Bike Finder · Bulls
Bulls Vuca EVO X 1
Bulls
Vuca EVO X 1 2025
CurrentFull Power · Cross-CountryAgeing · 4.9/10iFreshness 4.9/10
Motor
Pinion MGU (E1.12) · 85Nm · 600W
Battery
Bulls UltraCore 1055 · 1055Wh
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
28.65 kg
Price
£5,620
View the Bulls Vuca EVO X 1 on Bulls’s site
Bulls Vuca EVO X 1 2025
From £5,620
EMTB Forums verdict
The Bulls Vuca EVO X 1 is the e-SUV member of the Vuca EVO range, set apart from its all-mountain siblings by a rigid rear end and a 120 mm Bulls Lytro 36 fork rather than full suspension. The headline feature is the FIT Pinion MGU E1.12 gearbox motor, which integrates a 12-speed bottom-bracket gearbox with the drive unit and pairs it to a Gates CDX belt rather than a chain and derailleur, for 85 Nm of torque and very low routine maintenance.
Equipment is touring-led rather than trail-led: a MonkeyLoad rack, alloy mudguards, Fuxon lights with daytime running light, a Pletscher stand and a suspension dropper post all come fitted, and the 1055 Wh UltraCore battery is built in. Shimano Deore brakes with a 203 mm front rotor and wide 29 x 2.40 Supero tyres give it real stopping power and grip for a bike of this type. Claimed weight is a substantial 28.65 kg, in keeping with the SUV brief.
Geometry is upright and stable rather than aggressive: a 67 degree head angle, 74 degree seat angle, 420 mm reach and 1179 mm wheelbase across both listed sizes (S and M), with only the seat tube length changing between them. This is a comfort-oriented machine for surfaced trails, gravel and commuting rather than technical descending. It is sold at a single trim level with a recommended retail price of EUR 6,699.
Bike geometry diagram
SM
Reach420 mm420 mm
Stack679 mm679 mm
Seattube410 mm440 mm
Chainstay450 mm450 mm
Headtube Angle67°67°
Seattube Angle (eff)74°74°
Wheelbase1179 mm1179 mm
Headtube160 mm160 mm
Front Centre729 mm*729 mm*
FC:RC1.621.62
Trims · 1
Base
£5,620
MotorPinion MGU (E1.12) · 85 Nm
BatteryBulls UltraCore 1055 · 1055 Wh
Travel F/R120/? mm
FrameAluminium
ForkBulls Lytro 36 Supreme SL 1.8 Boost EQ 2CR-PCS DS 15LH-110, 120 mm
HeadsetFSA NO.72/55R 1.8" /CUP/CR
StemZECURE SUVi clean cockpit stem
HandlebarZECURE riser bar
GripsBulls Comfort Grip
SaddleBULLS Sportive Ergo
SeatpostLIMOTEC Alpha 3 Dropper Post with suspension (40 mm); S/M 40 mm, L/XL 80 mm + SL-MT500-L (with clamp)
BrakesSHIMANO Deore BR-M6120 hydraulic disc brake
Rear derailleurGATES Snubber (belt drive, Pinion bottom-bracket gearbox)
CrankPINION P8500
ShiftersPINION TE1
CassetteGATES CDX, 32T
ChainGates belt drive (Belt protection disc)
DrivetrainGATES Snubber (belt drive, Pinion bottom-bracket gearbox); PINION P8500; PINION TE1; GATES CDX, 32T; Gates belt drive (Belt protection disc)
WheelsRYDE Disc 30, tubeless ready
TyresSUPERO All Ground Anti-Puncture, 29 x 2.40 (62-622)
Weight28.65 kg
Price£5,620
Rides similarly
Spot a mistake?
