Schwalbe Smart Sam, Active, 2.6Schwalbe Smart Sam, Performance, 2.6Schwalbe Smart Sam, Performance, 2.6Schwalbe Johnny Watts 365, Performance, Kevlar, 2.6
Weight26.8 kg26.8 kg26.7 kg26.7 kg26.6 kg26.6 kg26.7 kg
Price£3,499£3,699£3,799£3,999£4,099£4,299£4,999
Rides similarly
Spot a mistake?
