Bike Finder · Bulls
Bulls Sonic EVO AM
Bulls
Sonic EVO AM 2022
DiscontinuedFull Power · TrailLegacy · 1/10iFreshness 1/10
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Weight
Price
From €4,787
View the Bulls Sonic EVO AM on Bulls’s site
Bulls Sonic EVO AM 2022
EMTB Forums verdict
The 2022 Bulls Sonic EVO AM was the brand's full-power Bosch all-mountain line, built around a four-bar full-suspension frame on full 29in wheels. It is now discontinued. Note the wheel setup: the 2022 bikes run 29F / 29R, whereas the later 2023 Sonic EVO AM switched to a mullet (29F / 27.5R) layout, so the two model years are not interchangeable.
Travel runs 140mm on the alloy AM 1 and AM 1 750 (Bulls Lytro fork), stepping up to 150mm on the carbon AM 4 Carbon 750 with its RockShox Lyrik. Every trim uses the Bosch Performance Line CX (Gen 4, 85 Nm) motor. Batteries span a 500Wh PowerTube on the entry AM 1, a 625Wh pack on the non-Smart AM 2 Carbon, and the 750Wh Smart System (BES3, Kiox 300) on the 750-badged trims. The Smart System frames also sit slacker at 65 degrees versus 66 degrees on the non-Smart frames.
Value scales steeply: the alloy AM 1 opened at 4,787 euro, while the carbon flagship AM i Carbon with SRAM GX AXS, a Lyrik Ultimate and carbon DT Swiss wheels reached 9,917 euro. Bulls did not sell these at a genuine GBP RRP, so no sterling pricing is quoted here.
No owner or long-term ride data is captured for this dossier, so the notes above are limited to verified spec and geometry. The published Bulls geometry has a real stack quirk (it dips mid-range rather than rising monotonically) that carries across the trims and is genuine, not a data error.
Geometry read
Size
Setting
Descending
54
A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
58
Size balance
88
Rear-long with a planted front in L (FC:RC 1.73) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
71
Climbs well — a 74° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
Battery500 Wh204 Wh below average
Motor torque85 Nm13 Nm below average
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXLXXL
Reach415 mm430 mm450 mm480 mm510 mm
Stack625 mm619 mm628 mm637 mm655 mm
Seattube440 mm480 mm510 mm530 mm
Chainstay450 mm450 mm450 mm450 mm450 mm
Headtube Angle66°66°66°66°66°
Seattube Angle (eff)74°74°74°74°74°
Wheelbase1189 mm1204 mm1228 mm1262 mm1300 mm
Headtube120 mm120 mm130 mm140 mm160 mm
BB Height357 mm357 mm357 mm357 mm357 mm
Front Centre739 mm*754 mm*778 mm*812 mm*850 mm*
FC:RC1.641.681.731.801.89
Trims · 7
AM 1
€4,787
AM 1 750
€5,243
AM 2 Carbon
€5,471
AM 2 Carbon 750
€5,699
AM 3 Carbon 750
€5,927
AM 4 Carbon 750
€7,067
AM i Carbon
€9,917
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 500 · 500 Wh · all trims
Travel F/R140/140 mm · all trims
FrameAluminiumAluminiumCarbonCarbonCarbonCarbonCarbon
ForkBULLS Lytro 34 LOR 1.8 taperedBULLS Lytro 34 LOR 1.8 taperedBULLS Lytro 35 Supreme LOR Air 1.8 taperedBULLS Lytro 35 Supreme LOR Air 1.8 taperedRockShox 35 Gold RL 1.8 29”RockShox Lyric Select Charger RC 1.8 29”RockShox Lyrik Ultimate Charger 2.1 RC2 1.8 29”
ShockSR SUNTOUR Edge Plus RSR SUNTOUR Edge Plus RSR SUNTOUR Edge LOR8SR SUNTOUR Edge LOR8RockShox Deluxe RT Select+RockShox Deluxe RT Select+RockShox Deluxe RT Select+
HeadsetACROS no.1 1.8 taperedACROS no.1 1.8 taperedACROS no.1 1.8 taperedACROS no.1 1.8 taperedACROS no.1 1.8 taperedACROS no.1 1.8 taperedACROS no.4 1.8 tapered
StemBULLS MTB 35mm, internal cable routing · all trims
HandlebarBULLS riserbarBULLS riserbarBULLS riserbarBULLS riserbarBULLS riserbarBULLS riserbarBULLS Carbon Riser Bar
Saddleprologo Proxim 400 wideprologo Proxim 400prologo Proxim 400prologo Proxim 400prologo Proxim 400prologo Proxim 450 Sportprologo Proxim 450 Sport
SeatpostLIMOTEC Alpha 1LIMOTEC Alpha 1LIMOTEC Alpha 1LIMOTEC Alpha 1LIMOTEC Alpha 1LIMOTEC Alpha 18PINS NGS
BrakesSHIMANO MT420SHIMANO MT420SHIMANO MT420SHIMANO MT420SHIMANO Deore BR-M6120SHIMANO Deore XT BR-M8120TRP 2.3
Rear derailleurSHIMANO Deore RD-M5120SHIMANO Deore RD-M5120SHIMANO Deore RD-M5100SHIMANO Deore RD-M5100SHIMANO XT RD-M8100SHIMANO XT RD-M8100SRAM GX AXS
CrankSAMOXSAMOXSAMOXSAMOXE-ThirteenE-ThirteenE-Thirteen
ShiftersSHIMANO Deore XT SL-M6100SHIMANO Deore XT SL-M8100SHIMANO Deore XT SL-M8100SRAM XO1
CassetteSHIMANO Deore CS-M4100-10 11-46TSHIMANO Deore CS-M4100-10 11-46TSHIMANO Deore CS-M5100-11 11-51TSHIMANO Deore CS-M5100-11 11-51TSHIMANO CS-M6100-12 10-51TSHIMANO SLX CS-M7100-12 10-51TSRAM XG 1275 10-52T
DrivetrainSHIMANO Deore RD-M5120; SAMOX; SHIMANO Deore CS-M4100-10 11-46TSHIMANO Deore RD-M5120; SAMOX; SHIMANO Deore CS-M4100-10 11-46TSHIMANO Deore RD-M5100; SAMOX; SHIMANO Deore XT SL-M6100; SHIMANO Deore CS-M5100-11 11-51TSHIMANO Deore RD-M5100; SAMOX; SHIMANO Deore CS-M5100-11 11-51TSHIMANO XT RD-M8100; E-Thirteen; SHIMANO Deore XT SL-M8100; SHIMANO CS-M6100-12 10-51TSHIMANO XT RD-M8100; E-Thirteen; SHIMANO Deore XT SL-M8100; SHIMANO SLX CS-M7100-12 10-51TSRAM GX AXS; E-Thirteen; SRAM XO1; SRAM XG 1275 10-52T
Wheels29 / 27,5 Zoll (SHIMANO HB-MT400 front hub / FH-MT400 rear hub)29 / 27,5 Zoll (SHIMANO HB-MT400 front hub / FH-MT400 rear hub)29 / 27,5 Zoll (SHIMANO HB-MT400 front hub / FH-MT400 rear hub)29 / 27,5 Zoll (SHIMANO HB-MT400 front hub / FH-MT400 rear hub)SHIMANO WH-MT620DT SWISS H 1900 SplineDT SWISS HXC 1501 Spline Carbon
TyresSCHWALBE Magic Mary Performance Soft Grip / Hans Dampf Performance Speed GripSCHWALBE Magic Mary Performance Soft Grip / Hans Dampf Performance Speed GripSCHWALBE Magic Mary Performance Soft Grip / Hans Dampf Performance Speed GripSCHWALBE Magic Mary Performance Soft Grip / Hans Dampf Performance Speed GripSCHWALBE Magic Mary Performance Soft Grip / Hans Dampf Performance Speed GripSCHWALBE Magic Mary Evolution Super Trail / Big Betty Evolution Super TrailSCHWALBE Magic Mary Evolution Super Trail / Big Betty Evolution Super Trail
Price€4,787€5,243€5,471€5,699€5,927€7,067€9,917
Rides similarly
Spot a mistake?
