Bike Finder · Bulls
Bulls Sonic SX
Bulls
Sonic SX 2024
DiscontinuedLightweight eMTBLegacy · 2.9/10iFreshness 2.9/10
Motor
Bosch Performance Line SX · 60Nm · 600W
Battery
Bosch CompactTube 400 · 400Wh
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Full carbon
Weight
17.7 kg
Bulls Sonic SX 2024
EMTB Forums verdict
The Bulls Sonic SX is the carbon hardtail in the Sonic family, built around the lightweight Bosch Performance Line SX motor (rated 55 Nm, with a free firmware upgrade to 60 Nm and 600 W offered from autumn 2025) and a slim, expandable 400 Wh battery. It sits below the full suspension Sonic EVO SX and Sonic EVO AM SX models, trading rear travel for low weight and a clean, simple ride. With 120 mm of fork travel front and rigid at the rear, it is pitched as a sporty light assist eMTB for cross country and all mountain tours rather than aggressive descending.
Two trims were offered. The SX 1 (4,999 euro) runs an SR Suntour Raidon 34 Air fork, Shimano Deore 12 speed cabled drivetrain, Shimano MT420 brakes and Shimano WH-MT620 wheels at a claimed 18.6 kg. The SX 2 (6,399 euro) is the clear step up: a RockShox SID fork, wireless SRAM GX Eagle AXS Transmission, TRP brakes and Mavic Crossmax XL S wheels drop the claimed weight to 17.7 kg. The extra outlay buys electronic shifting, a lighter fork and a more capable wheelset, which is where the value lies for riders who want the lightest, best equipped build.
Geometry is moderate and trail friendly rather than slack: a 67 degree head angle, 75 degree seat angle and 445 mm chainstays across all sizes, with reach growing from 420 mm (S) to 490 mm (XL). That makes it an easy handling, efficient climber suited to flowing terrain, consistent with its light assist positioning.
The Sonic SX is discontinued as a 2024 model. Bulls has since moved its lightweight Bosch SX range forward under the Sonic EVO naming, so the simple SX hardtail is best viewed as a one off lightweight option in that line.
Bike geometry diagram
SMLXL
Reach420 mm450 mm470 mm490 mm
Stack629 mm638 mm657 mm666 mm
Seattube400 mm440 mm470 mm510 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle67°67°67°67°
Seattube Angle (eff)75°75°75°75°
Wheelbase1158 mm1192 mm1220 mm1244 mm
Headtube100 mm110 mm130 mm140 mm
Front Centre713 mm*747 mm*775 mm*799 mm*
Trims · 2
SX 1
SX 2
MotorBosch Performance Line SX · 60 Nm · all trims
BatteryBosch CompactTube 400 · 400 Wh · all trims
Travel F/R120/? mm · all trims
FrameCarbon · all trims
ForkSR SUNTOUR Raidon 34 Air, 120 mm travelRockShox SID, 120 mm travel
HeadsetACROS AIF-531 1.5" · all trims
StemRUMBLE Altimate · all trims
HandlebarRUMBLE Altimate · all trims
GripsBulls ProximPrologo Proxim Cush
SaddleSELLE ROYAL SRXPrologo Proxim 400 wide
SeatpostLIMOTEC Alpha Series A1-UH ultra lite, 125 mm dropper · all trims
BrakesSHIMANO BR-MT420 hydraulic discTRP C2.3RX Trail / Slate caliper, hydraulic disc
Rear derailleurSHIMANO Deore RD-M6100SRAM GX Eagle AXS Transmission
CrankSAMOX EC40SRAM GX Eagle
ShiftersSHIMANO Deore SL-M6100, rapidfire+SRAM EC AXS Rocker
CassetteSHIMANO Deore CS-M6100-12, 10-51TSRAM GX Eagle T-Type, 10-52T
ChainSHIMANO Deore CN-M6100-12SRAM Eagle GX
DrivetrainSHIMANO Deore RD-M6100; SAMOX EC40; SHIMANO Deore SL-M6100, rapidfire+; SHIMANO Deore CS-M6100-12, 10-51T; SHIMANO Deore CN-M6100-12SRAM GX Eagle AXS Transmission; SRAM GX Eagle; SRAM EC AXS Rocker; SRAM GX Eagle T-Type, 10-52T; SRAM Eagle GX
WheelsSHIMANO WH-MT620, tubeless readyMAVIC Crossmax XL S
TyresSCHWALBE NOBBY NIC Perf, Folding, 29 x 2.40 · all trims
Weight18.6 kg17.7 kg
Rides similarly
Spot a mistake?
