A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Sonic EVO AM-SL 2022
The 2022 Bulls Sonic EVO AM-SL is the brand's lightweight carbon all-mountain eMTB, built on a full-carbon Sonic E-Power chassis with 140 mm of RockShox travel front and rear on 29in wheels. Power comes from a Shimano STEPS EP8 mid-drive (85 Nm) fed by Bulls' own 750 Wh Sonic V10 pack, so it sits in the higher-capacity end of the lightweight class rather than the sub-500 Wh featherweight bracket. It is now discontinued.
Two trims were offered. The AM-SL 1 Carbon (around 5,199 euro) pairs a RockShox 35 Gold fork and Deluxe Select+ shock with a Shimano Deore/XT mix, Deore four-piston brakes and Shimano WH-MT620 wheels on Schwalbe Nobby Nic Performance rubber. The AM-SL 2 Carbon (around 6,199 euro) steps up to a RockShox Lyrik Select RC fork, Deore XT four-piston brakes, DT Swiss H1900 wheels, a carbon riser bar and the Nobby Nic Evo tyre, keeping the same XT rear mech and EP8 motor.
Geometry is consistent and middle-of-the-road for the era: a 66 degree head angle, 75 degree seat angle, 450 mm chainstays and reach growing from 430 mm to 490 mm across the 40 to 51 cm carbon frames. There is no flip chip or adjustable geometry. Both trims share the identical frame and geometry, with the spec being the only differentiator.
No owner ride-feel or long-term reliability data is captured here, so treat the assessment as spec-led. The standout positioning is a carbon Shimano-powered chassis with a large 750 Wh battery at a price that undercuts many carbon rivals.
Rear-long with a planted front in L (FC:RC 1.75) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Shimano EP8 (DU-EP800) and a steep 75° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
| S | M | L | XL | |
| Reach | 430 mm | 450 mm | 470 mm | 490 mm |
| Stack | 628 mm | 628 mm | 637 mm | 646 mm |
| Seattube | — | 440 mm | 480 mm | 510 mm |
| Chainstay | 450 mm | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 75° | 75° | 75° | 75° |
| Wheelbase | 1194 mm | 1214 mm | 1238 mm | 1262 mm |
| Headtube | 120 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 344 mm | 344 mm | 344 mm | 344 mm |
| Front Centre | 744 mm* | 764 mm* | 788 mm* | 812 mm* |
| FC:RC | 1.65 | 1.70 | 1.75 | 1.80 |
Trims · 2
AM-SL 1 Carbon €5,199 | AM-SL 2 Carbon €6,199 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm · all trims | |
| Battery | Sonic V10 750 · 750 Wh · all trims | |
| Travel F/R | 140/140 mm · all trims | |
| Frame | Carbon · all trims | |
| Fork | RockShox 35 Gold 1.8 tapered | RockShox Lyrik Select RC 1.8 tapered |
| Shock | RockShox Deluxe Select+ RL · all trims | |
| Headset | ACROS no.4 1.8 tapered | ACROS No.1B, 1-1/8 Zoll |
| Stem | BULLS MTB 35mm, internal cable routing · all trims | |
| Handlebar | BULLS riserbar | BULLS Carbon Riser Bar |
| Saddle | prologo Proxim 450 Sport · all trims | |
| Seatpost | LIMOTEC Alpha 1L | LIMOTEC Alpha 1 |
| Brakes | SHIMANO Deore BR-M6120 | SHIMANO Deore XT BR-M8120 |
| Rear derailleur | SHIMANO XT RD-M8100 · all trims | |
| Crank | E-Thirteen · all trims | |
| Shifters | SHIMANO Deore XT SL-M6100 | — |
| Cassette | SHIMANO Deore CS-M6100-12 10-51T | SHIMANO SLX CS-M7100 10-51T |
| Drivetrain | SHIMANO XT RD-M8100; E-Thirteen; SHIMANO Deore XT SL-M6100; SHIMANO Deore CS-M6100-12 10-51T | SHIMANO XT RD-M8100; E-Thirteen; SHIMANO SLX CS-M7100 10-51T |
| Wheels | SHIMANO WH-MT620/29”/30mm/TL | DT SWISS H1900 |
| Tyres | SCHWALBE Nobby Nic Performance | SCHWALBE Nobby Nic Evo |
| Price | €5,199 | €6,199 |
Rides similarly
Spot a mistake?
