Bike Finder · Bulls
no image yet
Bulls
Vuca EVO AM 2024
DiscontinuedTrail/Enduro eMTBLegacy · 1.9/10iFreshness 1.9/10
Motor
Pinion MGU (E1.12) · 85Nm · 600W
Battery
FIT UltraCore 720 · 720Wh
Travel F/R
150/150mm
Wheels
29F / 29R
Frame
Carbon front, aluminium rear
Weight
25 kg
View the Bulls Vuca EVO AM on Bulls’s site
Bulls Vuca EVO AM 2024
EMTB Forums verdict
The Bulls Vuca EVO AM was the brand's 2024 all-mountain flagship, built around the then-novel Pinion MGU E1.12: a single unit combining an 85 Nm mid-motor with a sealed 12-speed gearbox, driving a maintenance-light Gates CDX belt rather than a chain and derailleur. A carbon main frame with an alloy 4-link swingarm carries 150 mm of travel front and rear on 29in wheels, fed by a fully integrated 720 Wh FIT UltraCore battery (a 960 Wh pack was an order option).
Two builds were sold. The AM 1 (€7,499) ran a Bulls Lytro 36 fork, SR Suntour Edge shock and Shimano four-piston M6120 brakes. The AM 2 (€8,499) is the one to have if budget allows, stepping up to a Fox 38 Float Factory fork, Fox Float X Factory shock, Shimano XT M8120 brakes with a larger 220 mm front rotor and Ergon finishing kit, for a claimed 25 kg in size L. Both share the same frame, geometry, Pinion drivetrain and Maxxis Minion DHF/DHR2 tyres.
Geometry is moderate rather than aggressive: a 66 degree head angle, 75 degree effective seat angle and reach growing from 442 mm (S) to 484 mm (XL), with a consistent 455 mm chainstay across all four sizes. That points to a versatile tourer-trail character rather than an outright enduro weapon.
This 2024 model is now discontinued; Bulls has continued the Vuca EVO AM line on the Pinion MGU platform in later model years.
Bike geometry diagram
SMLXL
Reach442 mm452 mm472 mm484 mm
Stack626 mm626 mm640 mm658 mm
Seattube410 mm440 mm480 mm540 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)75°75°75°75°
Wheelbase1217 mm1227 mm1250 mm1273 mm
Headtube105 mm105 mm120 mm140 mm
Front Centre762 mm*772 mm*795 mm*818 mm*
Trims · 2
AM 1
AM 2
MotorPinion MGU (E1.12) · 85 Nm · all trims
BatteryFIT UltraCore 720 · 720 Wh · all trims
Travel F/R150/150 mm · all trims
FrameCarbon main frame, aluminium rear triangle · all trims
ForkBULLS Lytro 36 Supreme SL 1.8 Boost, 150 mmFOX 38 Float Factory, 150 mm
ShockSR SUNTOUR Edge LOR8 Trunnion MountFOX Float X Factory 2-pos Trunnion Mount
HeadsetACROS 310.52.570R1ACROS AZF-621, 310.52.621
StemBULLS MTBi-Sport, CCS Slot Mount ready · all trims
HandlebarBULLS Enduro Carbon · all trims
GripsMTB SportERGON GE10
SaddleSELLE ROYAL Vivo ErgoErgon GE10
SeatpostLIMOTEC Alpha 1, 34.9 / S 100mm, M 125mm, L,XL 150mm + SL-MT500-IL with I-spec EV · all trims
BrakesSHIMANO BR-M6120 hydraulic discSHIMANO XT BR-M8120 hydraulic disc
Rear derailleurGATES Snubber (Pinion bottom-bracket gearbox, 12 speed) · all trims
CrankPinion P8512 165mm · all trims
ShiftersE-Trigger · all trims
Cassette39/32T · all trims
ChainGATES CDX belt · all trims
DrivetrainGATES Snubber (Pinion bottom-bracket gearbox, 12 speed); Pinion P8512 165mm; E-Trigger; 39/32T; GATES CDX belt · all trims
WheelsRYDE Disc 30, tubeless ready · all trims
TyresMAXXIS Minion DHF / MAXXIS Minion DHR2 AM · all trims
Weight25 kg
Rides similarly
Spot a mistake?
