Bike Finder · Cube
Cube Reaction Hybrid
Cube
Reaction Hybrid 2026
Currente-MTB hardtailMature · 5.5/10iFreshness 5.5/10
Travel F/R
120mm / —
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
24.8 kg
Price
From £2,699
View the Cube Reaction Hybrid on Cube’s site
Cube Reaction Hybrid 2026
From £2,699
EMTB Forums verdict
The Cube Reaction Hybrid 2026 is a full-power aluminium hardtail built around Bosch's most capable trail motor, a serious 800 Wh battery, and 120 mm of front travel — positioned squarely at riders who want genuine all-day range and proven drivetrain reliability without the weight penalty or price of a full-suspension platform. At 24.8–25.9 kg depending on trim, it sits in the heavier bracket for a hardtail, but the community's broad consensus is that the Bosch powertrain earns its keep on the climbs.
Drive system & range
The Bosch Performance Line CX Gen 4 delivers 85 Nm of torque and a manufacturer-claimed peak of 600 W from a 2.9 kg motor unit. That torque figure is strong for a 250 W-rated system and the CX Gen 4's trail-tuned power delivery is well documented across the platform. Paired with the 800 Wh PowerTube battery — integrated into the downtube — this is one of the largest-capacity packs in the hardtail category, and real-world range is meaningfully better than 500–625 Wh predecessors that owners of earlier Reaction Hybrids rode.
One live firmware question worth flagging: @rscreen noted that the 2026 Pro's Bosch BDU384Y motor unit may not yet support the new 45 km/h speed option, and that not all CX Gen 4 motors have been confirmed for that feature. Worth verifying with your dealer before purchase if extended-speed modes matter to you. The standard UK assist cuts out at 15.5 mph regardless, as @Revelator1969 confirmed on an earlier Reaction Hybrid — that is a legal constant, not a Cube-specific quirk.
Geometry & handling
The 67.5° head angle is on the slacker end for a 120 mm hardtail, which translates to more confidence on technical descents than the category average. Reach scales from 409 mm (S) to 471 mm (XXL) — a sensible 62 mm spread across five sizes that gives most riders a genuine fit rather than forcing a compromise. The MX wheel setup (29-inch front, 27.5-inch rear) lowers the bottom bracket relative to a straight 29er, aiding cornering clearance and handling agility on tighter singletrack.
Chainstay length jumps from 456 mm on the S to 470 mm on M through XXL and stays fixed there, which keeps the bigger sizes from feeling too stretched. Wheelbase runs 1157–1240 mm across the range — proportionate for the travel and head angle, and not unusually long. Size S riders should note the fork travel drops to 100 mm on all three trims, which does affect the head angle calculation slightly and is a real consideration for shorter riders who want maximum trail capability.
Build & value
Three trims span £2,699 to £3,299 — a £600 window with meaningful, not cosmetic, differences. The entry ONE 800 at £2,699 runs an SR Suntour XCM34 coil fork and Shimano BR-MT200 two-piston brakes with 180 mm rotors. The coil fork is competent but not tunable, and two-piston stoppers on a 25.9 kg bike are the weakest point in the package.
Step to the Pro 800 at £2,899 and you gain an SR Suntour X1-32 air fork (adjustable, same 120 mm travel) and, critically, Shimano BR-MT420 four-piston brakes with 203 mm rotors — a meaningful upgrade for a bike this weight. At £200 over the ONE, that step is good value. The Race 800 at £3,299 brings a RockShox Recon Silver RL air fork — noticeably stiffer and better damped than either Suntour option — and Magura Louise four-piston brakes, though it reverts to 180 mm rotors. The Race sheds 1.1 kg versus the ONE (24.8 kg vs 25.9 kg), partly through the fork upgrade.
Community-verified strengths
  • The Bosch CX Gen 4 powertrain inspires owner confidence: @RobbieMcManus describes an earlier Reaction Hybrid Pro as "solid and simple," the kind of reliability praise that recurs across owner threads.
  • The platform rewards upgrading: @slenemtbforums recommends the Marzocchi Bomber Z2 140 mm as a fork upgrade — lighter than stock, 34 mm stanchions, more travel, and it slackens the front end further, showing the frame has headroom beyond its stock spec.
  • Day-to-day rideability gets consistent praise: @audistwo collected a Race 750 and called it a "fantastic machine" after an 11-mile first ride, with only minor fit adjustments needed out of the box.
Caveats & known gripes
  • Motor bash guard durability is a real concern: @andyinpembs reports that a single rock strike destroyed the bash guard on a 2023 Reaction Hybrid, and replacement parts are hard
💬 Forum discussion
Cube Hybrid EMTB 2025 looks lit!
392 replies · 84.7k views · last reply yesterday
Join the discussion →
“Well, she’s finally arrived! The colour is absolutely stunning the way it flips. I’m hoping I don’t have to change the lovely ERA cranks for shorter ones, but I’ll soon find out on its first ride Sunday. Bit concerned how it’ll throw…”
— Eyuplad · ♥ 12 · most-liked post
Bike geometry diagram
SMLXLXXL
Reach409 mm420 mm437 mm455 mm471 mm
Stack646 mm653 mm662 mm674 mm685 mm
Seattube370 mm405 mm450 mm495 mm545 mm
Chainstay456 mm470 mm470 mm470 mm470 mm
Headtube Angle67.5°67.5°67.5°67.5°67.5°
Seattube Angle (eff)74.5°74°74°74°74°
BB Drop46 mm65 mm65 mm65 mm65 mm
Wheelbase1157 mm1176 mm1198 mm1218 mm1240 mm
Front Centre701 mm*706 mm*728 mm*748 mm*770 mm*
Trims · 3
Reaction Hybrid ONE 800
£2,699
Reaction Hybrid Pro 800
£2,899
Reaction Hybrid Race 800
£3,299
MotorBosch Performance Line CX Gen 5 · 85 Nm · all trims
BatteryBosch PowerTube 800 · 800 Wh · all trims
Travel F/R120/? mm · all trims
FrameAluminium · all trims
ForkSR Suntour XCM34 NLO Coil, tapered, 15x110mm, 120mm (100mm on size S)SR Suntour X1-32 LO-R Air, tapered, 15x110mm, 120mm (100mm on size S)RockShox Recon Silver RL Air, tapered, 15x110mm, 120mm (100mm on size S)
HeadsetACROS AZF-1034, ICR (Integrated Cable Routing), Top Zero-Stack 1 1/2 (ZS 56mm), Bottom Zero-Stack 1 1/2 (ZS 56mm)ACROS AZF-1034, ICR (Integrated Cable Routing)ACROS AZF-1034, ICR (Integrated Cable Routing), Top Zero-Stack 1 1/2 (ZS 56mm), Bottom Zero-Stack 1 1/2 (ZS 56mm), X-Connect Interface
StemCUBE Performance Stem E-MTB 35, FPI-Link · all trims
HandlebarCUBE Rise Trail Bar 35 · all trims
GripsACID Hybrid Perform · all trims
SaddleACID Sequence 160 · all trims
SeatpostCUBE Performance Post, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mmCUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm
BrakesShimano BR-MT200 hydraulic disc, 180mm rotorsShimano BR-MT420 4-piston hydraulic disc, 203mm rotorsMagura Louise 4-piston hydraulic disc, 180mm rotors
Rear derailleurShimano Cues RD-U6000-GS, 10-speedShimano XT RD-M8100-SGS, 12-speedSRAM Eagle 90 Transmission, 12-speed
CrankACID MTB Hybrid Pro, 38T · all trims
ShiftersShimano Cues SL-U6000, Rapidfire-PlusShimano Deore SL-M6100-IR, Direct AttachSRAM Eagle 90 Transmission
CassetteShimano Cues CS-LG400, 11-48TShimano Deore CS-M6100, 10-51TSRAM XS-1270, 10-52T
ChainKMC eGlideKMC e12SRAM GX Eagle Transmission
DrivetrainShimano Cues RD-U6000-GS, 10-speed; ACID MTB Hybrid Pro, 38T; Shimano Cues SL-U6000, Rapidfire-Plus; Shimano Cues CS-LG400, 11-48T; KMC eGlideShimano XT RD-M8100-SGS, 12-speed; ACID MTB Hybrid Pro, 38T; Shimano Deore SL-M6100-IR, Direct Attach; Shimano Deore CS-M6100, 10-51T; KMC e12SRAM Eagle 90 Transmission, 12-speed; ACID MTB Hybrid Pro, 38T; SRAM Eagle 90 Transmission; SRAM XS-1270, 10-52T; SRAM GX Eagle Transmission
WheelsACID Pro 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID SLX 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless ReadyACID Pro 30, 32/32 Spokes, 15x110mm/12x148mm, Tubeless Ready
TyresSchwalbe Smart Sam Active 2.6in · all trims
Weight25.9 kg25.5 kg24.8 kg
Price£2,699£2,899£3,299
Rides similarly
Spot a mistake?
