Bike Finder · Crestline
no image yet
Crestline
S 180 2025
CurrentEnduro eMTBMature · 6.9/10iFreshness 6.9/10
Travel F/R
180/180mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
21.75 kg
Price
£7,803
View the Crestline S 180 on Crestline’s site
Crestline S 180 2025
From £7,803
EMTB Forums verdict
The Crestline S 180 Classic Edition is a US gravity eMTB built and sold in a single limited run of 150 units for model year 2025, priced from $9,999 USD (600Wh build) up to $10,299 USD (800Wh build). The high-modulus carbon frame (laid up by VIP Composites in Vietnam) runs 180mm front and 180mm rear, with the dual-link rear end tuned by Cascade Components. A flip chip on the lower link adjusts rear travel, and Crestline ships size-specific 27.5in (445mm chainstay) or 29in (455mm chainstay) rear triangles so each frame can run MX or full 29in wheels.
The drivetrain is built around the Gen 5 Bosch Performance Line CX Smart System motor with a removable high energy density battery in either 600Wh or 800Wh, plus compatibility with the Bosch PowerMore 250Wh range extender for up to 1050Wh total. The build is gravity-oriented throughout: a RockShox Zeb Ultimate 180mm fork, Vivid Air Ultimate 230 x 65 shock, SRAM Maven Silver brakes on 200mm HS2 rotors, a SRAM GX T-Type transmission, DT Swiss 1700 alloy wheels and Continental Kryptotal Enduro Soft tyres.
Geometry is firmly in DH-adjacent enduro territory: a 63.5 degree head angle across all three rider-height sizes (RH-2/RH-3/RH-4), reach of 450/475/500mm, and a fairly tall static 356mm bottom bracket. The middle RH-3 size is user-configurable between MX (1269mm wheelbase) and full 29in (1278mm wheelbase) at point of sale, while RH-2 is MX-only and RH-4 is 29in-only. Reach can be tuned plus or minus 5mm with an aftermarket reach-adjust headset on the straight 56mm head tube. The model is now sold out and discontinued; Crestline has since moved its current lineup on to DJI Avinox powered RS 181.2 framesets.
💬 Forum discussion
Crestline RS180 Skid Plate?
20 replies · 3.9k views · last reply 22 months ago
Join the discussion →
“LOL 😂 I wasn't a big fan of the straps-based attachment approach but when you think about the strength issues you will have with any inserts mounted in carbon, going another route to attach the bash guard to the bike makes a ton of…”
— Arethustra · ♥ 3 · most-liked post
OWNERS’ REPORT
Crestline RS181 family — what owners actually know
5,029 posts · 349 owners · data through Jun 2026
4DJI coast-rattle, amplified by the VPP frame (M1-era RS181/Spectre) · typical onset: From new; motor-batch dependent
4Dropper insertion limit · typical onset: Design trait, from new
3Brittle motor/BB cover - both eras, cumulative chip damage · typical onset: First weeks in rocky terrain
4,000 miles on the RS181.1 'with almost zero issues' - only the rear shock mounting hardware replaced for play. 5,000 miles/1,000,000 ft a year rider, on his…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
RH-2RH-3RH-4
Reach450 mm475 mm500 mm
Stack632 mm641 mm650 mm
Seattube420 mm450 mm480 mm
Chainstay445 mm445 mm455 mm
Headtube Angle63.5°63.5°63.5°
Seattube Angle (eff)77°77°77.5°
Wheelbase1241 mm1269 mm1302 mm
Headtube100 mm110 mm120 mm
BB Height356 mm356 mm356 mm
Front Centre796 mm*824 mm*847 mm*
Trims · 1
Classic Edition
£7,803
MotorBosch Performance Line CX Gen 5 · 120 Nm
BatteryBosch PowerTube 800 · 800 Wh
Travel F/R180/180 mm
FrameHigh Modulus Carbon Fiber
ForkGloss Red RockShox Zeb Ultimate 180mm 29"
ShockRockShox Vivid Air Ultimate 230 x 65
HeadsetCane Creek 40
StemOneUp 42mm Stem
HandlebarOneUp 35mm Rise Alloy Bar
GripsTrail One Farlow Grips
SeatpostOneUp Components V3 Dropper: RH-2 (150mm), RH-3 (180mm), RH-4 (210mm)
BrakesSRAM Maven Silver
Rear derailleurSRAM GX T-Type (Eagle Transmission)
CrankSRAM GX Crank Arms
ShiftersSRAM GX T-Type AXS
CassetteSRAM GX T-Type
ChainSRAM GX T-Type
DrivetrainSRAM GX T-Type (Eagle Transmission); SRAM GX Crank Arms; SRAM GX T-Type AXS; SRAM GX T-Type; SRAM GX T-Type
WheelsDT Swiss 1700 Alloy Wheelset
TyresFront: Continental Kryptotal F, Rear: Continental Kryptotal R, both Enduro SOFT casing
Weight21.75 kg
Price£7,803
Rides similarly
Spot a mistake?
