Bike Finder · Bulls
Bulls Vuca EVO FSX 1
Bulls
Vuca EVO FSX 1 2024
DiscontinuedTrail eMTBLegacy · 1.9/10iFreshness 1.9/10
Motor
Pinion MGU (E1.12) · 85Nm · 600W
Battery
FIT UltraCore 720 · 720Wh
Travel F/R
120/120mm
Wheels
29F / 29R
Frame
Aluminium
Weight
29.9 kg
Price
£0
View the Bulls Vuca EVO FSX 1 on Bulls’s site
Bulls Vuca EVO FSX 1 2024
EMTB Forums verdict
The Bulls Vuca EVO FSX 1 is a full-suspension eSUV rather than a conventional trail eMTB. It pairs 120 mm of travel front and rear on 29in wheels with a comprehensive touring kit: full mudguards, integrated FUXON lighting, a MonkeyLoad rear rack mount, kickstand and ABUS frame lock. The headline feature is the FIT Pinion MGU E1.12 gearbox motor, an 85 Nm unit that combines a mid-drive with a 12-speed internal gearbox and a maintenance-light Gates CDX belt instead of a chain and derailleur.
The build is sold as a single FSX 1 specification with a choice of Diamant (classic top tube) or Wave (step-through) frame and either a 720 Wh or 960 Wh FIT UltraCore battery. Notable parts include a BULLS Lytro 36 Supreme SL 1.8in oversteerer fork, an SR Suntour Edge rear shock, Shimano four-piston BR-M6120 brakes with a 203 mm front rotor, a LIMOTEC dropper post and puncture-protected Supero All Ground tyres. Claimed weight is around 29.9 kg, reflecting the heavy-duty touring fit-out and the gearbox drivetrain.
Geometry is touring-oriented rather than aggressive: a relaxed 67.5 degree head angle, a 75 degree seat angle and reach figures from 449 mm in S to 490 mm in XL, with a tall stack for an upright position. Chainstays stay long at 480 mm across all sizes for stable, planted handling.
This 2024 model is discontinued. Bulls carried the Vuca EVO FSX 1 forward into 2025 with the same frame and geometry, so a near-identical successor exists in later catalogues.
Bike geometry diagram
SMLXL
Reach449 mm445 mm468 mm490 mm
Stack601 mm615 mm624 mm634 mm
Seattube410 mm440 mm480 mm540 mm
Chainstay480 mm480 mm480 mm480 mm
Headtube Angle67.5°67.5°67.5°67.5°
Seattube Angle (eff)75°75°75°75°
Wheelbase1215 mm1217 mm1243 mm1269 mm
Headtube105 mm120 mm130 mm140 mm
Front Centre735 mm*737 mm*763 mm*789 mm*
Trims · 1
FSX 1
MotorPinion MGU (E1.12) · 85 Nm
BatteryFIT UltraCore 720 · 720 Wh
Travel F/R120/120 mm
FrameAlloy
ForkBULLS Lytro 36 Supreme SL 1.8 Boost, 120 mm travel
ShockSR SUNTOUR Edge LOR8 Trunnion Mount, 120 mm rear travel
HeadsetFSA NO.72/55R 1.8" /CUP/CR
StemBULLS SUVi, CCS Slot Mount ready
HandlebarZECURE Sport-SL
GripsComfortgriff (comfort grips)
SaddleBULLS Sportive Ergo
SeatpostLIMOTEC Alpha 1, 34.9 / S 100mm, M 125mm, L,XL 150mm + SL-MT500-IL with I-spec EV (dropper)
BrakesSHIMANO BR-M6120 hydraulic disc brake
Rear derailleurGATES Snubber (belt tensioner); Pinion 12-speed gearbox, E-Trigger shifter
CrankPinion P8500 170mm
ShiftersE-Trigger
Cassette39/24T (Pinion gearbox), Rear hub FORMULA ECL-52 39T
ChainGATES CDX belt (Carbon Drive)
DrivetrainGATES Snubber (belt tensioner); Pinion 12-speed gearbox, E-Trigger shifter; Pinion P8500 170mm; E-Trigger; 39/24T (Pinion gearbox), Rear hub FORMULA ECL-52 39T; GATES CDX belt (Carbon Drive)
WheelsRYDE Disc 30, tubeless ready; front hub FORMULA CL-811, rear hub FORMULA ECL-52 39T
TyresSUPERO All Ground Anti-Puncture, 62-622 (29 in)
Weight29.9 kg
Rides similarly
Spot a mistake?
