Bike Finder · Commencal
Commencal T.E.M.P.O. Power
Commencal
T.E.M.P.O. Power 2026
CurrentLightweight/SL full-suspension trail eMTBMature · 5.9/10iFreshness 5.9/10
Motor
Bosch Performance Line SX · 55Nm · 600W
Battery
Bosch PowerTube 400 · 400Wh
Travel F/R
150/135mm
Wheels
29F / 29R
Frame
Aluminium
Weight
20.3 kg
Price
From £5,300
View the Commencal T.E.M.P.O. Power on Commencal’s site
Commencal T.E.M.P.O. Power 2026
From £5,300
💬 Forum discussion
Commencal Meta Power Race Fox!
180 replies · 58.2k views · last reply 68 months ago
Join the discussion →
“Third Ride, She's a beast, the Fox suspension is so smooth”
— jsalas2 · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach426 mm446 mm466 mm486 mm
Stack623 mm627.5 mm632 mm636.5 mm
Seattube380 mm420 mm440 mm460 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76.3°76.3°76.3°76.3°
BB Drop27 mm27 mm27 mm27 mm
Wheelbase1202.2 mm1224.4 mm1246.5 mm1270.5 mm
Front Centre757.2 mm*779.4 mm*801.5 mm*825.5 mm*
Trims · 4
Essential (2025)
£5,300
Essential Eagle 90 (2026)
£5,500
Signature AXS (2025)
£7,400
Signature Eagle 90 (2026)
£7,800
MotorBosch Performance Line SX · 55 Nm · all trims
BatteryBosch PowerTube 400 · 400 Wh · all trims
Travel F/R150/135 mm · all trims
FrameAluminium · all trims
ForkFox 36 Performance E-Bike, 150 mm, GripFox 36 Performance E-Bike, 150 mm, GripFox 36 Factory E-Bike, 150 mm, Grip X2Fox 36 Factory E-Bike, 150 mm
ShockFox Float Performance, 210 x 50 mmFox Float Performance, 210 x 50 mmFox Float Factory, 210 x 50 mmFox Float Factory, 210 x 50 mm
HeadsetACROS ZS56 / ZS56, Alloy cups, sealed & stainless steel bearingsACROS ZS56 / ZS56, Alloy cups, sealed & stainless steel bearingsACROS ZS56 / ZS56ACROS ZS56 / ZS56
StemRIDE ALPHA 40, 40 mm extension, 31.8 mm · all trims
HandlebarRIDE ALPHA R27 780 (M/L), R20 760 (S), R27 800 (XL), 31.8 mm, Alloy 6061RIDE ALPHA R27 780 (M/L), R20 760 (S), R27 800 (XL), 31.8 mmRIDE ALPHA R27 780 (M/L), R20 760 (S), R27 800 (XL), 31.8 mmRIDE ALPHA R27 780 (M/L), R20 760 (S), R27 800 (XL), 31.8 mm
GripsRIDE ALPHA Mushroom, Soft compound, single clamp, 132 mm width, blackRIDE ALPHA Mushroom, Soft compound, single clamp, 132 mm width, blackODI Longneck V2.1ODI Longneck V2.1
SaddleFIZIK Terra Ridon X5, 145 mm width, S-Alloy Mobius railsFIZIK Terra Aidon X5, 145 mm width, S-Alloy Mobius railsFIZIK Terra Ridon X3, 145 mm width, Kium Mobius railsFIZIK Terra Ridon X5, 145 mm width, Kium Mobius rails
SeatpostKS Ragei, 31.6 mmKS Ragei, 31.6 mmFOX Transfer Factory, 31.6 mmFOX Transfer Factory, 31.6 mm
BrakesShimano Deore, 4 pistons, resin pads, 203 mmShimano Deore, 4 pistons, resin pads, 203 mmShimano XT, 4 pistons, 203 mm MT905 rotorsShimano XT, 4 pistons, 203 mm MT905 rotors
Rear derailleurShimano Deore, 12s, 10-51tSRAM Eagle 90 T-Type, 12sSRAM X0 Eagle Transmission, 12s wireless AXSSRAM Eagle 90 T-Type, 12s
CrankE13 Helix Core e*spec, 155 mm crank arms, E13 Helix Race e*spec 34t direct mount chainringE13 Helix Core e*spec, 155 mm crank arms, E13 Helix Race e*spec 34t direct mount chainringSRAM X0 Eagle E-MTB, 34t chainringE13 Helix Core e*spec, 155 mm crank arms, SRAM XX T-Type 34t direct mount chainring
ShiftersSHIMANO Deore, 12sSRAM Eagle 90, 12sSRAM AXS Pod Controller, 12sSRAM Eagle 90, 12s
CassetteSHIMANO Deore, 12s, 10-51tSRAM XS 1270 T-Type, 12s, 10-52tSRAM X0 Eagle Transmission, 12s, 10-52t, T-TypeSRAM X0 Eagle Transmission, 12s, 10-52t, T-Type
ChainSHIMANO Deore, 12sSRAM GX T-type, 12sSRAM X0 Eagle Transmission, 12s, Flattop, T-TypeSRAM GX T-type, 12s
DrivetrainShimano Deore, 12s, 10-51t; E13 Helix Core e*spec, 155 mm crank arms, E13 Helix Race e*spec 34t direct mount chainring; SHIMANO Deore, 12s; SHIMANO Deore, 12s, 10-51t; SHIMANO Deore, 12sSRAM Eagle 90 T-Type, 12s; E13 Helix Core e*spec, 155 mm crank arms, E13 Helix Race e*spec 34t direct mount chainring; SRAM Eagle 90, 12s; SRAM XS 1270 T-Type, 12s, 10-52t; SRAM GX T-type, 12sSRAM X0 Eagle Transmission, 12s wireless AXS; SRAM X0 Eagle E-MTB, 34t chainring; SRAM AXS Pod Controller, 12s; SRAM X0 Eagle Transmission, 12s, 10-52t, T-Type; SRAM X0 Eagle Transmission, 12s, Flattop, T-TypeSRAM Eagle 90 T-Type, 12s; E13 Helix Core e*spec, 155 mm crank arms, SRAM XX T-Type 34t direct mount chainring; SRAM Eagle 90, 12s; SRAM X0 Eagle Transmission, 12s, 10-52t, T-Type; SRAM GX T-type, 12s
WheelsDT SWISS H 1900 LS, 29, 28h, 30 mm inner width, Tubeless ReadyDT SWISS M1900, 29, 28h, 30 mm inner width, Tubeless ReadyDT SWISS HX 1700 LS, 29, 28h, 30 mm inner widthDT SWISS XM 1700, 29, 28h, 30 mm inner width
TyresSchwalbe Magic Mary 29x2.4 front / Schwalbe Tacky Chan 29x2.4 rearSchwalbe Magic Mary 29x2.4 front / Schwalbe Tacky Chan 29x2.4 rearSchwalbe Magic Mary 29x2.4 front / Schwalbe Tacky Chan 29x2.4 rearMaxxis Assegai 29x2.5 front / Maxxis Minion DHR II 29x2.4 rear
Weight20.4 kg20.3 kg20.3 kg
Price£5,300£5,500£7,400£7,800
Rides similarly
Spot a mistake?
