A solid all-round descender (65.5° head angle, 155mm) — capable in the rough and steep without being an all-out bruiser.
Spectral:ON 2022
The 2022 Spectral:ON was a ground-up reboot of Canyon's playful mullet e-MTB, and the first to wear a full-carbon frame with a carbon rear triangle. It pairs a 29in front wheel with a 27.5in rear, a 150mm fork (the frame is rated to 160mm) and 155mm of rear travel via Canyon's four-bar Triple Phase Suspension, all driven by Shimano's 85Nm EP8 motor. Canyon's own 720Wh battery is standard, with a high-capacity 900Wh pack offered as an option on everything bar size S.
Geometry was made longer and slacker than the outgoing bike: a 65.5 degree head angle, a 76.5 degree effective seat angle and reach growing 25mm per size from 435mm (S) to 510mm (XL), with a constant 440mm chainstay. The result is a more centred, stable descender that keeps the mullet rear wheel's flickability. The CF line spans the value-focused CF 7 (RockShox Lyrik Select, Shimano XT) through the Fox 36 Rhythm, SLX-braked CF 8 to the SRAM GX Eagle AXS, Fox 36 Performance Elite CF 9 on DT Swiss wheels, while the lighter CFR frame underpins the Fox Factory CFR and the SRAM AXS, RockShox Flight Attendant CFR LTD flagship that tips the scales at a notably light 22.05kg.
This generation has since been discontinued and superseded by later Spectral:ON models, so the 2022 bike is now an end-of-line buy. It remains a well-rounded, relatively light full-carbon mullet e-MTB with strong battery capacity and a sensible spread of builds.
Short 440mm rear and a lighter build — easy to pop, manual and throw around.
Balanced front-to-rear in L (FC:RC 1.85) — weight sits evenly between the wheels.
Climbs well — a 76.5° seat keeps the front planted. 500W of peak power and 85Nm of torque — a strong full-power motor.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
| S | M | L | XL | |
| Reach | 435 mm | 460 mm | 485 mm | 510 mm |
| Stack | 634 mm | 643 mm | 652 mm | 661 mm |
| Seattube | 420 mm | 440 mm | 460 mm | 480 mm |
| Chainstay | 440 mm | 440 mm | 440 mm | 440 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 76.5° | 76.5° | 76.5° | 76.5° |
| Wheelbase | 1194 mm | 1223 mm | 1252 mm | 1281 mm |
| Headtube | 115 mm | 125 mm | 135 mm | 145 mm |
| Standover | 809 mm | 814 mm | 820 mm | 825 mm |
| Front Centre | 754 mm* | 783 mm* | 812 mm* | 841 mm* |
| FC:RC | 1.71 | 1.78 | 1.85 | 1.91 |
Trims · 5
CF 7 £4,749 | CF 8 £5,499 | CF 9 £6,399 | CFR £8,199 | CFR LTD £9,999 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm · all trims | ||||
| Battery | Canyon BT002 720Wh · 720 Wh · all trims | ||||
| Travel F/R | 150/155 mm · all trims | ||||
| Frame | Carbon (CF) | Carbon (CF) | Carbon (CF) | Carbon (CFR) | Carbon (CFR) |
| Fork | RockShox Lyrik Select, 150 mm, 35 mm stanchions | Fox 36 Rhythm Grip, 150 mm | Fox 36 Performance Elite, Grip2 damper, 150 mm | FOX 36 Factory, 29in, Grip2 damper, 44 mm offset, 150 mm | RockShox Lyrik Ultimate, 150 mm, 35 mm stanchions, 44 mm offset, Flight Attendant automatic suspension |
| Shock | RockShox Deluxe Select, 155 mm | Fox Float DPS Performance | Fox Float X Performance | FOX Float X Factory EVOL | RockShox Super Deluxe Ultimate Flight Attendant, 155 mm |
| Stem | Canyon:ON ST0031 · all trims | ||||
| Handlebar | Canyon:ON HB0057 Riser bar · all trims | ||||
| Grips | Canyon Lock-On · all trims | ||||
| Saddle | Fizik Terra Aidon X5 · all trims | ||||
| Seatpost | Iridium SP0050 Dropper Post, 30.9 mm | Iridium SP0050 Dropper Post | Iridium SP0050 dropper, 30.9 mm | Fox Transfer Factory dropper | RockShox Reverb AXS wireless dropper, 150 mm, 30.9 mm |
| Brakes | Shimano Deore MT6100 4-piston hydraulic disc (front and rear) | Shimano M7120 4-piston hydraulic disc (front and rear) | SRAM Code RS 4-piston hydraulic disc (front and rear) | Shimano XTR 4-piston hydraulic disc (front and rear) | SRAM Code RSC 4-piston hydraulic disc (front and rear), tool-free reach and bite-point adjust |
| Rear derailleur | Shimano XT, 12-speed | Shimano XT, 12-speed | SRAM GX Eagle AXS, wireless, 12-speed | Shimano XTR, 12-speed | SRAM XX1 Eagle AXS, wireless |
| Crank | Shimano STEPS e-MTB crank arms, 165 mm; Canyon:ON 34t direct-mount chainring | Shimano STEPS e-MTB crank arms, 165 mm; Canyon:ON 34t direct-mount chainring | Shimano STEPS HOLLOWTECH e-MTB crank arms, 165 mm; SRAM X-Sync 34t chainring on Shimano SM-CRE80-B spider | Shimano STEPS HOLLOWTECH e-MTB crank arms, 165 mm | Shimano STEPS HOLLOWTECH e-MTB crank arms, 165 mm |
| Shifters | Shimano Deore, 12-speed | Shimano SLX, 12-speed | SRAM Eagle AXS controller, 12-speed | Shimano XTR, 12-speed | SRAM Eagle AXS Rocker, 12-speed |
| Cassette | Shimano, 12-speed (10-51) | Shimano, 12-speed (10-51) | SRAM Eagle, 12-speed (10-52) | Shimano XTR, 12-speed (10-51) | SRAM XX1 Eagle, 12-speed (10-52) |
| Chain | Shimano, 12-speed | Shimano, 12-speed | SRAM Eagle, 12-speed | Shimano M9100 XTR, 12-speed | SRAM X01 Eagle, 12-speed |
| Drivetrain | Shimano XT, 12-speed; Shimano STEPS e-MTB crank arms, 165 mm; Canyon:ON 34t direct-mount chainring; Shimano Deore, 12-speed; Shimano, 12-speed (10-51); Shimano, 12-speed | Shimano XT, 12-speed; Shimano STEPS e-MTB crank arms, 165 mm; Canyon:ON 34t direct-mount chainring; Shimano SLX, 12-speed; Shimano, 12-speed (10-51); Shimano, 12-speed | SRAM GX Eagle AXS, wireless, 12-speed; Shimano STEPS HOLLOWTECH e-MTB crank arms, 165 mm; SRAM X-Sync 34t chainring on Shimano SM-CRE80-B spider; SRAM Eagle AXS controller, 12-speed; SRAM Eagle, 12-speed (10-52); SRAM Eagle, 12-speed | Shimano XTR, 12-speed; Shimano STEPS HOLLOWTECH e-MTB crank arms, 165 mm; Shimano XTR, 12-speed; Shimano XTR, 12-speed (10-51); Shimano M9100 XTR, 12-speed | SRAM XX1 Eagle AXS, wireless; Shimano STEPS HOLLOWTECH e-MTB crank arms, 165 mm; SRAM Eagle AXS Rocker, 12-speed; SRAM XX1 Eagle, 12-speed (10-52); SRAM X01 Eagle, 12-speed |
| Wheels | RaceFace AR30 (front) / RaceFace AR35 (rear) on Shimano MT400 / MT510 hubs | Sun Ringle Duroc (15x110 front) | DT Swiss H1900 (29in front / 27.5in rear) | Reynolds TR 309 E carbon (front, 29er) / Reynolds TR 367 E carbon (rear, 27.5in), Reynolds Tre hubs | Reynolds TR 309 E carbon (front, 29er) / Reynolds TR 367 E carbon (rear, 27.5in) |
| Tyres | Maxxis Assegai 3C MaxxTerra EXO 29x2.5 (front) / Maxxis Minion DHR II EXO 27.5x2.6 (rear) | Maxxis Assegai 3C MaxxTerra EXO 29x2.5 (front) / Maxxis Minion DHR II EXO 27.5x2.6 (rear) | Maxxis Assegai 3C MaxxTerra EXO 29x2.5 (front) / Maxxis Minion DHR II EXO 27.5x2.6 (rear) | Maxxis Assegai 29x2.5 (front) / Maxxis Minion DHR II 27.5x2.6 WT (rear) | Maxxis Assegai 3C MaxxTerra EXO 29x2.5 (front) / Maxxis Minion DHR II EXO 27.5x2.6 (rear) |
| Weight | 23.05 kg | 23.05 kg | 22.84 kg | 21.84 kg | 22.05 kg |
| Price | £4,749 | £5,499 | £6,399 | £8,199 | £9,999 |
Rides similarly
Spot a mistake?
