Torque:ON 2026
The Torque:ON is Canyon's full-power gravity e-MTB: a Category 5 rated carbon frame running 180 mm up front and 175 mm at the rear on a mullet (29in front, 27.5in rear) wheel set. The geometry is unashamedly downhill-leaning, with a 63.5 degree head angle, 445 mm chainstays and a long 1,306 mm wheelbase in size L, paired with a steep 77.5 degree seat angle to keep climbing manageable. Reach runs 450 to 525 mm across the S to XL sizes.
All three builds share the same frame, geometry and removable 800 Wh battery, so the choice comes down to motor and kit. The CF 9 at £4,179 is the pick if you want the stronger Shimano EP801 motor, a wireless SRAM Eagle AXS Transmission drivetrain, Fox 38 and Float X2 suspension and powerful SRAM Maven Silver brakes. The CF 8 (£3,819) and CF 7 (£3,279) both drop to the Shimano EP600 motor and a wired Shimano Deore 12-speed drivetrain.
Between the two cheaper builds, the CF 8 runs a RockShox Vivid air shock with Shimano Deore four-piston brakes, while the CF 7 swaps to a RockShox Super Deluxe coil shock and SRAM Code R brakes. Claimed weights are close across the range at 25.12 to 25.8 kg. The CF 9 carries the headline tech, but the CF 8 looks the value sweet spot for riders happy with the mid-tier motor.
| S | M | L | XL | |
| Reach | 450 mm | 475 mm | 500 mm | 525 mm |
| Stack | 639 mm | 648 mm | 657 mm | 666 mm |
| Seattube | 395 mm | 420 mm | 435 mm | 460 mm |
| Chainstay | 445 mm | 445 mm | 445 mm | 445 mm |
| Headtube Angle | 63.5° | 63.5° | 63.5° | 63.5° |
| Seattube Angle (eff) | 77.5° | 77.5° | 77.5° | 77.5° |
| Wheelbase | 1247 mm | 1276 mm | 1306 mm | 1335 mm |
| Headtube | 105 mm | 115 mm | 125 mm | 135 mm |
| Standover | 738 mm | 745 mm | 765 mm | 777 mm |
| Front Centre | 802 mm* | 831 mm* | 861 mm* | 890 mm* |
Trims · 3
CF 7 £3,279 | CF 8 £3,819 | CF 9 £4,179 | |
| Motor | Shimano EP6 (DU-EP600) · 85 Nm | Shimano EP6 (DU-EP600) · 85 Nm | Shimano EP801 · 85 Nm |
| Battery | Canyon BT010 · 800 Wh · all trims | ||
| Travel F/R | 180/175 mm · all trims | ||
| Frame | Carbon (CF) · all trims | ||
| Fork | RockShox ZEB, 180 mm, 44 mm offset, 38 mm stanchions | RockShox ZEB, 180 mm, 44 mm offset, 38 mm stanchions | Fox 38 Performance Elite, 180 mm, 44 mm offset, 38 mm stanchions |
| Shock | RockShox Super Deluxe Coil Select (400 spring) | RockShox Vivid | Fox Float X2 Performance |
| Stem | Canyon:ON ST0031, 45 mm, 35 mm clamp, aluminium · all trims | ||
| Handlebar | Canyon Handlebar HB0057, 35 mm clamp, 30 mm rise | Canyon Handlebar HB0057, 35 mm clamp, 30 mm rise | Canyon Handlebar HB0057, 35 mm clamp, 30 mm rise (780 mm S / 800 mm M-XL) |
| Grips | Canyon Lock-On · all trims | ||
| Saddle | Fizik Gravita Alpaca X5 · all trims | ||
| Seatpost | Iridium Dropper, 30.9 mm, aluminium · all trims | ||
| Brakes | SRAM Code R, 4-piston | Shimano Deore M6120, 4-piston | SRAM Maven Silver / SRAM Maven Silver Stealth, 4-piston |
| Rear derailleur | Shimano Deore M6100, 12-speed | Shimano Deore M6100, 12-speed | SRAM S1000 Eagle AXS Transmission |
| Crank | Shimano Steps, Canyon EP1110-01 Chainring 34T | Shimano Steps, Canyon EP1110-01 Chainring 34T | Shimano Steps, Eagle Transmission E-MTB Chainring 104 BCD |
| Shifters | Shimano Deore M6100, 12-speed | Shimano Deore M6100, 12-speed | SRAM AXS Pod |
| Cassette | Shimano Deore M6100, 12-speed, 10-51 | Shimano Deore M6100, 12-speed, 10-51 | SRAM XS-1275, 12-speed, 10-52 |
| Chain | Shimano Deore M6100 | Shimano Deore M6100 | SRAM GX Eagle Transmission |
| Drivetrain | Shimano Deore M6100, 12-speed; Shimano Steps, Canyon EP1110-01 Chainring 34T; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51; Shimano Deore M6100 | Shimano Deore M6100, 12-speed; Shimano Steps, Canyon EP1110-01 Chainring 34T; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51; Shimano Deore M6100 | SRAM S1000 Eagle AXS Transmission; Shimano Steps, Eagle Transmission E-MTB Chainring 104 BCD; SRAM AXS Pod; SRAM XS-1275, 12-speed, 10-52; SRAM GX Eagle Transmission |
| Wheels | SunRingle Duroc SD37 Comp 29in (front) / SD37 Comp 27.5in (rear), aluminium | Sun Ringle 309 Enduro Comp (front) / 307 Enduro Comp (rear), aluminium, 30 mm inner width | DT Swiss HFR1700, aluminium, 30 mm inner width (front 29in, rear 27.5in) |
| Tyres | Front: Maxxis Assegai 3C MaxxGrip 2.5in; Rear: Maxxis Minion DHR II 3C MaxxTerra 2.4in | Front: Maxxis Assegai 3C MaxxGrip 2.5in; Rear: Maxxis Minion DHR II 2.5in | Front: Maxxis Assegai 3C MaxxGrip 2.5in; Rear: Maxxis Minion DHR II 2.5in |
| Weight | 25.8 kg | 25.12 kg | 25.26 kg |
| Price | £3,279 | £3,819 | £4,179 |
Rides similarly
Spot a mistake?
