Bike Finder · Canyon
Canyon Grand Canyon:ON
Canyon
Grand Canyon:ON 2024
DiscontinuedFull Power · Cross-CountryLegacy · 1.6/10iFreshness 1.6/10
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
23.3 kg
Price
From £3,099
View the Canyon Grand Canyon:ON on Canyon’s site
Canyon Grand Canyon:ON 2024
From £3,099
EMTB Forums verdict
The 2024 Grand Canyon:ON is Canyon's aluminium flagship hardtail eMTB, built around a Bosch Performance Line CX motor (85 Nm) and a 750Wh PowerTube battery on a 29in, 120mm-fork platform. It is pitched as an all-day do-it-all adventure machine rather than a hard-charging trail weapon, and the geometry reflects that: a moderate 68-degree head angle, 76.5-degree effective seat angle, 460mm chainstays across all sizes and a low 309mm BB make for stable, planted handling rather than aggressive slackness.
The three-trim ladder is tightly spaced. The 7 (£3,099) runs a RockShox Judy Silver TK fork, SRAM DB8 brakes, a Shimano Deore drivetrain and a rigid seatpost. The 8 (£3,499) is the sweet spot, adding a FOX 34 AWL fork, a Deore XT rear mech, a 12-speed Shimano Deore group and an Iridium dropper post. The 9 (£3,999) tops out with Magura CTE ABS braking and a fuller XT build. All three share the same frame, motor, 750Wh battery and 23 to 24kg claimed weights, so the spend goes on suspension, brakes and drivetrain rather than ride platform.
This model year is discontinued. Canyon has since relaunched the line as the Grand Canyon:ON AL (7/8/9), moving to the latest Bosch Performance Line CX with higher peak output and a larger battery option while keeping the same do-it-all hardtail brief. British buyers seeking the 2024 bike will now find it only on the used market.
Geometry read
Size
Descending
44
Steeper 68° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Playfulness
62
Size balance
79
Rear-long with a planted front in L (FC:RC 1.69) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
79
Bosch Performance Line CX Gen 4 and a steep 76.5° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Watch out forNot built for serious descending — happier on flow than in the rough and steep.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 106 bikes in the database)
Weight23.3 kgabout average weight
Battery750 Wh53 Wh above average
Motor torque85 Nm8 Nm below average
Value for money67/100from £3,099 · most Bosch Performance Line CX Gen 4 bikes ~£3,499
💬 Forum discussion
Canyon with AVINOX!
14 replies · 3.2k views · last reply 2 days ago
Join the discussion →
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm500 mm
Stack647 mm661 mm675 mm688 mm
Seattube395 mm440 mm485 mm540 mm
Chainstay460 mm460 mm460 mm460 mm
Headtube Angle68°68°68°68°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1175 mm1206 mm1236 mm1267 mm
Headtube115 mm130 mm145 mm160 mm
BB Height309 mm309 mm309 mm309 mm
Standover782 mm792 mm823 mm837 mm
Front Centre715 mm*746 mm*776 mm*807 mm*
FC:RC1.551.621.691.75
Trims · 3
7
£3,099
8
£3,499
9
£3,999
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R120/? mm · all trims
FrameAluminium · all trims
ForkRockShox Judy Silver TK, Travel: 120 mmFOX 34 AWL, Axle: 15x110 mm, Stanchion: 34 mm, Travel: 120 mm, Offset: 51 mmFOX 34 AWL, Travel: 120 mm
StemCanyon:ON ST0031, Length: 45 mmCanyon:ON ST0031, Length: 45 mm, Clamp: 35.0 mmCanyon:ON ST0031, Length: 45 mm, Clamp: 35 mm
HandlebarCanyon:ON HB0056 Riser bar, Aluminium, Width: 760 mm, Rise: 20 mmCanyon:ON HB0056 Riser bar, Aluminium, Clamp: 35.0 mm, Width: 760 mm, Rise: 20 mmCanyon:ON HB0056 Riser bar, Clamp: 35 mm, Width: 760 mm, Rise: 20 mm
SaddleFizik Terra Alpaca X5Fizik Terra Alpaca X5, 230 gFizik Terra Alpaca X5, 230 g
SeatpostSP HL C255 400, Aluminium, Clamp diameter: 30.9 mmIridium Dropper Post, Aluminium, Clamp: 30.9 mm, 567 gIridium Dropper Post, Aluminium, Clamp: 30.9 mm, 580 g
BrakesSRAM DB8 Hydraulic DiscShimano Deore M6120 (front) | Shimano Deore M6100 (rear) Hydraulic DiscMagura CTE ABS, 4-piston Hydraulic Disc
Rear derailleurShimano Deore M6100, long cageShimano Deore XT M8100, long cageShimano Deore XT M8100, long cage
CrankFSA 745 E-Bike Crank for Bosch Gen4FSA 745 E-Bike Crank for Bosch Gen4FSA E-Bike Crank for Bosch Gen4
ShiftersShimano Deore M6100Shimano Deore M6100 12sShimano Deore XT
CassetteShimano Deore M6100, 10-51T, 12-speedShimano Deore M6100, 10-51T, 12-speed10-51T, 12-speed
ChainShimano CN-M6100
DrivetrainShimano Deore M6100, long cage; FSA 745 E-Bike Crank for Bosch Gen4; Shimano Deore M6100; Shimano Deore M6100, 10-51T, 12-speedShimano Deore XT M8100, long cage; FSA 745 E-Bike Crank for Bosch Gen4; Shimano Deore M6100 12s; Shimano Deore M6100, 10-51T, 12-speed; Shimano CN-M6100Shimano Deore XT M8100, long cage; FSA E-Bike Crank for Bosch Gen4; Shimano Deore XT; 10-51T, 12-speed
WheelsAluminiumRODI TRYP30 EVO, Center LockAluminium
TyresSchwalbe Nobby Nic Performance 29", 2.6"Schwalbe Nobby Nic Performance 2.6"Schwalbe Nobby Nic Performance 2.6", Tubeless Ready
Weight23.3 kg23.5 kg24.2 kg
Price£3,099£3,499£3,999
Rides similarly
Spot a mistake?
