Spectral:ON 2024
The 2024 Canyon Spectral:ON is the brand's full-power trail e-MTB, built around a carbon frame with 160 mm of fork travel and 155 mm at the rear, a mullet wheel set-up (29in front, 27.5in rear) and the Shimano EP801 motor rated at 85 Nm. Geometry is consistent across the range with a 65.5-degree head angle, a 76.5-degree effective seat angle and 440 mm chainstays on every size, giving a reasonably slack, capable trail position rather than an outright enduro one.
The line-up ran from the CF 7 at £4,649 (RockShox Lyrik, Deore drivetrain) up to the CFR at £8,849 (Fox 38 Factory, SRAM X0 AXS, Code Ultimate brakes) and the flagship CFR LTD at £11,149 with RockShox Flight Attendant electronic suspension and SRAM XX AXS. The CF 8 at £5,599 and CF 9 at £6,999 sit in between, with the CF 9 the first step up to a Fox 38 Performance Elite fork and SRAM GX AXS Transmission. As is typical for Canyon, the cheaper carbon builds offer a lot of frame and motor for the money.
Buying direct from Canyon, the consumer-direct pricing was a core part of the value proposition against shop-sold rivals. The Spectral:ON has since been discontinued in this form and superseded by a revised Spectral:ON generation, alongside the lighter, TQ-powered Spectral:ONfly sibling.
| S | M | L | XL | |
| Reach | 435 mm | 460 mm | 485 mm | 510 mm |
| Stack | 630 mm | 639 mm | 648 mm | 657 mm |
| Seattube | 420 mm | 440 mm | 460 mm | 480 mm |
| Chainstay | 440 mm | 440 mm | 440 mm | 440 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 76.5° | 76.5° | 76.5° | 76.5° |
| Wheelbase | 1194 mm | 1223 mm | 1252 mm | 1281 mm |
| Headtube | 115 mm | 125 mm | 135 mm | 145 mm |
| Standover | 809 mm | 814 mm | 820 mm | 825 mm |
| Front Centre | 754 mm* | 783 mm* | 812 mm* | 841 mm* |
Trims · 5
CF 7 £4,649 | CF 8 £5,599 | CF 9 £6,999 | CFR £8,849 | CFR LTD £11,149 | |
| Motor | Shimano EP801 · 85 Nm · all trims | ||||
| Battery | Canyon BT010 · 800 Wh · all trims | ||||
| Travel F/R | 160/155 mm · all trims | ||||
| Frame | Carbon (CF) | Carbon (CF) | Carbon (CF) | Carbon (CFR) | Carbon (CFR) |
| Fork | RockShox Lyrik, 160 mm travel, 44 mm offset, 35 mm stanchions | Fox 38 Rhythm, 160 mm travel, 44 mm offset, 38 mm stanchions | Fox 38 Performance Elite, 160 mm travel | Fox 38 Factory, 160 mm travel, 44 mm offset, 38 mm stanchions | RockShox Lyrik Ultimate, 44 mm offset, 35 mm stanchions |
| Shock | RockShox Deluxe Select R | Fox Float X Performance Evolution | Fox Float X Performance Evolution | Fox Float X Factory | RockShox Super Deluxe Ultimate Flight Attendant |
| Stem | Canyon:ON ST0031, 45 mm | Canyon:ON ST0031, 45 mm | Canyon:ON ST0031, 45 mm | Canyon:ON stem | Canyon:ON stem |
| Handlebar | Canyon:ON HB0057 Riser bar, 780 mm, 30 mm rise, 35 mm clamp | Canyon:ON HB0057 Riser bar, 780 mm, 30 mm rise, 35 mm clamp | Canyon:ON HB0057 Riser bar, 780 mm, 30 mm rise, 35 mm clamp | Canyon:ON riser bar | Canyon:ON riser bar |
| Grips | Canyon Lock-On · all trims | ||||
| Saddle | Fizik Terra Aidon X5 · all trims | ||||
| Seatpost | Iridium Dropper Post, 30.9 mm | Iridium Dropper Post, 30.9 mm | Iridium Dropper Post, 30.9 mm | RockShox Reverb AXS, 30.9 mm | RockShox Reverb AXS, 30.9 mm |
| Brakes | Shimano Deore M6120 (4-piston) | Shimano SLX M7120 (2-piston) | Shimano Deore XT M8120 (4-piston) | SRAM Code Ultimate Stealth | SRAM Code Ultimate Stealth |
| Rear derailleur | Shimano Deore M6100, 12-speed | Shimano Deore XT M8100, 12-speed | SRAM GX Eagle AXS Transmission, 12-speed | SRAM X0 Eagle AXS Transmission, 12-speed | SRAM XX Eagle AXS Transmission, 12-speed |
| Crank | Shimano STEPS | Shimano STEPS | Shimano STEPS | Shimano STEPS HollowTech e-MTB crank arms | Shimano STEPS HollowTech e-MTB crank arms |
| Shifters | Shimano Deore M6100, 12-speed | Shimano Deore SLX M7100, 12-speed | SRAM AXS POD Infinity | SRAM AXS Pod Ultimate | SRAM AXS Pod Ultimate |
| Cassette | Shimano Deore M6100, 12-speed, 10-51 | Shimano Deore SLX CS-M7100, 12-speed, 10-51 | SRAM XS-1275, 12-speed | SRAM X0 Eagle XS-1295, 12-speed, 10-52 | SRAM XX Eagle Transmission, 12-speed, 10-52 |
| Chain | Shimano Deore M6100 | Shimano Deore M6100 | SRAM GX Eagle Transmission | SRAM X0 T-Type | SRAM XX T-Type |
| Drivetrain | Shimano Deore M6100, 12-speed; Shimano STEPS; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51; Shimano Deore M6100 | Shimano Deore XT M8100, 12-speed; Shimano STEPS; Shimano Deore SLX M7100, 12-speed; Shimano Deore SLX CS-M7100, 12-speed, 10-51; Shimano Deore M6100 | SRAM GX Eagle AXS Transmission, 12-speed; Shimano STEPS; SRAM AXS POD Infinity; SRAM XS-1275, 12-speed; SRAM GX Eagle Transmission | SRAM X0 Eagle AXS Transmission, 12-speed; Shimano STEPS HollowTech e-MTB crank arms; SRAM AXS Pod Ultimate; SRAM X0 Eagle XS-1295, 12-speed, 10-52; SRAM X0 T-Type | SRAM XX Eagle AXS Transmission, 12-speed; Shimano STEPS HollowTech e-MTB crank arms; SRAM AXS Pod Ultimate; SRAM XX Eagle Transmission, 12-speed, 10-52; SRAM XX T-Type |
| Wheels | Front: RaceFace AR30; Rear: RaceFace AR35 (Centerlock) | DT Swiss HLN350 (Centerlock), 30 mm | DT Swiss HX1700 (front) / DT Swiss H1700 (rear), Centerlock | DT Swiss (Centerlock) | DT Swiss HXC 1501 (Centerlock) |
| Tyres | Maxxis Assegai 2.5" (front) / Maxxis Minion DHR II 27.5x2.60 WT (rear) · all trims | ||||
| Weight | 24.2 kg | 24.7 kg | 24.4 kg | 23.9 kg | — |
| Price | £4,649 | £5,599 | £6,999 | £8,849 | £11,149 |
Rides similarly
Spot a mistake?
