Spectral:ONfly 2026
The Spectral:ONfly is Canyon's lightweight take on its Spectral trail platform, swapping a full-power drive unit for the compact TQ HPR50 (50 Nm, 300 W peak) and a fully integrated 360 Wh battery. Claimed full-bike weights of 18.8-18.9 kg and a quoted Category 4E strength rating mean this is pitched as an all-mountain-capable mid-power bike rather than a stripped-back assist.
Geometry is borrowed from the regular Spectral CF: a 64-degree head angle, 76.5-degree seat tube, 440 mm chainstays across all sizes and a 470 mm reach in size M, rolling on a mullet (29in front, 27.5in rear) setup with 160 mm of fork travel and 150 mm at the rear. The K.I.S. steering stabiliser is fitted across the range, and the long-stroke Canyon dropper runs 200 mm on M/L and 230 mm on XL.
Both 2026 GB builds share the TQ motor, frame and finishing kit. The CF 8 at GBP 5,199 pairs a RockShox Lyrik fork and Deluxe Select+ shock with SRAM Code R four-piston brakes and a Shimano Deore 12-speed drivetrain on Sun Ringle alloy wheels. The CF 9 at GBP 5,849 steps up to a Fox 36 fork and DPS shock, Shimano XT M8120 brakes, an XT rear mech and DT Swiss alloy wheels. The CF 8 covers the value end, while the CF 9 buys a more premium chassis and braking package for the extra outlay.
| S | M | L | XL | |
| Reach | 445 mm | 470 mm | 495 mm | 520 mm |
| Stack | 620 mm | 629 mm | 638 mm | 647 mm |
| Seattube | 400 mm | 415 mm | 445 mm | 455 mm |
| Chainstay | 440 mm | 440 mm | 440 mm | 440 mm |
| Headtube Angle | 64° | 64° | 64° | 64° |
| Seattube Angle (eff) | 76.5° | 76.5° | 76.5° | 76.5° |
| Headtube | 105 mm | 115 mm | 125 mm | 135 mm |
| Standover | 734 mm | 739 mm | 743 mm | 747 mm |
Trims · 2
CF 8 £5,199 | CF 9 £5,849 | |
| Motor | TQ HPR50 · 50 Nm · all trims | |
| Battery | TQ HPR 360 · 360 Wh · all trims | |
| Travel F/R | 160/150 mm · all trims | |
| Frame | Carbon · all trims | |
| Fork | RockShox Lyrik, 160 mm, 35 mm stanchions, 44 mm offset | FOX 36 Performance Series, 160 mm |
| Shock | RockShox Deluxe Select+ | Fox DPS Performance |
| Stem | Canyon:ON ST0031, 45 mm · all trims | |
| Handlebar | Canyon:ON HB0057 Riser bar, 35 mm clamp, 30 mm rise · all trims | |
| Grips | Canyon Lock-On · all trims | |
| Saddle | Fizik Terra Aidon X5 · all trims | |
| Seatpost | Canyon SP0070-01 dropper (cable-actuated air cartridge), 34.9 mm; 200 mm (M/L), 230 mm (XL) · all trims | |
| Brakes | SRAM Code R, 4-piston | Shimano DEORE XT M8120, 4-piston |
| Rear derailleur | Shimano Deore M6100, 12-speed | Shimano Deore XT M8100 |
| Crank | FSA CK-745/IS Armset, FSA W0190 chainring · all trims | |
| Shifters | Shimano Deore M6100, 12-speed | Shimano Deore SLX M7100 |
| Cassette | Shimano Deore M6100, 12-speed, 10-51 · all trims | |
| Chain | Shimano Deore M6100 | Shimano M6100, 12-speed |
| Drivetrain | Shimano Deore M6100, 12-speed; FSA CK-745/IS Armset, FSA W0190 chainring; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51; Shimano Deore M6100 | Shimano Deore XT M8100; FSA CK-745/IS Armset, FSA W0190 chainring; Shimano Deore SLX M7100; Shimano Deore M6100, 12-speed, 10-51; Shimano M6100, 12-speed |
| Wheels | Sunringle 329 Trail Expert (front) / Sunringle 327 Trail Expert (rear), aluminium | DT Swiss H1900 29 (front) / DT Swiss HX 1900 Spline LS (rear), aluminium |
| Tyres | Maxxis Minion DHR II EXO 2.4in (front) / Maxxis Minion DHR II EXO+ 2.4in (rear) · all trims | |
| Weight | 18.9 kg | 18.8 kg |
| Price | £5,199 | £5,849 |
Rides similarly
Spot a mistake?
