Bike Finder · Canyon
Canyon Neuron:ONfly
Canyon
Neuron:ONfly 2026
CurrentLightweight eMTBCurrent · 7.5/10iFreshness 7.5/10
Motor
Bosch Performance Line SX · 60Nm · 600W
Battery
Bosch CompactTube 400 · 400Wh
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Full carbon
Weight
20.1 kg
Price
From £4,199
View the Canyon Neuron:ONfly on Canyon’s site
Canyon Neuron:ONfly 2026
From £4,199
EMTB Forums verdict
The Neuron:ONfly is Canyon's lightweight carbon trail e-MTB, pairing the compact Bosch Performance Line SX motor with a downtube-integrated 400 Wh battery for a claimed weight of around 20 kg. With 140 mm of travel front and rear on 29in wheels, a 64.5 degree head angle and 76.5 degree effective seat angle, it sits between a full-power e-MTB and an analogue trail bike, leaning towards an agile, efficient ride rather than outright climbing assistance.
Two carbon builds are offered for 2026. The CF 7 (RRP 4,199 pounds) runs a RockShox Pike Base fork and Deluxe Select+ shock with a Shimano Deore M6100 drivetrain, while the CF 8 (RRP 5,149 pounds) steps up to a Fox 34 Performance fork, Fox DPS Performance shock and a stronger four-piston Shimano Deore XT M8120 front brake. Both share the same frame, FSA cranks, Rodi and Iridium 30 mm aluminium wheels and Schwalbe Hans Dampf / Nobby Nic tyre pairing, so the extra outlay on the CF 8 buys suspension and brake quality rather than a lighter or faster bike.
Geometry stays consistent across the five sizes, with a fixed 450 mm chainstay and a 36 mm bottom bracket offset, and reach growing in even 25 mm steps from 410 mm (XS) to 510 mm (XL). The relaxed front end and longer rear centre suggest a stable, descending-biased character for a bike of this travel, while the integrated battery and PowerMore 250 range-extender compatibility extend its touring potential.
Bike geometry diagram
XSSMLXL
Reach410 mm435 mm460 mm485 mm510 mm
Stack608 mm626 mm635 mm644 mm653 mm
Seattube392 mm405 mm415 mm445 mm455 mm
Chainstay450 mm450 mm450 mm450 mm450 mm
Headtube Angle64.5°64.5°64.5°64.5°64.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°76.5°
Wheelbase1179 mm1213 mm1242 mm1271 mm1301 mm
Headtube110 mm120 mm130 mm140 mm150 mm
Standover757 mm767 mm770 mm775 mm779 mm
Front Centre729 mm*763 mm*792 mm*821 mm*851 mm*
Trims · 2
CF 7
£4,199
CF 8
£5,149
MotorBosch Performance Line SX · 60 Nm · all trims
BatteryBosch CompactTube 400 · 400 Wh · all trims
Travel F/R140/140 mm · all trims
FrameCarbon · all trims
ForkRockShox Pike Base, 140 mm travel, 44 mm offset, 35 mm stanchionsFox 34 Performance, 140 mm travel, 44 mm offset, 34 mm stanchions
ShockRockShox Deluxe Select+Fox DPS Performance
StemCanyon:ON ST0031, 45 mm, 35 mm clamp · all trims
HandlebarCanyon:ON HB0056 Riser bar, 20 mm rise, 35 mm clamp · all trims
GripsCanyon Lock-On · all trims
SaddleFizik Terra Aidon X5 · all trims
SeatpostCanyon SP0070-01 dropper, 34.9 mm, cable actuated · all trims
BrakesShimano M6120 (4-piston) / Shimano M6100 (2-piston)Shimano Deore XT M8120 (4-piston front) / Shimano M8100 (2-piston rear)
Rear derailleurShimano Deore M6100, 12-SpeedShimano Deore XT M8100
CrankFSA CK-745, 170 mm, 34T chainring · all trims
ShiftersShimano Deore M6100, 12-Speed · all trims
CassetteShimano Deore M6100, 10-51, 12-speed · all trims
ChainShimano Deore M6100 · all trims
DrivetrainShimano Deore M6100, 12-Speed; FSA CK-745, 170 mm, 34T chainring; Shimano Deore M6100, 12-Speed; Shimano Deore M6100, 10-51, 12-speed; Shimano Deore M6100Shimano Deore XT M8100; FSA CK-745, 170 mm, 34T chainring; Shimano Deore M6100, 12-Speed; Shimano Deore M6100, 10-51, 12-speed; Shimano Deore M6100
WheelsFront: Rodi TRYP 30 (Shimano MT400 hub); Rear: Iridium 30 (Shimano MT510 hub); 30 mm inner width, aluminium · all trims
TyresFront: Schwalbe Hans Dampf 60 mm; Rear: Schwalbe Nobby Nic 62 mm · all trims
Weight20.3 kg20.1 kg
Price£4,199£5,149
Rides similarly
Spot a mistake?
