Bike Finder · Canyon
Canyon Neuron:ONfly
Canyon
Neuron:ONfly 2024
DiscontinuedTrail eMTBLegacy · 2.9/10iFreshness 2.9/10
Motor
Bosch Performance Line SX · 55Nm · 600W
Battery
Bosch CompactTube 400 · 400Wh
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Full carbon
Weight
19.1 kg
Price
From £4,499
View the Canyon Neuron:ONfly on Canyon’s site
Canyon Neuron:ONfly 2024
From £4,499
EMTB Forums verdict
The Neuron:ONfly was Canyon's first lightweight e-MTB and the mid-power sibling to the full-power Neuron:ON CF. It pairs a 140 mm carbon trail chassis with the compact Bosch Performance Line SX motor (55 Nm, 600 W peak) and a downtube-integrated 400 Wh CompactTube battery, with an optional PowerMore 250 Wh range extender. The geometry is moderate trail rather than aggressive enduro: a 64.5 degree head angle, 76.5 degree seat angle, 450 mm chainstays across all five sizes and reach from 410 mm (XS) to 510 mm (XL), with the XS dropping to 130 mm travel and a narrower bar.
The four-trim range climbs steeply on value. The CF 7 (£4,499) runs a RockShox Pike, Shimano Deore 12-speed and SRAM Code R brakes at a claimed 20.3 kg. The CF 8 (£5,199) is the sensible mid-spec with a Fox 34 Performance, Shimano XT four-piston brakes and a 19.6 kg claimed weight. The CF 9 (£6,499) moves to a Pike Ultimate, SRAM GX Eagle AXS Transmission and DT Swiss HX1700 wheels. The CF LTD (£7,449) tops out with a Fox 34 Factory, SRAM XX Eagle AXS, Code Ultimate brakes and Reynolds carbon wheels for a claimed 19.1 kg.
All trims share the same carbon frame, Bosch SX motor, 400 Wh battery, Schwalbe Hans Dampf front / Nobby Nic rear tyres and 200 mm rotors, so the price difference is suspension, drivetrain, brakes and wheels rather than capability. The CF 8 stands out as the value pick.
This is a discontinued 2024 model. Canyon has since continued the Neuron:ONfly line with updated Bosch SX builds, so later model-year versions supersede it, but the 2024 platform, motor and geometry described here are the launch configuration.
Bike geometry diagram
XSSMLXL
Reach410 mm435 mm460 mm485 mm510 mm
Stack608 mm626 mm635 mm644 mm653 mm
Seattube392 mm405 mm415 mm445 mm455 mm
Chainstay450 mm450 mm450 mm450 mm450 mm
Headtube Angle64.5°64.5°64.5°64.5°64.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°76.5°
Wheelbase1179 mm1213 mm1242 mm1271 mm1301 mm
Headtube110 mm120 mm130 mm140 mm150 mm
BB Height338 mm338 mm338 mm338 mm338 mm
Standover757 mm767 mm770 mm775 mm779 mm
Front Centre729 mm*763 mm*792 mm*821 mm*851 mm*
Trims · 4
CF 7
£4,499
CF 8
£5,199
CF 9
£6,499
CF LTD
£7,449
MotorBosch Performance Line SX · 55 Nm · all trims
BatteryBosch CompactTube 400 · 400 Wh · all trims
Travel F/R140/140 mm · all trims
FrameCarbon · all trims
ForkRockShox Pike, 140 mm travel, 1 1/8"-1.5" steererFox 34 Performance, 34 mm stanchions, 140 mm travel, 44 mm offsetRockShox Pike Ultimate, 140 mm travel, 44 mm offsetFox 34 Factory, 140 mm travel, 15x110 mm, 44 mm offset
ShockRockShox Deluxe Select+, 140 mm travelFox Float DPS Performance, 140 mm travelRockShox Deluxe Select+, 140 mm travelFox Float DPS Factory, 140 mm travel
HeadsetAcros Block Lock · all trims
StemCanyon:ON ST0031, 45 mm, 35.0 mm clamp, aluminium · all trims
HandlebarCanyon:ON HB0056 riser bar, aluminium, 760 mm width, 20 mm rise, 35.0 mm clamp · all trims
GripsCanyon Lock-On · all trims
SaddleFizik Terra Alpaca X5Fizik Terra Alpaca X5Fizik Terra Aidon X5Fizik Terra Aidon X5
SeatpostCanyon SP0070-01 dropper, cable-actuated, 34.9 mm, travel size-dependent · all trims
BrakesSRAM Code R, 4-piston hydraulic discShimano Deore XT M8120, 4-piston hydraulic discSRAM Code Silver Stealth, 4-piston hydraulic discSRAM Code Ultimate Stealth, 4-piston hydraulic disc
Rear derailleurShimano Deore M6100, 12-speed, long cageShimano Deore XT M8100, long cageSRAM GX Eagle AXS TransmissionSRAM XX Eagle AXS Transmission
CrankFSA CK-745, 170 mmFSA CK-745, 170 mmFSA CK-745, 170 mmSRAM XX, 170 mm
ShiftersShimano Deore M6100, 12-speedShimano Deore M6100, 12-speedSRAM AXS PodSRAM AXS POD Ultimate
CassetteShimano Deore M6100, 12-speed, 10-51Shimano Deore M6100, 12-speed, 10-51SRAM XS-1275 Eagle Transmission, 12-speed, 10-52SRAM XX Eagle Transmission, 12-speed, 10-52
ChainShimano Deore M6100Shimano XTSRAM GX Eagle TransmissionSRAM XX T-Type
DrivetrainShimano Deore M6100, 12-speed, long cage; FSA CK-745, 170 mm; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51; Shimano Deore M6100Shimano Deore XT M8100, long cage; FSA CK-745, 170 mm; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51; Shimano XTSRAM GX Eagle AXS Transmission; FSA CK-745, 170 mm; SRAM AXS Pod; SRAM XS-1275 Eagle Transmission, 12-speed, 10-52; SRAM GX Eagle TransmissionSRAM XX Eagle AXS Transmission; SRAM XX, 170 mm; SRAM AXS POD Ultimate; SRAM XX Eagle Transmission, 12-speed, 10-52; SRAM XX T-Type
WheelsRODI TRYP30 EVO (F 15x110 mm, R 12x148 mm), Center LockSun Ringle 329 Trail Expert (F 15x110 mm, R 15x148 mm), Center LockDT Swiss HX1700 (F 15x110 mm, R 12x148 mm), Center Lock, aluminiumReynolds Trail 329 Blacklabel Expert (F 15x110 mm), Center Lock, carbon
TyresSchwalbe Hans Dampf 29" (front) / Schwalbe Nobby Nic 29" (rear), 60 mm width · all trims
Weight20.3 kg19.6 kg19.9 kg19.1 kg
Price£4,499£5,199£6,499£7,449
Rides similarly
Spot a mistake?
