Bike Finder · Cube
Cube Stereo Hybrid 140 HPC
Cube
Stereo Hybrid 140 HPC 2023
DiscontinuedFull Power · TrailLegacy · 1/10iFreshness 1/10
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Carbon front, aluminium rear
Weight
23.8 kg
Price
From £3,499
View the Cube Stereo Hybrid 140 HPC on Cube’s site
Cube Stereo Hybrid 140 HPC 2023
From £3,499
EMTB Forums verdict
The 2023 Cube Stereo Hybrid 140 HPC is a discontinued all-mountain eMTB built on a C:62 carbon front triangle with an alloy rear end and Cube's FSP 4-Link suspension running 150mm front / 140mm rear. Every trim uses the same Bosch Performance Line CX Gen 4 motor (85Nm, Smart System) fed by an integrated PowerTube battery: 750Wh on most builds, 625Wh on the entry Pro 625 and Race 625. Smaller frames (SM) run a mullet 29in front / 27.5in rear wheel pairing, while M, L and XL are full 29er, with a slack 66 degree head angle across all sizes.
The range is broad. Entry Pro 625/750 builds pair RockShox Recon forks with Shimano Deore 11-speed; the Race 625/750 step up to RockShox 35 Silver, SRAM DB8 brakes and a Shimano XT mech. Mid-range SLX 750 (£4,499) brings Fox 34 Rhythm and a full Shimano XT brakeset. The ABS 750 (£4,799) adds Bosch eBike ABS with Magura MT C ABS brakes. The TM 750 (£4,999) is the aggressive build with a Fox 36 fork, Float X shock, SRAM GX and Maxxis Assegai/Minion DHR II rubber, while the flagship SLT 750 (£6,999) and 29-only SLT 750 29 (£8,399) go Fox Factory Kashima, SRAM XX1 Eagle AXS wireless and carbon Newmen wheels.
Geometry is moderate by current standards (66 degree head angle, 447mm reach in M, 1,221mm wheelbase) reflecting Cube's Agile Trail brief rather than an outright enduro stance. This model has since been discontinued and replaced in Cube's lineup. No verified owner or long-term reliability data is included here, so treat ride-feel impressions from elsewhere with appropriate caution.
Geometry read
Size
Wheels
Descending
60
A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
58
Size balance
91
Rear-long with a planted front in L (FC:RC 1.74) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
76
Bosch Performance Line CX Gen 4 and a steep 75.5° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Trail bikes (from 246 bikes in the database)
Weight23.8 kg0.8 kg heavier than average
Battery750 Whabout average capacity
Motor torque85 Nm13 Nm below average
Value for money91/100from £3,499 · most Bosch Performance Line CX Gen 4 bikes ~£4,799
💬 Forum discussion
16 replies · 11.3k views · last reply 90 months ago
Join the discussion →
“Bit overdue, but here is a pic of Lucy. Was a nutty day, very very wet and slippery..”
— Gofurtherfaster · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach426 mm447 mm473 mm497 mm
Stack607 mm626 mm637 mm653 mm
Seattube370 mm420 mm460 mm490 mm
Chainstay450 mm457 mm457 mm457 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)76°75.5°75.5°75.5°
Wheelbase1187 mm1221 mm1252 mm1283 mm
Headtube120 mm108 mm120 mm138 mm
BB Height339 mm338 mm338 mm338 mm
Front Centre737 mm*764 mm*795 mm*826 mm*
FC:RC1.641.671.741.81
Trims · 9
Pro 625
£3,499
Pro 750
£3,699
Race 625
£3,699
Race 750
£3,899
SLX 750
£4,499
ABS 750
£4,799
TM 750
£4,999
SLT 750
£6,999
SLT 750 29
£8,399
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R150/140 mm · all trims
FrameCarbon (C:62 front triangle, Aluminium 6061 T6 rear triangle) · all trims
ForkRockShox Recon Silver RL Air, Tapered, 15x110mm, eMTB Approved, 150mm, LockoutRockShox Recon Silver RL Air, Tapered, 15x110mm, eMTB Approved, 150mm, LockoutRockShox 35 Silver TK Air, Tapered, 15x110mm, eMTB Approved, 150mm, LockoutRockShox 35 Silver TK Air, Tapered, 15x110mm, eMTB Approved, 150mm, LockoutFox 34 Float Rhythm, 2-Position Sweep-Adjust GRIP Damper, Tapered, 15x110mm, E-Bike Tune, 150mmFox 34 Rhythm, 2-Position Sweep-Adjust GRIP Damper, Tapered, 15x110mm, E-Bike Optimized, 150mmFox 36 Float Performance GRIP, 3-Position w/Micro Adjust, Tapered, 15x110mm, E-Bike Optimized, 150mmFox 36 Float Factory FIT GRIP2, Tapered, 15x110mm, E-Bike Optimized, 150mm, Kashima CoatedFox 36 Float Factory FIT GRIP2, Tapered, 15x110mm, E-Bike Tune, 150mm, Kashima Coated
ShockRockShox Deluxe Select, 205x60mm (27.5: 185x55mm), Rebound Adjust, Trunnion MountRockShox Deluxe Select, 205x60mm (27.5: 185x55mm), Rebound Adjust, Trunnion MountRockShox Deluxe Select+, 205x60mm (27.5: 185x55mm), Rebound Adjust, Trunnion Mount, LockoutRockShox Deluxe Select+, 205x60mm (27.5: 185x55mm), Rebound Adjust, Trunnion Mount, LockoutFox Float DPS EVOL, 205x60mm (27.5: 185x55mm), Open/Medium/Firm Mode, Trunnion MountFox Float DPS EVOL, 205x60mm (27.5: 185x55mm), Open/Medium/Firm Mode, Trunnion MountFox Float X Performance, 205x60mm (27.5: 185x55mm), Trunnion Mount, Adjustable LSR w/ 2-Pos. LeverFox Float X Factory, 205x60mm (27.5: 185x55mm), Adjustable LSC w/ 2-Pos. Lever, Trunnion Mount, Kashima CoatedFox Float X Factory, 205x60mm, Trunnion Mount, Adjustable LSC w/ 2-Pos. Lever, Kashima Coated
HeadsetACROS AZF-1035, ICR (Integrated Cable Routing), BlockLock 120 deg, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) · all trims
StemCUBE Performance Stem E-MTB, 31.8mm · all trims
HandlebarNewmen Evolution SL 318.25, 760mmNewmen Evolution SL 318.25, 760mmNewmen Evolution SL 318.25, 760mmNewmen Evolution SL 318.25, 760mmNewmen Evolution SL 318.25, 780mmNewmen Evolution SL 318.25, 780mmNewmen Evolution SL 318.25, 800mmNewmen Advanced 318.25, Carbon, 780mmNewmen Advanced 318.25, Carbon, 780mm
GripsACID React ProACID React ProACID React ProACID React ProACID Disrupt, Soft CompoundACID Disrupt, Soft CompoundACID Disrupt, Soft CompoundACID Disrupt, Soft CompoundACID Disrupt, Soft Compound
SaddleNatural Fit Venec · all trims
SeatpostCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmFox Transfer Factory 31.6mm, Kashima CoatedFox Transfer Factory 31.6mm, Kashima Coated (M,L: 150mm, XL: 175mm)
BrakesMagura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc BrakeMagura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc BrakeSRAM DB8, Hydr. Disc BrakeSRAM DB8, Hydr. Disc BrakeShimano XT BR-M8120, Hydr. Disc BrakeMagura MT C ABS, Hydr. Disc Brake (Bosch eBike ABS)Magura MT7, Hydr. Disc BrakeMagura MT7, Hydr. Disc BrakeMagura MT7, Hydr. Disc Brake
Rear derailleurShimano Deore RD-M5100-SGS, 11-SpeedShimano Deore RD-M5100-SGS, 11-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedSRAM GX Eagle, 12-SpeedSRAM XX1 Eagle AXS, 12-SpeedSRAM XX1 Eagle AXS, 12-Speed
CrankACID E-Crank, 165mm (27.5: 36T // 29: 34T)ACID E-Crank, 165mm (27.5: 36T // 29: 34T)ACID E-Crank, 165mm (27.5: 36T // 29: 34T)ACID E-Crank, 165mm (27.5: 36T // 29: 34T)ACID E-Crank, 165mm (27.5: 36T // 29: 34T)ACID E-Crank, 165mm (27.5: 36T // 29: 34T)ACID E-Crank, 165mm (27.5: 36T // 29: 34T)e*thirteen Plus Crank, 165mm (27.5: 36T // 29: 34T)e*thirteen Plus Crank, 165mm, 34T
ShiftersShimano Deore SL-M5100, Rapidfire-PlusShimano Deore SL-M5100, Rapidfire-PlusShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusSRAM GX Eagle Trigger, Single ClickSRAM Eagle AXS ControllerSRAM Eagle AXS Controller
CassetteShimano Deore CS-M5100, 11-51TShimano Deore CS-M5100, 11-51TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51TSRAM XG-1275 Eagle, 10-52TSRAM XG-1299 Eagle Rainbow, 10-52TSRAM XG-1299 Eagle Rainbow, 10-52T
ChainKMC X11KMC X11Shimano CN-M6100Shimano CN-M6100Shimano CN-M6100Shimano CN-M6100SRAM NX EagleSRAM PC-XX1 Eagle RainbowSRAM PC-XX1 Eagle Rainbow
DrivetrainShimano Deore RD-M5100-SGS, 11-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); Shimano Deore SL-M5100, Rapidfire-Plus; Shimano Deore CS-M5100, 11-51T; KMC X11Shimano Deore RD-M5100-SGS, 11-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); Shimano Deore SL-M5100, Rapidfire-Plus; Shimano Deore CS-M5100, 11-51T; KMC X11Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; Shimano CN-M6100Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; Shimano CN-M6100Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; Shimano CN-M6100Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; Shimano CN-M6100SRAM GX Eagle, 12-Speed; ACID E-Crank, 165mm (27.5: 36T // 29: 34T); SRAM GX Eagle Trigger, Single Click; SRAM XG-1275 Eagle, 10-52T; SRAM NX EagleSRAM XX1 Eagle AXS, 12-Speed; e*thirteen Plus Crank, 165mm (27.5: 36T // 29: 34T); SRAM Eagle AXS Controller; SRAM XG-1299 Eagle Rainbow, 10-52T; SRAM PC-XX1 Eagle RainbowSRAM XX1 Eagle AXS, 12-Speed; e*thirteen Plus Crank, 165mm, 34T; SRAM Eagle AXS Controller; SRAM XG-1299 Eagle Rainbow, 10-52T; SRAM PC-XX1 Eagle Rainbow
WheelsRodi Tryp 30, 32H, Disc, Tubeless ReadyRodi Tryp 30, 32H, Disc, Tubeless ReadyCUBE EX30, 32H, Disc, Tubeless ReadyCUBE EX30, 32H, Disc, Tubeless ReadyNewmen Performance 30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Performance 30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Performance 30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Advanced SL A.30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless ReadyNewmen Advanced SL A.30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless Ready
TyresSchwalbe Nobby Nic, PerfL, 2.6Schwalbe Nobby Nic, PerfL, 2.6Schwalbe Nobby Nic, PerfL, 2.6Schwalbe Nobby Nic, PerfL, 2.6Front: Schwalbe Hans Dampf, Addix Soft, Super Trail, Tubeless Easy, 2.6, Rear: Schwalbe Hans Dampf, Addix Speedgrip, Super Trail, Tubeless Easy, 2.6Front: Schwalbe Hans Dampf, Addix Soft, Super Trail, Tubeless Easy, 2.6, Rear: Schwalbe Hans Dampf, Addix Speedgrip, Super Trail, Tubeless Easy, 2.6Front: Maxxis Assegai, MaxxGrip/EXO+, Tubeless Ready, 2.5 WT, Rear: Maxxis Minion DHR II, MaxxGrip/DoubleDown, Tubeless Ready, 2.4 WTFront: Schwalbe Magic Mary, Super Trail, Addix Soft, Kevlar, 2.4, Rear: Schwalbe Big Betty, Super Trail, Addix Soft, Kevlar, 2.4Front: Schwalbe Magic Mary, Super Trail, Addix Soft, Kevlar, 2.4, Rear: Schwalbe Big Betty, Super Trail, Addix Soft, Kevlar, 2.4
Weight23.8 kg24.5 kg24.1 kg24.8 kg24.1 kg24.9 kg24.6 kg23.9 kg23.9 kg
Price£3,499£3,699£3,699£3,899£4,499£4,799£4,999£6,999£8,399
Rides similarly
Spot a mistake?
