Bike Finder · Cube
no image yet
Cube
Stereo Hybrid 120 2024
DiscontinuedTrail eMTBLegacy · 1.6/10iFreshness 1.6/10
Travel F/R
130/120mm
Wheels
29F / 29R
Frame
Aluminium
Weight
25.6 kg
Price
From £3,699
View the Cube Stereo Hybrid 120 on Cube’s site
Cube Stereo Hybrid 120 2024
From £3,699
EMTB Forums verdict
The 2024 Cube Stereo Hybrid 120 was Cube's aluminium short-travel Bosch trail eMTB, pairing 120mm of FSP 4-Link rear travel with a 120-130mm fork and the fourth-generation Bosch Performance Line CX motor (85Nm) fed by an integrated 750Wh PowerTube. Cube's Comfort Geometry, with a relatively steep 76-degree seat angle, a 67-degree head angle and a high 331mm bottom bracket, plus the SizeSplit approach (27.5in wheels on size S, 29in on M/L/XL), positions it as an easy-handling, ride-all-day trail bike rather than an aggressive enduro machine.
Across the 750Wh trims the frame, motor and battery are shared, so the differences are in the kit. The Pro 750 (£3,699) runs RockShox Recon Silver suspension, two-piston Shimano MT420 brakes and a Deore mech on a fixed post. The Race 750 (£3,999) steps up to a Fox 34 fork and Float DPS shock, four-piston Magura MT Thirty brakes and a Shimano XT rear derailleur, making it the value sweet spot for riders who want better suspension and stoppers. The SLX 750 (£4,099) adds the same Fox suspension and XT mech but its standout upgrade is a genuine internally-routed dropper post, which is the single most useful real-world addition for trail riding.
This generation is discontinued. Cube has since replaced the 120 numbering with its current Stereo Hybrid ONE series (ONE22, ONE44, ONE77), which moved the trail range onto newer Bosch hardware and 800Wh batteries. As a result the 2024 Stereo Hybrid 120 is now found mainly on clearance, where its full Bosch CX drive and 750Wh range make it a sensible budget trail option.
💬 Forum discussion
Cube Stereo Hybrid bash plate
31 replies · 19.7k views · last reply 65 months ago
Join the discussion →
“Live on their site now. E-BIKES - CUBE - ROCKGUARDZ”
— Dfowler · ♥ 3 · most-liked post
Bike geometry diagram
SMLXL
Reach434 mm454 mm476 mm497 mm
Stack610 mm647 mm656 mm670 mm
Seattube370 mm420 mm465 mm515 mm
Chainstay466 mm480 mm480 mm480 mm
Headtube Angle66.7°67°67°67°
Seattube Angle (eff)76°76°76°76°
Wheelbase1199 mm1244 mm1270 mm1297 mm
Headtube130 mm135 mm145 mm160 mm
BB Height331 mm331 mm331 mm331 mm
Front Centre733 mm*764 mm*790 mm*817 mm*
Trims · 3
Pro 750
£3,699
Race 750
£3,999
SLX 750
£4,099
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R130/120 mm · all trims
FrameAluminium · all trims
ForkRockShox Recon Silver RL Air, Tapered, 15x110mm, eMTB Approved, 130mm, LockoutFox 34 Float AWL, 2-Position Sweep-Adjust RAIL Damper, Tapered, 15x110mm, E-Bike Optimized, 120mmFox 34 Float AWL, 2-Position Sweep-Adjust RAIL Damper, Tapered, 15x110mm, E-Bike Optimized, 120mm
ShockRockShox Deluxe Select, 185x55mm (27.5: 165x45mm), Rebound Adjust, Trunnion MountFox Float DPS EVOL, 185x55mm (27.5: 165x45mm), Open/Medium/Firm Mode, Trunnion MountFox Float DPS EVOL, 185x55mm (27.5: 165x45mm), Open/Medium/Firm Mode, Trunnion Mount
HeadsetACROS AZF-1035, ICR (Integrated Cable Routing), BlockLock 120 degrees, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) · all trims
StemCUBE Performance Stem E-MTB, 31.8mm · all trims
HandlebarNewmen Evolution SL 318.25, 760mm · all trims
GripsACID Hybrid Perform · all trims
SaddleNatural Fit Sequence · all trims
SeatpostCUBE Performance Post, 30.9mmCUBE Performance Post, 30.9mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 30.9mm
BrakesShimano BR-MT420, Hydr. Disc Brake (203/203)Magura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc Brake (203/203)Shimano BR-MT520, Hydr. Disc Brake (203/203)
Rear derailleurShimano Deore RD-M6100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-SpeedShimano XT RD-M8100-SGS, ShadowPlus, 12-Speed
CrankACID E-Crank, 38T, 170mm · all trims
ShiftersShimano Deore SL-M6100-IR, Direct Attach, Rapidfire-PlusShimano Deore SL-M6100, Rapidfire-PlusShimano Deore SL-M6100, Rapidfire-Plus
CassetteSunrace CSMZ600, 11-51TShimano Deore CS-M6100, 10-51TShimano Deore CS-M6100, 10-51T
ChainShimano CN-M6100 · all trims
DrivetrainShimano Deore RD-M6100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 38T, 170mm; Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus; Sunrace CSMZ600, 11-51T; Shimano CN-M6100Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 38T, 170mm; Shimano Deore SL-M6100, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; Shimano CN-M6100Shimano XT RD-M8100-SGS, ShadowPlus, 12-Speed; ACID E-Crank, 38T, 170mm; Shimano Deore SL-M6100, Rapidfire-Plus; Shimano Deore CS-M6100, 10-51T; Shimano CN-M6100
WheelsRodi Tryp 30, 32H, Disc, Tubeless Ready (CUBE Engineered By Newmen hubs, Boost, Centerlock)CUBE EX30, 32H, Disc, Tubeless Ready (Shimano HB-MT400-B / FH-MT410-B hubs, Boost, Centerlock)Newmen Performance 30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless Ready
TyresSchwalbe Smart Sam, Active, 2.6Schwalbe Smart Sam, Active, 2.6Schwalbe Smart Sam, Performance, 2.6
Weight25.8 kg25.6 kg25.9 kg
Price£3,699£3,999£4,099
Rides similarly
Spot a mistake?
